Burning capacitors near Mosfet
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Hi Folk's, Thhe machibe its Dell OptiPlex 3070 mini, don't power up, two capacitors near mosfet (PQ0) burning
    These that you see on camera are new replaced, I had doubts if it was the capacitor (pc64) but I changed both at once, it still results in the same thing, it does not activate the safety of the power supply, and anyway the machine does not turn on, I am limited I only got this boardview, All ideas are welcome, the positive side capacitors have 19V without oscillations
    Mobo: IPCFL-CG Rev.A00
    S/T: JX8CM63
  • mon2
    • Dec 2019
    • 14720
    See attached. Remove all power. Measure the resistance to ground of these caps. One side will be ground. Other side should be a high resistance. Confirm this detail.
    Click image for larger version  Name:	burning_caps.png Views:	0 Size:	168.4 KB ID:	3298213
    • the Benninger
      • Nov 2022
      • 189
      • venezulan
      Thanks for answering, I confirm both capacitors have ground resistance ranging from 16kOm and if you hold the munitmeter for a while this resistance varies up to 24khom where it starts to slow down but continues to slow down
      • the Benninger
        • Nov 2022
        • 189
        • venezulan
        There is another thing, I mentioned before when I created the post, that line that feeds the circuit has 19V without fluctuation, but the schematic you show me tells me that there should be 5V, you help me understand it mon2 thanks u
        • the Benninger
          • Nov 2022
          • 189
          • venezulan
          Disassemble the capacitors, one is 11 and the other 10.54uF, resistance on the positive rail without the capacitors is 25K
          • the Benninger
            • Nov 2022
            • 189
            • venezulan
            nice day mon2 u could read the data that is posted you I think you lost the thread I'm still interested in help can you take a minute out of your day to help me? I appreciate it. Have a very good day.
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • Nooy
              VGA MOSfet permanently shorted and loss of MOSfet pad
              by Nooy
              Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
              I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
              02-14-2024, 02:26 AM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
            • dragon3x
              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
              by dragon3x
              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
              power on.
              Here are some examples :
              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
              switching supply area).
              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
              than 6.3 V.)
              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
              I replaced capacitors with aluminum-polymer.
              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
              03-21-2025, 02:46 PM
            • AppleLover123
              Asus X712EA 3 volts after the first mosfet
              by AppleLover123
              Hey guys,
              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
              Now i thought something...
              12-15-2024, 07:49 AM
