Toshiba 23l1350u standby voltage present, won't power up
  • AcGeorgiegirl
    • Jun 2013
    • 203
    There's no standby led lighting up. Without the main board connected, I get 5.14 on the 3 pins labeled for 5v for what I assume is standby(con isn't labeled as such...see pics). With main board connected, I get the following pin voltages:
    1 gnd
    2 5vcc 5.21
    3 5vcc 5.21
    4 gnd
    5 5vcc 5.21
    6 13vcc 12.71
    7 13vcc_AUD 12.71
    8 gnd
    9 PWON 3.03
    10 ACD 3.46
    11 gnd
    12 BLON 0
    13 DIM 0
    I realize that pins 6 & 7 are supposed to be 13v. I don't know what pins 9 & 10 should be, nor 12 & 13. Also, when checking diodes and fuses, I found that D210A on the Secondary side has reading both ways (208 and 1342) I keep running into this, and am wondering if this is normal on the secondary side, or not? I usually don't take the diodes out of circuit when I test them...maybe this is why I get this?
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Toshiba 23l1350u standby voltage present, won't power up
    I would say that the backlight on is missing (around 3V) and also Dim voltage
      Originally posted by dick_barton
      i would say that the backlight on is missing (around 3v) and also dim voltage
      +1
      12 blon 0
      13 dim 0
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        BLon and the DIM signal are coming from the main board.
        • koka0011
          • Apr 2013
          • 30
          • Sri Lanka
          try replacing the 1117-ADJ regulator.it is on the main board.located near lvds connector.
          • koka0011
            • Apr 2013
            • 30
            • Sri Lanka
            i have highlighted the regulator
            • AcGeorgiegirl
              • Jun 2013
              • 203
              Ok, I'll start with the regulator. Would it be smart to first test it, before ordering a replacement?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                A check first would be useful.
                • AcGeorgiegirl
                  • Jun 2013
                  • 203
                  I get an input voltage of 5.21 and an output of 3.25.
                  • AcGeorgiegirl
                    • Jun 2013
                    • 203
                    I've looked for the label on this regulator, and it doesn't have what you've indicated...does this matter? The number code on the second line reads "17-33"...with possibly being "17-331". The top line isn't readable except the last bit of "3BC". I am wanting to make sure I have the correct specs for seeing if the output I get is good.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      maybe a IRU1117-33 in a 5V to 3.3V regulator so if it is it working ok
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5085
                        • New Zealand
                        Are there any other regulators? I see some larger parts which could be higher current regulators. (From stock photos, seem to be U11, U13, U15)
                        There are also a few switching regulators, it seems.
                        Can we have a better photo of the mainboard?
                        -David VanHorn
                        • AcGeorgiegirl
                          • Jun 2013
                          • 203
                          I couldn't get in close enough for clarity, but here's some pics I hope will help.
                          • AcGeorgiegirl
                            • Jun 2013
                            • 203
                            The three regulators you've indicated are correct...they read:
                            U11 no input voltage
                            U13 no input voltage
                            U15 input 4 v
                            output 2 v
                            *this one, at first was reading 3v as input, but a couple of minutes later was 4
                            • AcGeorgiegirl
                              • Jun 2013
                              • 203
                              I am understanding this looks like a main board issue, right? Any suggestions as to what I can test for failure, or do you guys suggest just replacing the board? I'd much prefer learning how to repair what's wrong, which is what you guys are so good at helping with!
                                Yes, the main board problem, the key is to get the schematic diagram of the main board to do the component level troubleshooting of the complex main board.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  What's the resistance between Pin 12 (BLON) and Pin 1 (GND) at the power supply connector and the equivalent positions from the main board?
                                  • AcGeorgiegirl
                                    • Jun 2013
                                    • 203
                                    Ok. Can you tell me, on the board, where the PN is, so I can start searching? I see two white labels that might be it, as well as what's written directly on the board at the far left top.
                                    • AcGeorgiegirl
                                      • Jun 2013
                                      • 203
                                      I'm not sure what I would put my DMM on as far as mode...would I use Ohm's mode and then set it to range at 200(the lowest setting)?
                                      ...and should the power be plugged in and turned on, etc?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        no power on as testing resistance then test between pin 12 and pin 1 and yes ohms mode
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • x_orange90_x
                                          Samsung UN55KU6300F no standby voltage
                                          by x_orange90_x
                                          I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                          Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                          05-21-2025, 09:59 PM
                                        • brock-s
                                          Asus GL503GE 3.3 standby voltage low
                                          by brock-s
                                          An Asus GL503GE laptop arrived that had had a screw dropped on the motherboard while the battery was connected. This resulted in a physical damage to the 3.3v / 5v voltage controller RT6575DGQW (pu28 on schematic, page 40). Additionally, the trace to pin 12 (VIN 19v supply) was burnt.
                                          Replaced the RT6575DGQW with a new one, repaired the damaged trace. Only getting 0.7V instead of the expected 3.3v standby voltage (3V_S5 on schematic).
                                          Replaced the AON7408 PQ60 mosfet from a donor board as resistance was low on the gate (I did not write this value down, as I optimistically...
                                          07-13-2023, 03:43 PM
                                          Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                          09-06-2024, 05:30 AM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
