Good day folks. Got this Philips 32PHH4100 LED TV which has power supply issues. When the chap brought it in, the red power LED would blink rapidly, indicating the set is trying to come on but can't. I took it apart, took some measurements and immediately noticed the 12v output dropping to around 7v when the main board was connected to the power supply. It is an "always on" supply, meaning it doesn't have a STBY voltage - the 12v rail IS the standby voltage as well. To test this theory, I took a computer PSU, connected its 12v output to the appropriate pins on the main board and powered the set on: even though there was no backlight, the TV was definitely on and working fine, as I could see stuff moving on screen with the "flashlight method".
Back on the faulty power board, it is a 715G6550. I couldn't find a schematic, but it's not really necessary at this point, since no components are completely blown apart. When it's first plugged in, the 12v output slowly rises, until it reaches around 11.6v, which is OK, but the turn-on "curve" is WAY too slow: it starts off at 5v and takes about 5 seconds to reach 11v, which is not alright. When you load this output, the voltage goes down to 7v and then slowly rises again upon removal of the load. What I have tried so far to no avail:
-replacing the caps on the 12v output (but not the LED driver too, which runs off a separate tap on the switching transformer)
-replacing the optocoupler, thinking perhaps it doesn't provide correct feedback to the PWM IC
-replacing the 2 small caps on the Vcc pin of the PWM IC in the primary
Could this be a bad PWM Ic, bad MOSFET, bad rectifier diodes ? Suggestions are highly appreciated
