Asus ROG GL502VM G502VM Bios
  • JLCurve
    • Feb 2017
    • 32
    HI,
    Looking for bios image for the GL502VM (NOT the GL502VMK).
    Also, I'm a bit puzzled, there are 3 serial flash chips on this motherboard. Which one(s) are the bios?
  • angel-boy
    • 550
    • Romania
    Re: Asus ROG GL502VM G502VM Bios
    Mainboard name, and revision
    • JLCurve
      • Feb 2017
      • 32
      GL502VM
      Rev 2.0
      • angel-boy
        • 550
        • Romania
        try this
        • JLCurve
          • Feb 2017
          • 32
          Thank, I will do try.
          Onlly one chip is 64Mb so no confusion after all.
          Any idea what are the other two 8Mb chips? ... just curious.
          • angel-boy
            • 550
            • Romania
            Try to replace only W25Q64 , if not , let me know to search for all
            tell me the name of other 2 cip
            • JLCurve
              • Feb 2017
              • 32
              The two other chips are W25Q80.
              One of your files was the correct bios file. Thank you!
              But I still have weird blue screens in Windows 10. On the other hand, Ubuntu seems to run without problems. Will try to reinstall Win10.
              J.
              • angel-boy
                • 550
                • Romania
                See if the hard drive operating system is legacy or uefi ,
                • AlvaroGuerrero
                  • Aug 2018
                  • 3
                  Originally posted by JLCurve
                  HI,
                  hey was just wondering what number(in your photo) was the correct chip
                  • zommify
                    • Jun 2019
                    • 2
                    Is it possible to get a dump of the W25Q80. Sorry if I'm necroing a dead thread.
                    • Zeeshanali1
                      • Oct 2018
                      • 27
                      • Pakistan
                      i need accurate bios GL502vm rev 2.1
                      but i have an issue display driver did not install.......
                      i have try many time ..
                      zash
                      • balobi
                        • Jan 2015
                        • 88
                        • phillippines
                        Angel_boy, thanks! Working bin files.
                        • enricora
                          • Sep 2015
                          • 1
                          • italy
                          tanks! the ver GL502VM REV 2.1.zip have restore my bricked gl502vm.
                          very nice forum
                          • dumikosma
                            • Mar 2020
                            • 2
                            • Belgia
                            I do confirm that GL502VM REV2.1 is ok ; it save my laptop as wel . Thanks
                            • MISICO
                              • Jun 2021
                              • 1
                              • Ecuador
                              Hello, I hope you can help me, I am presented with a keyboard problem on my computer, this is a GL502VM and it has the Bios driver GL502VMK.308 installed, I try to install the bios that I downloaded from this forum but I do not have the option available in the BIOS ez flash 3 utility (it is off, it does not appear highlighted), I try to install it by the asus driver installer for windows 10 and it tells me that it is not compatible (it recognizes the GL502VMK> 308) and it does not let me go to an older driver How do I install the correct driver? Thank you
                              • ashefr10
                                • Mar 2021
                                • 11
                                • France
                                HELLO I search a full dump bios for G502VM With motherboard v2.0
                                (with ch341A programer spi) with backlight keyboard and me firmware please . (8mb)
                                • binoyroy
                                  • Sep 2017
                                  • 51
                                  • bangladeah
                                  [QUOTE=ashefr10;1198541]HELLO I search a full dump bios for G502VM With motherboard v2.0
                                  Try this
                                  • ashefr10
                                    • Mar 2021
                                    • 11
                                    • France
                                    [QUOTE=binoyroy;1198591]
                                    Try this
                                    hello, thank you this bios works the ME part no longer has the error at startup but I do not have the backlight of the keyboard
                                    backlight keyboard not work
                                    • ashefr10
                                      • Mar 2021
                                      • 11
                                      • France
                                      I need a complete bios where the backlight works as well as the ME part
                                      • peste
                                        • Dec 2016
                                        • 13759
                                        • ROMANIA
                                        try.this..
                                        https://www.badcaps.net/forum/showthread.php?t=69782
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • grimacelord
                                          ASUS TUF GAMING Z790-PLUS WIFI - BIOS Help
                                          by grimacelord
                                          I have spent the last hour on this and I guess this is just over my head, so here I am.
                                          I have an ASUS TUF GAMING Z790-PLUS WIFI motherboard here that needs to have the BIOS updated in order to accept the latest CPUs.
                                          The BIOS chips seem to come as a set of two: GD25B64ESIG and GD25B128ESIG. My guess is one of them is a fail-safe for the main BIOS? I really don't know. Or one of them is ME and other is BIOS? I don't know.
                                          Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
