Change old low HDD to a CF card?
  • trodas
    • Jan 2006
    • 770
    • Czech republic
    Segate 13G ST313021A on Pentium 90 @ 125MHz:
    Average - 6.4MB/sec - now this is SPEEED! :p
    I wonder, if anyone have in operation slower HDD
    Therefore I wonder, if someone have a experience with replacing such SLOOOW HDDs with PATA to CF adapter and CF card(s)? The latest models promise very fast speeds - 160MB/sec is quite above PATA possibilities:
    SanDIsk Extreme PRO 32G CF card
    ...and since the adapters are just wires, connecting the CF card to PATA interface (CF cards work on same PATA interface!) and only in best cases, you can choose the voltage (3.3V or 5V) and you get the power and activity lights:
    DeLock 91620 PATA to CF
    ...then there should not be any problem of using CF cards as old PATA HDD replacement(s). Only problem I hear, that there should be changed bit on the card somewhere, that change the device type from removable to fixed. Then it should act as normal HardDriveDevice.
    But maybe I missed something...? Do anyone have experience with this? Could someone share tips, software for the change (from removable to fixed) and experience in general?
    "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
    "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
    • 31063
    Re: Change old low HDD to a CF card?
    what your talking about is down to the wiring on the adaptor.
    my notes have this:
    solder a link between pins 34 and 40 it runs at full speed (UltraDMA6 133Mbytes/s)
    however, i cant remember if those are the CF pins or the IDE pins or if it's for a 40pin or 44pin interface!
    • RJARRRPCGP
      • Jul 2004
      • 6304
      160 MB/s rating is bullshit on a PATA interface, just like an Adaptec 29160 SCSI card on a regular PCI slot. Can't get more than 133 MB/s.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • Compgeke
        • Feb 2014
        • 524
        Never had issues throwing a CF card in as an IDE replacement. No need to do anything about removable, especially on something that old.
        I've done IDE CF replacements in everything from 386s to Powermac 6400s and no issues at all.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          That ST313021A is seriously bottlenecked, you should be able to see the inner track speed reduction on this disk too... plus it's only showing up as 8GB? And your CPU usage is really high? Might get better throughput with a working DMA/UDMA system? You'll need it for the SSD anyway.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            CF to IDE works fine, but usually it's hard to get DMA mode working.
            And CF cards usually have really poor performance with small writes.
            Without doing some tweaks to the OS it's possible wear them out quite quickly.
            Fix the problems you have with the system first, because a CF is not going to be faster in any way.
            You don't have working DMA mode, probably stuck in some of the PIO modes.
            And the BIOS is limiting the drives capacity.
            • RJARRRPCGP
              • Jul 2004
              • 6304
              If in PIO mode, you usually see it crawl at 5 MB/s or less. Often because of bad connection.
              Arc A770 16 GB
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Slower...
                geode# hdparm -tT /dev/sda
                /dev/sda:
                Timing buffer-cache reads: 50 MB in 0.54 seconds = 93620 kB/s
                Timing buffered disk reads: 12 MB in 3.11 seconds = 3942 kB/s
                This disk is stuck in PIO4...
                I'm getting ready to re-purpose this machine...
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Uhh, and in what way do you feel that the average sequential read rate of 6MB/sec shows that it's not in PIO mode?!
                  It fits perfectly with PIO mode 2
                  https://en.wikipedia.org/wiki/Progra..._ATA_interface
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    I know when Windows goes to PIO mode, you're lucky to see 4 or 5 MB/s.
                    (That's despite the PIO spec is up to 16 MB/s, but never saw close to that on a system that downgraded to PIO mode.)
                    And TBH, would be worse on an NT-based Windows version than with Windows 98, because of the NT-family's Windows size alone.
                    OTOH, sometimes, you don't notice much if you forget to have DMA enabled on Windows 98. But, probably will notice some annoying lag.
                    Going to PIO on Windows 2000 and later would be torture.
                    (PIO is a red herring meaning you need to check the ATA connections.)
                    Likely screams cheap Chinese adapter!
                    And keep in mind that the max PIO specs usually mean burst rate of memory transfer, not the physical disk!
                    HD Tune also has a bad habit of reporting the wrong burst rate, sometimes lower than the physical disk speed!
                    Arc A770 16 GB
                      • 31063
                      check the bios settings - it may be forced.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        PIO mode will automatically kick in if the host detects read/write errors.
                        In XP you had to do to device manager and the IDE controller, find the one with the HDD then uninstall. It showed it was in PIO mode IIRC. When the PC was rebooted it re installs DMA correctly.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Who made the IDE controllers on this P5 machine? Hopefully it's not some buggy IDE chipset (at least I recall that in Linux the CMD640 and RZ1000 IDE controllers that were specially handled, perhaps with PIO modes because of hardware bugs) and the Windows drivers did the same thing.
                          Might want to try sticking in a PCI IDE controller that has known working DMA or UDMA if it has PCI slots. If this is a VLB IDE controller... SOL?
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Soo true! It's usually a bad ATA connection. And possibly can be caused by the CMOS being corrupted.
                            (Don't forget to clear the CMOS, change the CR-2032 battery, load optimal defaults and save changes to the CMOS.) (A.K.A. NVRAM)
                            Arc A770 16 GB
                              • 31063
                              if you get errors - replace the cable.
