Altec MX6021
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Altec MX6021
    Hi All , greetings, someone pass a Altec Lansing MX6021 and I would like to learn how to repair it.
    The issue is there is no power to the speaker set.
    Note: Mods please move this post if you think it is in the wrong section.
    Upon inspection of the speaker power board, there were burnt components, of the resistors. the resistors were FUBAR.
    The power transistor seems to be shorted and I'm planning to replace those.
    The fuse is also open
    Normally for this caused? faulty filter capacitor? transistor? or shorts?
    As attached, it seems that some have gooey black stuffs on it.... i suppose glue become conductive?
    Many Thanks
  • jazzie366
    • May 2016
    • 304
    Re: Altec MX6021
    Many Thanks
    Well, the first obvious thing I can see is an exploded SMD resistor.
    Nothing else looks too bad other than shit got really hot due to the glue being browned.
    You're going to need an SMD rework station and a schematic to repair this, you up for that? The rework station isn't expensive, 60$ will get you one that can do the job.
    Popcorn.
    • ant3202
      • Jun 2006
      • 275
      • Singapore
      Re: Altec MX6021
      Hi Jazzie366
      thanks for the tips...
      You are right, the SMD has been burnt and i cannot read the values properly.
      Perhaps i need to ask people around and compare on it.
      Yea, i can lend a smd rework station from someone.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8155
        Re: Altec MX6021
        there are 5 smd resistors in parallel they should be all the same rating. I would change all 5 of them out.
        • ant3202
          • Jun 2006
          • 275
          • Singapore
          Re: Altec MX6021
          yea, CapLeaker, thanks for the tips, definitely it need to be changed.
          need help to identify... as it is badly burnt...
          i think it could be 1R0 but i might be wrong.
          • Behemot
            • 4845
            • CZ
            Re: Altec MX6021
            OMG! SMPS in speakers and chloroprene glue on top of that! What crap is this?
            1R0 is likely, it is fusible resistor which acts as fuse when something goes wrong on the primary.
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              Re: Altec MX6021
              thanks for your help Behemot
              you are right.... really crappy.... SMPS inside is really.... (
              older models were using transformer...
              can I say to change all to 1R0 ???
              i had checked.... the ic chip is busted, guess drawing too much current, burning the smd resistors and pcb 1.6A FUSE.
              as a precaution ... i will also change the filter capacitor and misc to better and reliable one.
              as checked with some tech guys ..... seems this board fails quite often.
              now no more decent stuffs from altec lansing...
              plantronics ... and stuffs are really going down......
              • Behemot
                • 4845
                • CZ
                Re: Altec MX6021
                You tell me, just got this BIG sub from Cambridge-whatever-something under Creative, expensive like hell, also SMPS in there (no wonder with the power the thing puts out) and ofc all caps busted. And vitually TONS of that chloroprene stuff EVERYWHERE.
                This is just crazy! Power supplies went ahead and even the El Cheapos start using two-forward topologies at least. But in audio equipment, everybody continues to produce the same shit they used to. Often even worse.
                When you start testing it, I suggest the lightbulb in series. Often it takes one bad SMD components to make the PWM driver explode again. This hould limit the current and protect it, plus you see right away there's a problem.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8155
                  Re: Altec MX6021
                  Those 4 resistors should all have the same value 1R0. Could you post a straight shot, high resolution pictures of the whole front and back side of the PSU? Right now, I'd say there are at least some resistors, the mosfet and the PWM blown. Once hi voltage gets shorted to the gate of the Mosfet, anything in between the Mosfet, including the PWM has to be checked. Only because there is resistance on a resistor, it doesn't mean the resistor is good. You would have to check the value of the resistor and compare it with spec. Usually resistors either burn up (open circuit) or they change their value of resistance HIGHER than spec. If you do up an order, get the PWM too. Probably only cost you an extra 1$ anyway. What is printed on U1?
                  • ant3202
                    • Jun 2006
                    • 275
                    • Singapore
                    Re: Altec MX6021
                    Hi CapLeaker
                    U1 is behind... i suspect it is blown too.
                    cannot see any wording on it like
                    Using a magnifying glass....
                    First Row: 03 510
                    Second Row: PA TM
                    • ant3202
                      • Jun 2006
                      • 275
                      • Singapore
                      Re: Altec MX6021
                      thanks for the tips....... light bulb trick is good.....pardon me as im still learning, directly replace the fuse with a light bulb to test in this case?
                      • ant3202
                        • Jun 2006
                        • 275
                        • Singapore
                        Re: Altec MX6021
                        Some Component lists....
                        • Behemot
                          • 4845
                          • CZ
                          Re: Altec MX6021
                          You can rewire old lamp or just reconnect the socket to a power cord so it is in series with the device.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8155
                            Re: Altec MX6021
                            I guess we are going to have a problem identifying / replacing U1. Maybe have to gamble on it still being good. I guess fuse F1 is blown too? also check those 3 pink resistors inside the heat shrink tubing.
