HDD issues.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    HDD issues.
    I have a 750 WD Blue drive here and it keeps power cycling. Every time I try to read data off the partition that contained the OS / user data, the drive disappears and after a few seconds, reappears. This makes it very difficult to use ddrescue.
    I've been able to successfully recovery the recovery partitions. My question is simple. Does anyone knows what causes a hard drive to power cycle like this? ddrescue reports bad sectors, but I think that might just be because when the drive powers down, it's marking it as bad. I haven't seen it mark any sectors bad while it's actually recovering data.
    Is this bad sectors on the drive or is it something with the heads or the PCB? I'm thinking it's probably not circuitry because I was successfully able tor recover 4 other partitions, 300MB, 600MB, 2.9GB and 20GB in size. I would think if it was because of a dying PCB, I wouldn't of been able to get that 20GB without having issues.
    ddrescue has recovered 5.6GB so far and the drive has power cycled about 20 times now.
    Thanks.
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: HDD issues.
    Oh, I always want to say I don't think it's anything with the heads, I don't hear any clicking noise or anything like that. Granted, the internals of a hard drive aren't really my strong suite here. Thanks.
    • ddscentral
      • Mar 2008
      • 151
      • Lithuania, EU
      Re: HDD issues.
      It could be anything: bad heads, bad sectors, dying electronics, etc. But does it really matter ?
      Knowing why the drive behaves like that most likely will not help you save the data.
      Try to save what you can and replace the drive.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Re: HDD issues.
        When you say power cycling on and off of the power drive. Are you saying the activation light goes out when you don't see the drive with the software? If this is the case then you could have a bad power connector to the drive. If it only happen in a read mode and not a write mode and it is just in one partition this could be a bad section of the disk. Do you have any test program on your computer that writes and read data to the hard disk. That should tell you the section of the disk you are having problems with. Use to be that one could could read and write to certain places on the disk to be able to tell which ones were bad. The program would not stop when it ran into the first bad section but would store it in memory and continue on. Some programs would remember the bad sections and not try to retrieve them. In this way some of the programs on the disk were recoverable and some programs were corrupt by the bad sectors. You could also retrieve bits of data from all good places on the disk. Then you would have to reverse engineer it to tell which part of the bad program needed to be fixed.
          • 31283
          Re: HDD issues.
          internal drive, or external?
          • Spork Schivago
            • Mar 2012
            • 4734
            Re: HDD issues.
            The hard drive completely looses power and then the power on the hard drive comes back, but this seems to only happen when I read (didn't try writing because the one partition I'm having trouble with was in hibernation mode and my Linux system makes me mount it read only because of this). I left the hard drive connected for over 24 hours, with no reads, and there where no problems. I'm not used to hard drives just turning off like this. It makes using a program like ddrescue a real pain in the ass. Every time the drive shuts down, ddrescue crashes, the drive disappears from /dev for a bit, and then reappears 10 seconds later or so. In X-Windows, it wants me to the type root's password to mount them. I tried setting up a udev rule to turn off USB auto-mount (I'm using a USB external hard drive enclosure) but it didn't work. This is what dmesg says:
            Code:
            [1998407.447046] usb 2-1: new high-speed USB device number 18 using ehci-pci
            [1998407.561993] usb 2-1: New USB device found, idVendor=152d, idProduct=2351
            [1998407.561999] usb 2-1: New USB device strings: Mfr=10, Product=11, SerialNumber=5
            [1998407.562024] usb 2-1: Product: USB/eSATA To SATA Bridge
            [1998407.562029] usb 2-1: Manufacturer: JMicron
            [1998407.562031] usb 2-1: SerialNumber: D21E428696FF
            [1998407.563805] usb-storage 2-1:1.0: USB Mass Storage device detected
            [1998407.567876] scsi21 : usb-storage 2-1:1.0
            [1998408.574153] scsi 21:0:0:0: Direct-Access   WDC WD75 00BPVT-80HXZT3    PQ: 0 ANSI: 2 CCS
