All replacement capacitors in iMac G5 PSU burned up
  • nwd
    • Feb 2009
    • 22
    Hello members. I had 7 bad caps on the power supply for my iMac G5 1.6 Ghz 17 inch which I had a local electronics guy replace. I bought nichicon low impedance radial aluminum electrolytic capacitors from Mouser Electronics. All ratings were the same as those that came off the PSU although some of the physical sizes were slightly different. I brought it home, popped it in yesterday and good to go. Until this morning. I got a burning smell and when I opened up the PSU (which was very hot), the leads of every single new capacitor were brown and melty on the underside of the board. In addition, the coating/paint on a circular component with a wire running around it had turned black and cracked. There is also evidence of some overheating melting on one other component on a different part of the board.
    Any insight as to what happened here? All of the new capacitors going bad make me think I bought the wrong type of capacitors or that the guy installed them incorrectly. Other people have had incidences of other components being bad, but no cases described all the new capacitors burning up as a result of another component being bad. Thanks for any advice.
    -Nate
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: All replacement capacitors in iMac G5 PSU burned up
    If PSU was at least somewhat working before the repair I would suspect the caps were installed backwards or some solder got away from him (left on the board) and it shorted something out.
    The 'doughnut' with the wire looped around it is called a torrid.
    Mann-Made Global Warming.
    - Dr Seuss
    • nwd
      • Feb 2009
      • 22
      All the replacement caps appear to be inserted correctly. The white stripes on the caps align with the white paint marks at each location.
      Before the repair, the computer would only power up after pressing the power button tons of times and then eventually wouldn't power up at all.
      After the repair, the computer worked perfectly for a day and was in fact working fine when the burning smell began and I shut the machine down to discover the burn marks at all the leads. The torrid appeared to have cracks in the coating but otherwise seemed fine before the repair. After the burning smell, the coating was pure black and cracking much worse.
      I'm guessing that the bad caps caused the initial PSU failure. As the computer was still working when the smell started, would this PSU be likely to be salvageable in the right hands? I'm not sure what to ask the guy who did the work. Thanks again.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        The silk screens are sometimes reversed from the 'usual'.
        I say usual because there is no official standard so one manufacturer may make the 'white paint' negative and the another will make it positive.
        Sometimes they even make a mistake in the silk screen in a few spots.
        The trick is to look at the old caps before they are pulled and make a map of the replacements.
        Is it possible to fix. - Yes.
        Is it practical. - Probably not if you aren't the tech.
        The labor could easily run more than just buying a replacement.
        I think in your situation I'd look for a working replacement and then have it preemptively recapped. (Since you know the caps tend to go.)
        - Dr Seuss
        • i4004
          • Oct 2006
          • 2029
          it's something of a wonder it worked at all...
          well, if he's fair he should pay for the caps and pay back the labour, if he charged it.
          as boinez says, the chances are he put them backwards...ie he didn't look how old caps were installed, but looked just at the white-white match...and that may or may not be correct way...
          if you know how to solder change them yourself...or learn to solder and change them...
          we can probably help you with deciding what's the ground(minus for the caps) on that pcb.
          • nwd
            • Feb 2009
            • 22
            Thank you for the advice, members.
            Does anyone know the stats on the torrid that got really hot? It is at position L8 on the iMac G5 1.6 Ghz 17 inch power supply (Apple part no. 614-0293, AcBel part no. API3PC94) sort of right in the middle of everything on the low voltage side. Is this a part that could fail? Is it the sort of thing I can order?
            • Wizard
              • Mar 2008
              • 2296
              When a coil or a transformer bursts into smoke, it means PSU went SERIOUSLY wrong or missed small capacitors that caused frequency to go way off (too low or high) excessive noise to the point the coils simply heated up like a heater. What guy did bad was missed other capacitors; vital small capacitors that is on the voltage feedback and IC controller that drove the main transistors.
              That is where ESR meter is absolute must to check them during rebuilding of a said PSU especially complex type like apple uses.
              Cheers, Wizard
              • i4004
                • Oct 2006
                • 2029
                wizard
                perhaps you missed this
                "the leads of every single new capacitor were brown and melty on the underside of the board"
                coil burning was probably just the result of that, not the result of skipping some other (old) caps...ie in such case coil would be burning before swap too...
                well, first be sure it's destroyed, because it probably is not, even if it's al black...
                to go bad wire of it needs to be completely severed(melted to the point of breaking)..
                i don't think that happened because it probably would require more current than that psu can produce on ALL rails(and coil was only on one).
                this is easy to establish with multimeter: if it conducts electricity it's ok...
                problem could be if the isolation is burned to the wire and windings are touching, as in that case it's not a coil anymore...
                but we didn't saw your coil so we can't say...
                can you find replacement coils? probably yes.... many distributors carry lots of models...you can try contacting acbel and ask for specs(ie inductance of it)
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  where that thread worthess without pics smiley?
