Telefunken TS32D875L5, panel problem Sharp LK315T3LA31, lower third black
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Telefunken TS32D875L5, panel problem Sharp LK315T3LA31, lower third black
    Connections inside the glass.
    • michael dranfield
      • Jan 2016
      • 232
      • England
      Originally posted by Chungalin
      One thing I don't understand is how T-CON communicates with lateral Gate drivers. There's no cable from any of them to T-CON or top PCB. Gate drivers are just bond to the glass and that's all.
      Conductive tracks are printed onto the glass surface you can see them with a magnifying glass or microscope.
      • Chungalin
        • Jul 2014
        • 423
        • Spain
        Well, I just wanted to report that another technician lent me a T-CON for this panel, exactly the same numbers and...
        the winner is...
        Reecey!!
        It does exactly the same effect. Replacement T-CON even included both FFC to the panel.
        I'm gonna dismiss this one, unless Diah has something to add. O course one could say that this second T-CON has the same failure than the first.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          As I suspected I have seen ALOT of them and tried lots to fix them. Pure Samsung trash. Thanks for the update
          • advant
            by advant
            02-03-2020, 12:25 AM
          • Andrew453
            Crestron TPS-2000L with Sharp LQ5AW136R panel
            by Andrew453
            I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
            The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
            Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other...
            01-28-2023, 02:54 PM
          • howardc64
            LG 49UJ6500 LCD panel lighter band that goes away
            by howardc64
            49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
            Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
            02-19-2023, 12:13 AM
          • triplefour
            SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
            by triplefour
            TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
            tcon is built into mainboard.
            Only one cable goes to panel boards.
            there is a cable from one panel board to the other that links them.
            cost cutting measure that results in us having harder time to diagnose.
            removing the link to the second panel board allows TV to stay on with stable backlight but no image.
            used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
            07-28-2022, 07:59 PM
          • Storyteller12
            QN55Q60R Service Menu Panel Help
            by Storyteller12
            I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
            I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
            I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
            the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
            01-13-2024, 01:57 PM