            [1998408.574503] sd 21:0:0:0: Attached scsi generic sg3 type 0
            [1998408.805627] sd 21:0:0:0: [sdc] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
            [1998408.809765] sd 21:0:0:0: [sdc] Write Protect is off
            [1998408.809772] sd 21:0:0:0: [sdc] Mode Sense: 34 00 00 00
            [1998408.810756] sd 21:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
            [1998408.905788] sdc: sdc1 sdc2 sdc3 sdc4 sdc5 sdc6
            [1998408.912506] sd 21:0:0:0: [sdc] Attached SCSI disk
            [1998670.350965] sd 21:0:0:0: [sdc] Unhandled sense code
            [1998670.350973] sd 21:0:0:0: [sdc]
            [1998670.350977] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
            [1998670.350981] sd 21:0:0:0: [sdc]
            [1998670.350984] Sense Key : Medium Error [current]
            [1998670.350991] sd 21:0:0:0: [sdc]
            [1998670.350995] Add. Sense: Unrecovered read error
            [1998670.350999] sd 21:0:0:0: [sdc] CDB:
            [1998670.351028] Read(10): 28 00 00 d0 33 80 00 00 80 00
            [1998670.351055] end_request: critical medium error, dev sdc, sector 13644672
            [1998700.880045] usb 2-1: reset high-speed USB device number 18 using ehci-pci
            [1998701.350447] usb 2-1: device firmware changed
            [1998701.350490] usb 2-1: USB disconnect, device number 18
            [1998701.355400] scsi 21:0:0:0: rejecting I/O to offline device
            [1998701.355408] scsi 21:0:0:0: [sdc] killing request
            [1998701.355425] scsi 21:0:0:0: [sdc] Unhandled error code
            [1998701.355427] scsi 21:0:0:0: [sdc]
            [1998701.355429] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
            [1998701.355432] scsi 21:0:0:0: [sdc] CDB:
            [1998701.355434] Read(10): 28 00 00 d0 34 01 00 00 7f 00
            [1998701.355442] end_request: I/O error, dev sdc, sector 13644801
            [1998701.468035] usb 2-1: new high-speed USB device number 19 using ehci-pci
            [1998701.583068] usb 2-1: New USB device found, idVendor=152d, idProduct=2351
            [1998701.583073] usb 2-1: New USB device strings: Mfr=10, Product=11, SerialNumber=5
            [1998701.583076] usb 2-1: Product: USB/eSATA To SATA Bridge
            [1998701.583079] usb 2-1: Manufacturer: JMicron
            [1998701.583081] usb 2-1: SerialNumber: D21E428696FF
            [1998701.584040] usb-storage 2-1:1.0: USB Mass Storage device detected
            [1998701.593172] scsi22 : usb-storage 2-1:1.0
            [1998702.600231] scsi 22:0:0:0: Direct-Access   WDC WD75 00BPVT-80HXZT3    PQ: 0 ANSI: 2 CCS
            [1998702.604286] sd 22:0:0:0: Attached scsi generic sg3 type 0
            [1998702.831828] sd 22:0:0:0: [sdc] 1465149168 512-byte logical blocks: (750 GB/698 GiB)
            [1998702.834450] sd 22:0:0:0: [sdc] Write Protect is off
            [1998702.834456] sd 22:0:0:0: [sdc] Mode Sense: 34 00 00 00
            [1998702.835837] sd 22:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
            [1998702.929902] sdc: sdc1 sdc2 sdc3 sdc4 sdc5 sdc6
            [1998702.936577] sd 22:0:0:0: [sdc] Attached SCSI disk
            This kind of makes me think it is bad sectors on the drive. So essentially, there's no way to repair this, right? Even with a clean room and the proper tools, the platters would have to be replaced, correct? Even though we could use ddrescue to get data off the partition, something is so horribly wrong, when it try reading a bad sector, the drivers actually have to restart the device.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              Re: HDD issues.
              get it on an internal PSU bus. Your case may not be providing enough power by the looks of it. Also if you're using the USB bridge you cant send SMART commands beyond the necessary ones for normal operation.
              Follow the white rabbit.
              • Spork Schivago
                • Mar 2012
                • 4734
                Re: HDD issues.
                Yes, it does really matter. If it's something like a dying PCB, I might be able to replace the PCB. Depending on the drive, people have had varying degrees of success. Same with changing the heads. People have made portable clean rooms (and granted, this is recommended) and have successfully replaced parts inside the hard drive long enough to recover the data. I know what risks are involved. And it'd be something, if I could find out what was really causing the problem, I'd do just for the fun of it.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  Re: HDD issues.