                            • ant3202
                              • Jun 2006
                              • 275
                              • Singapore
                              Re: Altec MX6021
                              Alright, I will try.
                              Yep, the F1 has been blown out.
                              those resistors, four big ones..... i gotta take apart to check.
                              • zerbino
                                • 11
                                • Russian Federation
                                Re: Altec MX6021
                                Hello, ant3202. Did you fix your breakage?
                                I have the same problem. Even made new post on avsforum, but there is now answers.
                                Here is copy/paste.
                                I really need help with repairing my Altec Lansing MX6021. It has broken power supply. I have only basic knowledge of physics, a ability to solder, fan, a multimeter and the ability to buy components. After disassembling, I saw that the resistors were burnt (I managed to examine their 1R0 nominal), the capacitor that lost capacitance (a new 68uF 686 16x32mm 450V one was ordered), the punched out fuse T1.6A 1.6A 250V 382 (bought), and it looks like nothing more.
                                Yesterday I replaced all this and decided to connect without assembling. There was a BIG BADABUM! Resistors burned out again, the fuse too. The capacitor seems to be ok. It's good that I have spare parts and I can change them again. BUT. I'm a bad circuit engineer. But as I heard, maybe someone else has not been able to give proper power. I suggested that this is a power transistor. I tested it with a transistor tester . He showed resistance between the base 5 and 1 ohm. Apparently it's broken. Yesterday I ordered it. Now I'm afraid that I did not miss something else. But I do not know what and how to test. I searched the information on the Internet, but found nothing. No scheme, nothing. Only today I accidentally saw this topic and the person with the same problem as me https://www.badcaps.net/forum/showthread.php?t=60238 But the topic there is not closed. It seems that the person decided it. Could you express your opinion on what else and how to check? Or after the replacement of the transistor SPA08N80C3 (near R15) everything should be fine?
                                I really do not want to throw this stereo system out. This is a great system! You will not believe it, but I am satisfied with it just like the Elac FS 249.
                                Sorry for my bad English. I used google translate and my basic knowledge of English.
                                Best Regards.
                                Can You give any additional information about?
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  Re: Altec MX6021
                                  Hi zerbino,
                                  the first thing you should do is the incandescent light bulb trick, like this:
                                  https://www.badcaps.net/forum/showpo...4&postcount=70
                                  This will prevent your new parts from blowing up again when you have to test the power supply.
                                  Start by testing all parts on the primary with your multimeter. Any diodes or transistors that show low resistance (less than 300 Ohms) between any of their pins should be removed and checked out of circuit. Resistors should read same as labeled value or lower in circuit (higher resistance that what is printed on them is not good if above their tolerance).
                                  Last but not least, post pictures of your power supply board, even if it looks fairly identical to what ant3202 posted here. After all, there may be small difference in your power supply from his, so it helps for us to see what you are seeing to help you better.
                                  • zerbino
                                    • 11
                                    Re: Altec MX6021
                                    Thank You very much for answer. when i'll get transistor, i 'll you lamp for insurance. If it will failed again, i'll let forum know. If I'll fix it, i will let know too.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      Re: Altec MX6021
                                      If the transistor is shorted there is a big chance that the controller chip is also dead. Just something to keep in mind.
                                      A working TV? How boring!
                                      • zerbino
                                        • 11
                                        Re: Altec MX6021
                                        Hello all!
                                        Recently i get transistor to change broken SPP08N80C3. As i understand transistor not original, but tested with transistor tester and soldered on pcb. Remember your advice to me i connected 100W lamp and googled how it works). As i understand, lamp must blink and shut down after power on BUT it always glows, so as i understand bord is short short-circuited. Only one ship U1 (1351D PCOI connected 1,3,4,5,7,8) not tested yet and i dont understand how can i test it. Tested only that pins do not call each other and 4 pin is GROUND. And test tested resistors (2W? 15mm length), its 157, 158, 1770, 1781 Ohms
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • brightest_z
                                          Hot Air Blew Away Resistors Near Bios
                                          by brightest_z
                                          Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                                          Does anyone with more knowledge, and experience than I, know if this is the case?
                                          12-11-2024, 08:34 PM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • jinu_j
                                          LED driver circuit. Burnt Resistors
                                          by jinu_j
                                          Hi Folks
                                          This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                                          Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                                          But i have some queries on this circuit
                                          1. The resistors that burnt to crisp...
                                          08-26-2020, 01:24 AM
                                        • magneh
                                          Behringer Eurolive B205D repair - help identifying transistor
                                          by magneh
                                          Hello
                                          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
                                          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
                                          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
                                          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
                                          Still, I need to replace this transistor....
                                          06-18-2025, 02:34 AM
