Me wrong or ShopJimmy?
  • capwizard
    • Jun 2016
    • 1991
    Me wrong or ShopJimmy? Does anyone know the answer??
    LG 42LE5300 my tested result shows : 19 X 12, Total LEDs = 228 LEDs , but ShopJimmy's picture shows 52 X 4, total LEDs = 208 LEDs
    Voltage needs wait 1 min. = 105.7v, one LED votage = 5.54v
    How many LEDs in an array = 19 LEDs, How many arrays = 12, Total LEDs = 228 LEDs
    PS: This edge screen has twins LEDs, all the led arrays worked OK, so I won't open the screen to find out the answer!
    LG 42LE5300 service manual:
    https://www.electronica-pt.com/esque...artdown/24431/
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: Me wrong or ShopJimmy?
    no idea sorry .
    p.s what is that board for on your meter ?
    • capwizard
      • Jun 2016
      • 1991
      Poormans LED TV Backlight Tester.
      https://www.badcaps.net/forum/showthread.php?t=59136
      • petehall347
        • Jan 2015
        • 4450
        • United Kingdom
        looks good until you go and touch it whilst on .
        • capwizard
          • Jun 2016
          • 1991
          Electroshock therapy treatment help poorman be rich and add some more memory.
          • petehall347
            • Jan 2015
            • 4450
            • United Kingdom
            these damn switch-mode supplies give me a shock if i get nearer than 5 inches away with my hand .
            turn them led lights down and forget how many are in there . pain in the arse stripping panels to change them .
              5.54V for Dual -LED, you are getting that may be due to you are not running at close to max If so the calculation comes out wrong?
              I.E. Look at Vf VS If chart.
              https://cdn.badcaps-static.com/pdfs/...4398d8add2.pdf
              • capwizard
                • Jun 2016
                • 1991
                "you are getting that may be due to you are not running at close to max If so the calculation comes out wrong?"
                Ive set Tester current at 6.8 mA for safety reason, normally single LED should be at 20 mA -30 mA, but total LEDs test current also low, calculate results that are aiming for unknown values, the percent error formula turnout to be pretty accurate.
                "Not running at close to max" that did bother me, then I found out testing at 5ma, 10ma, 15ma, and 20ma the result almost the same, and can accurately predict the number of LEDs, but not the total power consumption. Thank you for your response.
                  "normally single LED should be at 20 mA -30 mA" Not these White backlights LEDs they run at 200~400mA.
                  Lower current = lower Vf so your cal for the qty of LEDs will be off.
                  • capwizard
                    • Jun 2016
                    • 1991
                    You're the Best! it's hard to believe that TV industry put up the current so high to get what they want, every time I saw the spec. I thought that was A misprint! In my case, LEDs current is at 55mA.
                    From ShopJimmy: base on AUO's panel T420HW07 V.1 it is 208 LEDs. He is right!.....
                    ShopJimmy's picture shows 52 X 4, total LEDs = 208 LEDs is for Panel Sticker Number: T420HW07 V.1 LG/Vizio T420HW07 V.1 LED Strips - 4 Strips
                    From my calculation: base on LG's panel LC420EUH it is 228 LEDs. im right!.....
                    Voltage = 105.7v, one LED voltage = 5.54v, how many LEDs in an array = 19 LEDs, How many arrays = 12, Total LEDs = 228 LEDs
                    PS: My LG 42LE5300 TV LED screen till unopened..... WHY! they use different brand of panels? Because they sale so many TVs all over the world , always out of the supply.
                    Reference:
                    LG's panel LC420EUH
                    From ShopJimmy:
                    Important Message: PLEASE make sure the LED panel in your TV matches the information in this listing before ordering. DO NOT simply order by model number, as this may result in receiving LED strips that are incompatible with your TV.
                      If you look at the chart (LC420) when the LED string are driven at 55mA (TYP.), the Vf is 117.8V (TYP.).
                      The T420 is driven at 120mA (typ), Vf for one string is 88.4V (TYP.)
                      • capwizard
                        • Jun 2016
                        • 1991
                        You are so smart, I saw that and i talk to myself don't waste my time to mention it, nobody will pay attention to it.......
                        • Pipolups
                          Corsair K70 LUX RGB dying LEDs
                          by Pipolups
                          Hi there !
                          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                          10-08-2024, 11:58 AM
                        • cueballsi
                          e701i-a3 LEDs pulse after removing drivers, and also using wrong power cord
                          by cueballsi
                          Well need some help guys... I removed the drivers and put it all together have some lines.. I think I need to clean the cables and put them back. BUT I noticed the following:
                          - I used a OO power cable instead of the [ ]O looking power cable to power up the tv.
                          - The LEDs seem to brighten and darken and brighten like a very slow strobe.
                          Did I mess up the board with the power cable mess up? I switched to the [ ]O type and still slowly pulses....
                          what would make the LEDs do this?
                          any help would be appreciated. What should I test?...
                          10-02-2020, 05:44 PM
                        • pni
                          Backlight panel diffuser melt by backlight leds broken
                          by pni
                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                          10-12-2025, 12:08 AM
                        • tmhobadcap
                          TCL 65S403 Backlight LED Question
                          by tmhobadcap
                          I got the TV from a friend. He claims that no image but sound from the TV.
                          I confirmed that when shine a flashlight on to the screen, I can see the image. And this should be backlight problem.
                          I open up the TV and found a few leds failed. And now I am ordering a new set of backlight strips for it.
                          But there is something that I do not understand when checking the leds. I do not have an led tester. I only use a bench power supply. I first set the voltage to 3V and current to 10mA. I could not light up the led until I increase the voltage to 12V. I understand most...
                          05-25-2025, 11:03 AM
                        • VitalComputing
                          Replacing Mode Indicator LEDs
                          by VitalComputing
                          I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                          I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                          I thought I could just put a resistor...
                          09-17-2023, 04:43 PM