                  Internal laptop SATA 3.0Gbps WD 750 GB hooked up to an external enclosure right now. I haven't tried hooking it up directly via the onboard SATA ports on my PC yet. I should probably do that before I tear the thing open. We can successfully read data from other partitions and I was able to successfully clone my wife's 500GB laptop hdd, so I know it's not the enclosure. Before that though, I also tried using E-SATA and tried another USB cable just to rule that out.
                  Any ideas STJ? dmesg kinda tells me why the drives resetting. It appears it finds a bad sector while trying to read and then for some reason, the driver actually restarts the drive. So I guess damage on the platters is looking more and more like the problem.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    Re: HDD issues.
                    yes, do that. Those USB laptop cases have sparse power. definitely not 1amp worth! Unless you are on USB3.
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      Re: HDD issues.
                      I cannot retrieve the S.M.A.R.T. data using 3rd party tools when it's running through a USB / eSATA to SATA bridge? I did not know this.
                      I questioned whether it was something with the enclosure or not at first but I figured because I was able to successfully recover all the data from the other partitions, it wasn't bad. The enclosure is not self powered. It has a transformer to power it.
                      However, just to rule it out once and for all, I'll hook it up directly to my PC later and give it a shot. I've read of others with the same issue and for them, hooking it up to the SATA controller directly didn't help at all. Good idea though. I'll let you know how it goes.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Re: HDD issues.
                        Output of the transformer is 12V, 1.5A. It's actually made for desktop hard drives as well as laptop, just not the smaller, laptop hard drives. It feels a bit cheap though. I think maybe you posted this before I posted my post about it being not self-powered and having a separate transformer. I will still try it directly plugged into my Desktop.
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          Re: HDD issues.
                          I questioned this originally but figured because I was able to successfully recover so much data, it wasn't the case. The enclosure is not self powered. It has a transformer to power it.
                          SMART will attempt to recover the sectors, causing a spike in power draw. I see this with desktop drives, so whether it's as big of a power change on a laptop drive i don't know.
                          let me dig up an old thread about that....
                          https://www.badcaps.net/forum/showthread.php?t=35254
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Re: HDD issues.
                            Wow, great thread there Goontron! I never released how cheap the transformer was!
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Re: HDD issues.
                              I use a salvaged old 110w ATX PSU to power drives I'm connecting to a USB adapter.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Re: HDD issues.
                                I do believe you figured it out Goontron! I just had no idea something like this was happening because of the 1.5A transformer. I knew laptop drives didn't need that much, but wow, boy did I learn something new today.
                                ddrescue shows:
                                Code:
                                [FONT="Courier New"]GNU ddrescue 1.18.1
                                About to copy 300061 MBytes from /dev/sdc4 to /home/spork/backups/sdc4.img
                                  Starting positions: infile = 0 B, outfile = 0 B
                                  Copy block size: 128 sectors    Initial skip size: 128 sectors
                                Sector size: 512 Bytes
                                Press Ctrl-C to interrupt
                                Initial status (read from logfile)
                                rescued:   5906 MB, errsize:    0 B, errors:    0
                                Current status
                                rescued:   6612 MB, errsize:  8650kB, current rate:   524 kB/s
                                  ipos:   6635 MB,  errors:   143,  average rate:  1613 kB/s
                                  opos:   6635 MB, run time:  7.88 m, successful read:    0 s ago
                                Copying non-tried blocks... Pass 1 (forwards)
                                [/FONT]
                                Thank you so much!!!! Now I can successfully run ddrescue. Are you familiar with the program? Following the example someone used when they had the same issue, the command is:
                                Code:
                                ddrescue -d -v -n -A /dev/sdc4 /home/spork/backups/sdc4.img /home/spork/backups/sdc4.logfile
                                Supposedly this helped them a bit. I normally use something more like:
                                Code:
                                ddrescue -d -r3 /dev/sdc4 /home/spork/backups/sdc4.img /home/spork/backups/sdc4.logfile
                                And then I just try it over and over again until the drive dies or there's no more errors. The -d means direct disk access (no disk caching, etc), -v means verbose, -n means no-split (skip the splitting phase) and -A means try-again (mark non-split, non-trimmed blocks as non-tried). My -r3 means retry-passed = 3. (exit after <n> retry passes (-1=infinity) [0])
                                I don't really understand the whole skip the splitting phase and mark non-split, non-trimmed blocks as non-tried. Usually, with a dying drive, first pass, I won't set r at all, just so it doesn't kill the drive faster.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  Re: HDD issues.
