Samsung UN60EH6003 Screen Blacks out after 2-3 Min
  • Treydogg77
    Treydogg77
    • Mar 2013
    • 99
    • US
    I'm working on a Samsung UN60EH6003 that I replaced every board in the unit about a month ago, because the unit would stay on for about 3-4 then blackout. I ran off and on for about 2 days and it worked fine with no problems. I took it over to friends house, he hooked it up and it's back doing the same crap all over again. Comes on for 2-3 min then the screen goes out but still has sound. I tried every input on the unit and it continued to black out with no change. Any ideas to what's causing this?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung UN60EH6003 Screen Blacks out after 2-3 Min
    Could be an overheating led or driver circuit. When it goes out, take a flashlight and look into the screen to see if there is still video.
    • Treydogg77
      Treydogg77
      • Mar 2013
      • 99
      • US
      Aight I will check that and let you know!
      • Treydogg77
        Treydogg77
        • Mar 2013
        • 99
        • US
        Okay I have confirmed the back is working when the image disappears. It slowly starts fading then the image starts to freeze then goes into a hologram look till the picture is totally black. Is there a way to post a video of what it's doing on here?
        • Treydogg77
          Treydogg77
          • Mar 2013
          • 99
          • US
          Here is a picture of it during the fade
          http://imgur.com/a/FPVLk
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8188
            Either you got a t-con or a panel fault.
            • jjanssen7
              • Nov 2012
              • 252
              I just repaired this exact model with similar but not the same symptoms. I had just one LED that was shorted. Once I replaced the burnt out LED, I also had to replace some (current limiting?) resistors on the back of my power supply. (three 100u wired in parallel I believe).
              Long story short, one LED overheating can take out the whole backlighting system. I have seen LEDs that work/then fail/then work again depending on heat cycle.
              • jjanssen7
                • Nov 2012
                • 252
                But now seeing the picture I agree with Cap Leaker that your panel or T-Conn is failing.
                As a last resort, try disconnecting one side of the T-Conn Ribbon and running the TV. If theTV stays on, then your problem is failed/failing TAB IC on the same side as the side of the screen that was disconnected.
                • Treydogg77
                  Treydogg77
                  • Mar 2013
                  • 99
                  • US
                  Thanks Capleaker & JJanssen! I guess I should try the ribbon cable test first right?
                  • jjanssen7
                    • Nov 2012
                    • 252
                    Yup, should run normal on one side and have some sort of screen garble/distortion/shutdown when connected to the other side.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      I know this sounds weird but if that's the case take a small piece of scotch tape and start covering up about 10 pins in on the bad side from the outside of the ribbon cable. This would Be the side farthest away from the other cable you still have connected . One of these pins hampers its ability to stay on because of a short in the panel. However it gets its data from the other side so shutting down this side will keep the other side keeping data to the whole panel.
                      Scotch tape must be no longer than 2 pins in width. Move the Scotch tape around on the cable and keep reconnecting and disconnecting until you get a picture And then see if it cuts out still. In some configurations where you have the Scotch tape lying across some pins the panel may look disoriented and not right because of data that needs to get to that side of the panel. But once you find the right pin that is shutting the panel down in the panel looks good when you put the tape on it watch it for a little bit and see if it kicks out still. If you're confused I'll post a picture of what I'm talking about
                      • brucetv
                        • May 2015
                        • 281
                        • united states
                        I get a lot of these in and see a lot of problems with the T-Con board's part number BN95-00628C. I replace them with part number BN95-00944B because they have a lower failure rate. I keep one on hand in case the repair kit that ShopJimmy.com offers for less than $20 does not work out. It's one IC and two capacitors if you have good soldering skills. The T-cons are expensive to buy so try the repair kit first. 95% of the time that will fix the same problem your having.
                        • Chrissygizmo
                          by Chrissygizmo
                          02-10-2025, 12:33 AM
                        • Chrissygizmo
                          samsung galaxy ao2s very temperamental after screen replaced
                          by Chrissygizmo
                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                          Ive eventually managed to get it on and working but it's very temperamental...
                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                          05-26-2024, 12:05 AM
                        • JunkmanJimbo
                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                          by JunkmanJimbo
                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                          Please help. Thanks in advance!
                          08-12-2025, 11:45 AM
                        • Kiberge
                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                          by Kiberge
                          HI guys!
                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                          04-22-2024, 11:28 AM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
