Dell 15-AAL15 LA-D071P
  • borbooroski
    • Mar 2014
    • 177
    • Ghana
    Please guys i greet everyone here, i need a help
    there is this Dell 15-AAL15 LA-D071P which is given me hell
    When you plug in the Charger then the charger gose off i try all i could but still i saw this mosfet but when i change the mosfet and plug the charger again it will stay on for just 5seconds then the charger go off again. i dont know whatr to do please help your brother
  • imranromi
    • Jan 2015
    • 1290
    • Pakistan
    Re: Dell 15-AAL15 LA-D071P
    19v short check 19v line many time this problem is 19v capactor. Remove the mosfet and check all caps 19v.
    THIS MOTHERBOARD NO HAVE SCHEMATIC.
    • borbooroski
      • Mar 2014
      • 177
      • Ghana
      Alright imranromi Thank You for the responds
      • borbooroski
        • Mar 2014
        • 177
        • Ghana
        i can't find anything
        • borbooroski
          • Mar 2014
          • 177
          • Ghana
          please You guys are the best i know you can help me out.......Please
          • borbooroski
            • Mar 2014
            • 177
            • Ghana
              Great Sage é½Šå¤©å¤§č–
              • 31218
              does the dell have a model name?
              • imranromi
                • Jan 2015
                • 1290
                • Pakistan
                Dell insipron 5559 model. 6th generation motherboard.
                • borbooroski
                  • Mar 2014
                  • 177
                  • Ghana
                  • indu
                    • May 2015
                    • 30
                    • srilanka
                    https://www.badcaps.net/forum/showth...light=la-d071p
                    • zhanok
                      • Aug 2013
                      • 1
                      • eua
                      I have the same problem. Did you find a solution?
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        No one can help you here in forum(can help you to the right path only). Its you who have to find the faulty component physically. 19v line is shorted so have patience. Check mosfet and capacitors. Likely you have more then one componenet failure.
                        • vhn1998
                          • Jun 2015
                          • 56
                          • Vietnam
                          this is schematic. you check pin 1, pin 2 PU703
                          • Drassh
                            • Apr 2017
                            • 43
                            • Mexico
                            Thanks for heƱping in findind the schem and sharing it here. Very much appreciated
                            • nashdumur
                              • Feb 2016
                              • 7
                              • Mauritius
                              Hello guys, I have somewhat same problem but this one had a short on 5vs rail, so I found the following component short and replaced:
                              1. PU102
                              2. UZ2
                              3. PU603
                              4. PU605
                              5. HDA27
                              Now the led white for 1 second and off, only 5valws/3valws present. Now for this 1 second signal vr_on is 3v on pin 40.
                              Replaced bios chip from a donor board, now fan spins up. After solid white led goes off no display coming.
                              Does anyone has solution for this problem or did I miss something or did something wrong? Any help from you guys is very much appreciated.
                              • Sojke
                                • Apr 2017
                                • 131
                                • Serbia
                                Try clearing management engine.
                                • prlio
                                  • Oct 2017
                                  • 21
                                  • Cairo
