Telefunken TS32D875L5, panel problem Sharp LK315T3LA31, lower third black
  • Chungalin
    • Jul 2014
    • 422
    • Spain
    This TV clearly has a panel problem, but I wonder if it's worth replacing T-CON or not. I think not, because it has 3 gate drivers at the right, and darkened strip is exactly one third of screen height and it entirely belongs to the lower gate driver. I've touched around the flex bond and nothing improves.
    I've reseated both FFC from T-CON to panel to no avail. Disconnecting one of them produces half-screen to black, and the lower third stripe doesn't change.
    What do you think? Thumb up or thumb down?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Telefunken TS32D875L5, panel problem Sharp LK315T3LA31, lower third black
    Bad panel, dont bother spending a penny on it. These integrate the horizontal drivers into the lcd glass which is very unreliable and they fail exactly like this.
    • Diah
      • Feb 2013
      • 6363
      its T-COn fault, you need to consider only on the cost. Panel fault never saw in such way.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I beg to differ ! Please look on the forum for "Lta320Ap06" you will find many other of these panels failed in similar ways. Tcon wont cause that type of failure !
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Here is just a few before you start contradicting me, its not a tcon fault ! The integrated transistors inside the lcd gladd for the horizontal rows fail and any image below the failed one will be totally messed up like this.
          https://www.badcaps.net/forum/showth...ght=Lta320ap06
          • Diah
            • Feb 2013
            • 6363
            i am not that bad person whom spent time here trying help other .... to be rude to others,,this urs link. read last post whom try to measure t-con ans what happen..
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              I didn't say you were bad though just said before you say other wise. The display drivers get thrown off by the failed parts in the panel which is why the display starts going green etc.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Im not here to argue either just saying that this is 100% panel fault IMO I have seen alot of these Samsung panels fail in the same way and its not fixable.
                • Diah
                  • Feb 2013
                  • 6363
                  Any way, there are no panel over all first and second and the last generation curve one, an short of it can effect on drivers, A Board or T-CONs however ovr all sets there fuse for panel VCC. vertical issue always panel. horizontal issue 90% drivers ( T-CON ).
                  i my wrong but i do wish this TV under my hand one day in this fault
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Thats not true, look up for the Vizio 70" panel repair, failed tab bond driver was causing the Tcon to go mental. Trust me this is a panel fault. I would not suggest you buy a Tcon and waste money at all. Wait till aome other chime in like Tom and Bud.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      These panels integrate the horri drivers into the glass in small address transistor packages you can actually see them inside the glass in small packages. They are in series so if one goes all below it will fail I have seen so many of these samsung panels fail in the same way. Its not fixable period.
                      • Diah
                        • Feb 2013
                        • 6363
                        up 60 as well 70" panel are total different from 55 and below.
                        this is only 31.5
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Yes but its the same lol failed Tab bond drivers no matter if they or horri or vert can cause the Tcon and the rest of the display to have an issue.
                          • Diah
                            • Feb 2013
                            • 6363
                            okay you are right... keep on to learn. stooping from me
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ok, Im not being an ass just trying to stop someone from spending money on something unfixable. You wont know until you get one, I have serviced at least 20 Samsung Lcd panels same fault, not fixable.
                              • Diah
                                • Feb 2013
                                • 6363
                                sure you do, i appreciated it as well yours repair LED Backlight video.. keep on. lol
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Lol no worries, its good to have a debate though about something like this ! Also cheers
                                  • Chungalin
                                    • Jul 2014
                                    • 422
                                    • Spain
                                    Just to clarify, this panel is not a Samsung LTA320AP06, but a Sharp LK315T3LA31. Perhaps you meant that they share the same architecture?
                                    I've added a pic of one of the three horizontal drivers bonded to the right side of the panel.
                                      SONY T-CON_training_manual.
                                      same principles applied.
                                      • Chungalin
                                        • Jul 2014
                                        • 422
                                        • Spain
                                        One thing I don’t understand is how T-CON communicates with lateral Gate drivers. There’s no cable from any of them to T-CON or top PCB. Gate drivers are just bond to the glass and that’s all.
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Andrew453
                                          Crestron TPS-2000L with Sharp LQ5AW136R panel
                                          by Andrew453
                                          I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
                                          The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
                                          Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other...
                                          01-28-2023, 02:54 PM
                                        • howardc64
                                          LG 49UJ6500 LCD panel lighter band that goes away
                                          by howardc64
                                          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                                          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                                          02-19-2023, 12:13 AM
                                        • triplefour
                                          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                                          by triplefour
                                          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                                          tcon is built into mainboard.
                                          Only one cable goes to panel boards.
                                          there is a cable from one panel board to the other that links them.
                                          cost cutting measure that results in us having harder time to diagnose.
                                          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                                          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                                          07-28-2022, 07:59 PM
                                        • Storyteller12
                                          QN55Q60R Service Menu Panel Help
                                          by Storyteller12
                                          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
                                          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
                                          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
                                          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
                                          01-13-2024, 01:57 PM
