Panasonic TCP50G20 with 10 blink error
  • SpinMaster12
    • Jan 2016
    • 5
    • Usa
    I have a Panasonic TCP50G20 with the 10 blink error.
    I went through a long diagnostic call to confirm it was a bad SC
    Board. So I bought a new SC board and installed it.
    When powered it up, it worked correctly for five minutes, but the entire time, there was a loud buzzing noise from the SC Board. Then there was a very bright and loud spark from some where on the top left of the SC board and it stopped working.
    I thought it was another bad SC Board, so I found another one and just put it in.
    BUT when I powered it up, I heard the loud buzzing sound again. I quickly pulled out the power cord before anything else could happen. I don't want to kill another of these hard to find SC boards.
    I am guessing there is something, maybe in the POWER Board that is killing the SC board.
    How do I test the power board?
    Has anyone else had this issue?
    This is now a 3 month long project and I would be very grateful for Any help.
    Thanks!
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Panasonic TCP50G20 with 10 blink error
    maybe best keeping this in one thread as your also asking in this one
    https://www.badcaps.net/forum/showthread.php?t=49434
      I moved this out from Samsung LED thread. If it's not needed I'll delete it.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
        by sam_sam_sam
        I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
        This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
        After all of...
        07-13-2024, 08:14 PM
      • canadaboy25
        Panasonic TC-P54VT25 No image. A or D board?
        by canadaboy25
        I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
        The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
        I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
        01-17-2021, 01:06 AM
      • tiku
        Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
        by tiku
        Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
        I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
        09-05-2021, 05:02 AM