                              • fzabkar
                                • Mar 2009
                                • 772
                                I notice a strange discontinuity in the access time graph at the 30% capacity mark. I've never seen anything like that before.
                                The sinusoidal transfer rate is also weird. Could you rerun the benchmark using a short-stroke setting of 100MB and 1GB? This will expand the first part of the graph.
                                Are you overclocking the I/O bus to 37.5MHz? If so, then that may be the problem.
                                I'm guessing that your drive should have a maximum transfer rate of around 16 - 17MB/s at the outermost tracks.
                                Examine the UDMA_CRC_Error_Count SMART attribute under HD Tune's Health tab. That should tell us if there are interface errors, possibly due to cabling or overclocking.
                                Here is the SMART report for my own ST313021A:
                                http://www.users.on.net/~fzabkar/Smartctl/13gb.log
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  +1
                                  Arc A770 16 GB
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Agree with the others, before you do anything else, make sure you check "Use DMA" in device manager for that hard disk. Then reboot and see the difference.
                                    A working TV? How boring!
                                    • trodas
                                      • Jan 2006
                                      • 770
                                      • Czech republic
                                      Well, DMA is used, so there is no difference after reboot. It might, however, be related to PCI bus clock 41.7MHz (FSB 83MHz).
                                      Curiously as long, as the S3 Trio64 GFX card is used, it works stable (PCI latency 42). When swaped to ATI Rage XL, Win fail to boot and Win install fail to start.
                                      It looks working, tough, using the CF card adapter. Interesting...
                                      Anyway:
                                      Well, since SanDisk is not going to reply, I tried with the default 5V setting the DeLock adapter I mentioned earlier with very old, 0.5G CF card SanDisk SDCFH. It does support PIO 4, but no DMA and the speed is very slow:
                                      Tested on ASRock 775Dual-VSTA (P4, 3.8GHz WinXP, alligned). Also works (or more precisely, get detected) on the target Asus TXP4-X, so so far, so good. Except the speed, lol.
                                      Now the question is - what voltage to use for the SanDisk Extreme PRO 32G CF card and how to change the removable bit to fixed, so there will be the caching in Windows possible.
                                      Well... first the good news: I tried 3.3V first and the good news are, that SanDisk Extreme PRO 32G CF card works well with 3.3V settings! There are the result, enabling Smart a 32bit mode transfer did nothing, PATA133 is supported, but it is not going to get higher. Sadly. Still, I think that this is a reasonable speed improvement:
                                      (ASRock 775Dual-VSTA, 3.8GHz P4, 2G DDR2 Crucial Ballistix rams)
                                      However, now to bad news. The CF card is completely useless, unless someone tell me how to change the removable bit to fixed. Period. You cannot use the CF card for anything w/o that. Two examples:
                                      I use Mini Tool Partition Wizard Pro to setup the drive on boot CD - it let me allign the partitions - when creating second partition (one 4G FAT32 for OS, rest for DATA and NTFS = usable settings for waza), it tells me, that I cannot use that partition under Win, as Win recognize only ONE partition on removable device. I was like... that it is, I'm screwed.
                                      So for lolz, I started the install. It want well even at 83MHz FSB with the ATI Rage XL card (IDE HDD refused to work under such conditions, it worked only when S3 Trio64 is used as graphic card at that clock), but then I get to the drive partitioning and problems arise. D partition is invisible (unpartioned space, lol) and there is no way to create a new partition there, because on removable drive, only one partition is supprted. So OK, I try installing and using only the 4G partition... but no! It cannot install, because this partition is NOT compatible with WinXP.
                                      (additionally the card then refuse to work in any PC... formating in my Nikon Coolpix 4300 camera was the only way to fix the caard :-O )
                                      So basicaly, w/o the change from removable to fixed, any usage of any CF card as HDD replacement is doomed.
                                      I'm quite mad at SanDisk - they should rename themselves as ScamDisk, because they are selling not CF cards, but CF compatible *) cards, with the *) exception for the possibility to change removable to fixed bit. I believe, that there is open possibility to lawsuit against SanDisk and any other CF card producing company, that produces products, that does not meet the CF card specifications. Because this is false advertising and misleading labeling of product. This is not a CF card, period.
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        Anyway:
                                        That my friend is a Windows problem. This is a DRM implementation to go along with the Windows antipiracy crap. Linux, DOS, Unix, Solaris, BSD, OSX, Android all work from removable media. So will Windows CE/Mobile/RT It's the rest of the versions that shit themselves.
                                        Follow the white rabbit.
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                                          09-06-2024, 08:30 AM
                                        • FZG
                                          EVGA Nu Audio Sound Card - Not Working
                                          by FZG
                                          I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                                          The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                                          I found...
                                          03-07-2025, 11:44 AM
                                        • benwaterson
                                          Gigabyte Aorus 1080ti - card not initialising
                                          by benwaterson
                                          Hi there.
                                          Have searched various forums but haven't come across the exact issue I am having.
                                          Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                                          I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                                          Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                                          02-05-2022, 11:42 AM
                                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                                          what is wrong with your PC in just seconds. It saves you time and money.
                                          Our new and improved design...
                                          11-01-2024, 06:29 AM