                  • Wizard
                    • Mar 2008
                    • 2296
                    Every caps? What about small ones like 10uF, 1uF, 22uF 47uF kind?
                    Cheers, Wizard
                    • i4004
                      • Oct 2006
                      • 2029
                      every single NEW capacitor, ie those that bloke put in....7 pieces.
                      ie new nichicon caps.
                      lasting few hrs..better to say burning up within few hrs...
                      indeed pics would be usefull....we could see the coil and the caps...some nice macro shots of that psu...
                      • nwd
                        • Feb 2009
                        • 22
                        I showed the board to the tech today. He said that the capacitors were fine, i.e, not burned up - the brownish goo on the underside of the board at each capacitor lead was a material from the soldering process. I don't think the brown stuff was there when I first got it back from repair - did it melt out at high temp? Also, the one capacitor on the low voltage side that was not replaced shows no evidence of brown stuff.
                        No small caps of the sizes you list, Wizard, were replaced. There are some small ones on the high voltage side but they look fine and I can't find any record of these causing anyone a problem.
                        I don't think the coil is destroyed.
                        I apologize if I have misled anyone with my descriptions. I haven't done anything with electronics before. Pics attached - sorry for the wait.
                        • i4004
                          • Oct 2006
                          • 2029
                          yes, i did find it a bit suspicious when you said
                          "the leads of every single new capacitor were brown and melty on the underside of the board."
                          but i thought you made a mistake and was actually talking about bad things happening on the component side of the pcb.
                          goo should bhe from soldering yeah...also if the caps were leaking, i don't think they would pass that pcb and solder to reach to other side...they would prefer to explode thru the top...
                          • i4004
                            • Oct 2006
                            • 2029
                            it seems to me they're not reversed....what were the original caps?
                            probably not low impedance?
                            there was one example where replacing gp caps with llow esr ones cause more noise on output....but huh, no burning was involved...
                            can't think of anything else that would cause new caps to make problems....
                            unless his soldering work made few unwanted connections...hard to see...is there a physical contact between pins of that cap near the coil?
                            that 1000uf6.3v cap
                            • nwd
                              • Feb 2009
                              • 22
                              Original caps are labeled LTec. All are LYZ 105C except for one which is TK 105C.
                              What may look like contact is where the tech scraped at the brown stuff a bit. I don't see any contact on the underside of the board.
                              • nwd
                                • Feb 2009
                                • 22
                                Another member describes the exact same symptom with the same coil in the "power supply and design troubleshooting" forum here:
                                https://www.badcaps.net/forum/showth...highlight=imac
                                • i4004
                                  • Oct 2006
                                  • 2029
                                  diodes on that rail should be checked...send it to wizard..he'll probably fix it...
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Looks like tech didn't clean the resin off the board.
                                    Depending on what was used it may be conductive.
                                    - Dr Seuss
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      bet the coil got stressed with the bad caps.
                                      its insulation cooked and it got shorted turns.
                                      iirc that one is on +3.3
                                      you might be able to rob one from some junker.its common in many psu's.
                                      look for one with same gauge and number of turns.
                                      your caps are ok.
                                      • i4004
                                        • Oct 2006
                                        • 2029
                                        i don't think that explains why it's getting hot...what do shorted turns do for a coil with few windings and thats running on 9x % DC?
                                        if anything it should be getting cooler with shorted turns...hehe...
                                        only if some eddy currents develop there....in that metal core, but i doubt current would prefer that path to the wire around it...
                                        • the Benninger
                                          Burning capacitors near Mosfet
                                          by the Benninger
                                          Hi Folk's, Thhe machibe its Dell OptiPlex 3070 mini, don't power up, two capacitors near mosfet (PQ0) burning
                                          These that you see on camera are new replaced, I had doubts if it was the capacitor (pc64) but I changed both at once, it still results in the same thing, it does not activate the safety of the power supply, and anyway the machine does not turn on, I am limited I only got this boardview, All ideas are welcome, the positive side capacitors have 19V without oscillations
                                          Mobo: IPCFL-CG Rev.A00
                                          S/T: JX8CM63...
                                          06-27-2024, 02:53 PM
                                        • Katz993
                                          iMac Display Replacement Adhesive
                                          by Katz993
                                          TL;DR: Looking for as-close-to-genuine as possible iMac Thin Panel (2012-2019) Adhesive.
                                          Long Rant: I run a tech shop that has a specialty in Macs. We've been doing upgrades and repairs on the thin panel iMacs as long as they've been out, and I've always had the issue of being unable to get something close to the OEM Adhesive for the Display Assembly, i.e. a 'two-part' adhesive, extremely thin but durable and can be cut easily with a thin wheel cutter. My replacement adhesive has always been essentially standard thin adhesive. For a long time, the biggest annoyance with this was having...
                                          03-15-2022, 10:31 AM
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                        • nicktasios
                                          Macintosh Quadra 840AV PSU
                                          by nicktasios
                                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                          12-22-2024, 05:07 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