                                  I wish I could do that, but this USB / eSATA enclosure won't allow me to. It's more like a caddy that sites on the desk and I push the drives into it, so they're standing vertical. It has a SATA port built into it. It came with our E3 flasher when we bought it for dumping the NAND on the PS3. Replacing the transformer with a higher quality one wouldn't fix this issue, right? I'd need a different USB adapter that allows me to power the drive directly, right?
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    Re: HDD issues.
                                    Hard drives can report SMART data via USB provided that the USB-SATA bridge firmware supports SCSI-ATA translation (SAT). This allows any ATA command to be tunnelled through the bridge by encapsulating it within a SCSI command packet. Earlier bridges had proprietary methods for doing the same thing, while the earliest bridges had no support for SMART. A tool such as smartctl (smartmontools) should be able to retrieve the SMART data. Otherwise there are Windows tools such as CrystalDiskInfo, HD Sentinel, HDDScan, etc.
                                    WD's drives have problems with oxidisation at the HDA contacts. These contacts can be cleaned with a soft pencil eraser.
                                    Oxidisation on Western Digital PCBs:
                                    http://www.hddoracle.com/viewtopic.p...6&t=649&p=1789
                                    WD's drives also suffer from the "slow" problem. Professional data recovery tools have a single-click solution which is often called the "slow fix" or "dealing with slow responding". AIUI, this turns off reallocation and retries. Essentially it does what ddrescue tries to do, but at the firmware level. You can do the same thing by purchasing a one-month licence for WD Marvel (US$15), or you can apply the free solution described here:
                                    http://forum.hddguru.com/viewtopic.p...29187&start=20
                                    http://www.alexsoft.org/viewtopic.ph...8&p=4345#p4345
                                    There is a free Linux tool, with source code, (by KHONG How Yu) that modifies the same two firmware modules:
                                    http://mod32patch.sourceforge.net/
                                    http://mod2patch.sourceforge.net/
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      Re: HDD issues.
                                      most dont have SAT support. good cases do. but not all.
                                      ddrescue shows:
                                      Code:
                                      Current status
                                      [/FONT]
                                      Code:
                                      Code:
                                      Assuming that the rating of the brick is fudged is not a bad thing.
                                      I always assume on those bricks that they just tacked the TOTAL rating of the tranny as the rating of both rails. 1.5/2=.75 would be the actual rating per rail. A Samsung laptop drive sitting on my desk has a minimum (they always seem to list the minimal) of .85 amps.
                                      • fzabkar
                                        • Mar 2009
                                        • 772
                                        Re: HDD issues.
                                        most dont have SAT support. High end cases do. but not most.
                                        Not true. SAT support is the norm.
                                        https://www.smartmontools.org/wiki/S...ed_USB-Devices
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
                                        • ha0s
                                          [Model] Acer A114-61L (DA0Z8XMB6D0 REV. D) — OEM partitions wiped, need firehose (EDL / QSIP 7180)
                                          by ha0s
                                          I have an Acer A114-61L laptop (motherboard: DA0Z8XMB6D0 REV. D) where the OEM partitions were accidentally wiped using the diskpart -> clean command. Now the laptop no longer boots, but it does show signs of life:
                                          • Power consumption is around 22 mA when powered on
                                          • It can be switched into EDL mode, where it is detected as Qualcomm HS-USB QDLoader 9008
                                          • I would like to try restoring the GPT/partitions via EDL
                                          To access storage in EDL mode, I need a firehose loader.
                                          Does anyone happen to have a compatible firehose for QSIP 7180?
                                          07-23-2025, 06:05 AM
                                        • SoulFreeze
                                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                          by SoulFreeze
                                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                          After repairing the above issue, I realized the following remaining problem,
                                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                          The computer recognizes headphones are connected and displays a popup in windows
                                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                          06-21-2025, 09:53 AM
                                        • Nagyesz
                                          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                                          by Nagyesz
                                          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                                          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                                          How can I extend its lifespan? Could reflow help?
                                          It has ryzen 5 5500h, rtx 2050, no soldered ram.
                                          Example of the artifacts:
                                          03-01-2025, 11:11 AM
                                        • pwnjuice
                                          Bitlocker issues
                                          by pwnjuice
                                          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
                                          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
                                          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
                                          01-06-2025, 05:33 PM
