Sharp 40LE550U strange Backlight issue
  • Jtroutt19
    • Aug 2011
    • 164
    So originally though I had some bad solder joints on the backlight strips in this tv. But after tearing it down and testing them I found out that wasn't the issue. So After I got it all back together and started cleaning the Panel the backlight popped on. I took my hand off the screen and it went out.
    I quickly discovered that if I pushed on the top of the TV the backlight would come on. So what in the world is going on here. I can see the PS board flex as I push the top of the TV. I have inspected the solder joints under microscope and don't see any cracks or damage anywhere. Any ideas?
  • heavymachines
    • Mar 2011
    • 1028
    Re: Sharp 40LE550U strange Backlight issue
    My first thought would be wires going to led strips grounding out or cold soldier joints on boards or connectors not seating right.
    • Jtroutt19
      • Aug 2011
      • 164
      I tested each individual LED strip. no bad solder joints. I will check wires thank you.
        Do the LED use SMD connectors to link the LED strip together? Those connectors are common failure.
        • Jtroutt19
          • Aug 2011
          • 164
          I would assume it is an SMD connector. THey are super tiny and don't really hold the strips together. I am going to take the panel out of it again and push on the connectors to see if I can get the backlight to come on.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            If you suspect the connectors you can bridge across them by soldering a wire across each.
              https://www.badcaps.net/forum/showth...124#post690124
              Same model I worked on a while back so probably same failure.
              • Jtroutt19
                • Aug 2011
                • 164
                Yip it’s working fully now. I actually discovered that thread yesterday
                • Cornito
                  Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                  by Cornito
                  Hello Team,
                  I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                  Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                  Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                  08-08-2024, 08:09 AM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • Cornito
                  TCL 65C715 backlight issue
                  by Cornito
                  Hello team,
                  I'm back with another topic.
                  It's a 65C715 TCL tv with backlight issue.
                  But the problem is a bit strange.
                  When I took this tv from the marketplace backlight didn't work but picture was ok.
                  Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                  Putting all back together the tv worked fine for weeks. => Contact issue??
                  Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                  06-09-2024, 02:24 AM
                • Superbee_dad
                  Sharp 80” long short flash backlight error - Help
                  by Superbee_dad
                  Hello Sharp TV experts
                  Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                  > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                  > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                  01-24-2025, 11:51 PM
                • shellybelly
                  Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                  by shellybelly
                  Back Story
                  I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                  So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                  08-27-2023, 10:40 PM
