What's this SMD component?
  • dfear
    • Mar 2013
    • 55
    What's the SMD component in the attached photos?
    IMG_20180529_150235.jpg shows a close up of the component and IMG_20180531_013659.jpg shows a bit more of the circuit that the component is part of.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: What's this SMD component?
    Tantalum 22uF 25V capacitor?
    • dfear
      • Mar 2013
      • 55
      How did you work out that it is a Tantalum capacitor?
      Does the "x" marking indicate the Package/Case size?
        It is typical case style that we have experience with and seen many times before. The white band in this case is 'Positive'.
        Is it tested bad?
        What is the circuit not doing?
        • redwire
          • Dec 2010
          • 3912
          From the pic, it's on a SMPS output where you need low ESR. A tantalum will roast there.
          So I think it would be a SMD polymer cap, 22uF 25V.
          Not sure why there is a river of solder and high-current traces around a little 22uF cap.
          You won't get an a amp of ripple current out of it...
          • dfear
            • Mar 2013
            • 55
            Is it tested bad?
            The component was "blown" completely off the board, the pad on the positive end was almost completely burnt off and and there is damage to the pcb substrate too.
            I was told "I think it was connected up incorrectly ".
            An op-amp and a couple of other mystery components in the same section of the board were damaged too.
            • dfear
              • Mar 2013
              • 55
              Further photos of the circuit that the mystery component is part of.
                Tantalum failure mode is shorts.
                I can see at least two bad solder joints and blown IC.
                • dfear
                  • Mar 2013
                  • 55
                  The blown IC is a AD8544 op-amp.
                  I can't see a bad solder joint where you marked BAD SOLDER JOINTS, I think the two prongs are a shunt.
                  • redwire
                    • Dec 2010
                    • 3912
                    AD8544 is a 5V part, this board has 12V?
                      Look at how the solder wet the leads and then look at other through hole device soldered leads, it doe not matter what the component is..
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        This takes a lot of guts to admit but it makes things much easier to diagnose...
                        Yeah I could see tantalum caps fry like that with reverse polarity... hopefully not too difficult to find what was damaged, but likely significant damage occurred.
                        • Rauni
                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                          by Rauni
                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                          Read also that we should test what happens if we...
                          10-01-2023, 12:06 AM
                        • Stanley1843
                          Dell Inspiron 15 3520 - AC Adapter shows "Not Installed - Not Charging
                          by Stanley1843
                          I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?...
                          09-27-2025, 08:44 PM
                        • saimom
                          Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
                          by saimom
                          Hello everyone!
                          Please help me determine which microcontroller was in this place.
                          Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
                          Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
                          They did not take photos before the intervention
                          The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
                          Maybe someone has a photo of this piece,...
                          12-17-2024, 08:51 AM
                        • ChaosLegionnaire
                          cracked tantalum cap on a video card. safe to apply power without fireworks?
                          by ChaosLegionnaire
                          please refer to the attached pics. is it safe to apply power with that tantalum cap like that without causing fireworks? i dont wanna burn a hole through the pcb as the gpu chip is on the other side.
                          happened to me once before with a shorted mlcc. shorted mlcc on a vrm power phase burned a hole through the pcb power section but thankfully that was nowhere near the gpu chip. but the video card still ended up in the landfill anyway tho as the burn-through was not fixable.
                          so do let me know what u think of the chipped tantalum there. thanks....
                          09-08-2024, 07:05 PM
                        • Davi.p
                          Reduce the size of photos please..
                          by Davi.p
                          Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
                          05-16-2024, 12:53 AM
