LG 50PX990-ZA Vertical Black Lines
  • Scrim
    • Jun 2016
    • 9
    • England
    I have an LG 50PX990-ZA plasma TV and a few months ago i noticed a single black line from top to bottom of the screen and then this week, this is now 3 individual black lines. I have attached pictures to help show the problem. They're not horrendous but once you know they're there they annoy you!!
    Any help or advice would be great.
  • Scrim
    • Jun 2016
    • 9
    • England
    Re: LG 50PX990-ZA Verticle Black Lines
    Vertical not verticle! doh >_<
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: LG 50PX990-ZA Vertical Black Lines
      Panel failure not fixable sorry.
      • Scrim
        • Jun 2016
        • 9
        • England
        Thought that'd be the case damn.
        Will it only get worse then?
          It looks like one particular COF chip is failing, so yes unfortunately it is only likely to get worse. Although if it's any consolation it'll likely stay around that area.
          • Scrim
            • Jun 2016
            • 9
            • England
            Haha not particularly! Thanks for the quick response guys...
            Anyone want an LG 50PX990-ZA with 2 pairs of 3D glasses? >_<
            • comptek
              • Aug 2013
              • 606
              • uk
              i fixed one before by heating up the tab it was an lg plasma too used a reflow heat gun just kept going back and forth and the line went
              worth a shot nothing to lose
              • Scrim
                • Jun 2016
                • 9
                • England
                Definitely nothing to lose. Can you pin point me in the direction of where I need to apply heat?
                With the other guys saying it's a failing chip / panel I assumed it's irreparable?
                  Essentially there's a bunch of chips bonded along the bottom of the panel - they're the address drivers.
                  If you can get the front bezel off the TV while it's on the stand you might be able to do this. *Might.*
                  Generally I'd say these are not repairable when they fail but I have heard of people heat gunning them and getting a few months out of them.
                  • Scrim
                    • Jun 2016
                    • 9
                    • England
                    Ah ok. I won't bother then I guess. Bought a new TV now anyway so i'll just give this one away.
                    Thanks for your help guys.
                    • Firentiosi
                      1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                      by Firentiosi
                      Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                      The issues are as follows: the...
                      11-27-2024, 12:33 AM
                    • Stanley1843
                      Screen Display Vertical Multicolor Lines
                      by Stanley1843
                      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                      06-29-2024, 11:54 AM
                    • Ancient1
                      Strange LG TV issue : Image vertical lines in black screen
                      by Ancient1
                      Hi
                      Asking for a friend.
                      I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                      but here its the opposite !
                      TV has new T-con = same issue
                      A missing panel voltage would have global effect
                      So , what should one do ? how can I find where the fault is ?
                      Thanks !...
                      02-05-2025, 03:37 PM
                    • syedshueeb@gmail.com
                      Black spot and vertical lines on Sony KD-55x9300C
                      by syedshueeb@gmail.com
                      Can experts please share their opinion on this issue where i have a black spot and vertical lines all over the screen.
                      Is this fixable or needs a new panel?...
                      03-31-2023, 01:29 AM
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      Sadly it has vertical lines at the left and one line in the middle-right.
                      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                      I have factory resetted the TV as well but also with no luck.
                      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                      A similar issue has been posted as well but also with no actual response ...
                      Yesterday, 04:19 AM
