Transitor/ESR tester dead
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Starting a new thread about this that began in my Korg Polysix synthesizer thread in Audio forum...
    Originally posted by SteveNielsen
    That's what I'm in the process of doing. Unfortunately I will have to spend money so it's going to wait a little while. My Chinese transistor/etc tester just died too. At least I can still measure capacitance on my DMM.
    Originally posted by stj
    seriously? there's hardly anything to die on them!
    you did discharge the caps you wanted to test i hope - the testers are 3.3v
    I am very good about discharging caps before measuring them. I may have missed doing so to the last one. It's usually my habit to discharge but I don't know. However, it failed right after I had re-soldered a test lead to it that the strands were breaking on. It's soldered to a length of solid wire that is soldered to a PCB pad, so I didn't overheat anything or that bit of solid wire would have come loose. Regardless, the little guy won't fire up. Oh well. I've gotten a lot of use out of it. I'll get another when I am able to.
    Edit: it was also running on a regulated DC power supply not a battery, so I suppose a momentary power fluctuation or spike that didn't get filtered out could have killed it but I've been using it that way for months. *shrug*
    post a foto of the parts-side so i can see the design.
    it may just be a voltage regulator.
    btw, i just ordered this model.
    i chose it because it has a 3pin connector and flyleads.
    http://www.ebay.co.uk/itm/181861030068
    I like that one. I think I want one too.
    Originally posted by Agent24
    That thing looks like it has no input protection, you could well have blown the uC with a charged capacitor.
    see if that regulator near the battery wires has 9v going in and 5v coming out.
    btw.
    Nope, input on the reg is only 2.4v, output is about 1v.
    Yes, it's a known fact that a charged cap can damage the chip. The manual warns of it.
    i think your dead tester is just a transistor.
    look at the pdf i linked - page11
    I did look and have questions but I think I ought to start a new thread about this.
    Ok, back to the present.
    Stj page 11 appears to show a mod for the board but not what's there on my board. If I'm mistaken let me know. If you meant the basic schematic then what transistor are you referring to?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Transitor/ESR tester dead
    hi i have the same tester here any measurements you need just ask on the regulator i have 9.37 in 4.99 out im running off a 9volt battery is your dc power supply still giving the correct output voltage you have probably already checked this though.
      • 31294
      battery power goes through the transistor top-right.
      it's similar to the schematic but the diode is missing.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Where is the Schematic?
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          The schematic is in the PDF file.
          Stj, you mean the transistor to the left of the regulator?
            • 31294
            yes, just follow the track from the red wire.
            you could run a fine wire from the red cable to the input on the regulator for a quick test.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Thank Steve. So you have a plug in "worts" if I spelled that right and a 9 volt battery. I imagine when its plug in it disconnects the battery. What are the symptoms? Does it not have a test button?
                • 31294
                this is probably it.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  So pin7 and pin1 of the big chip should be at +5 volt. ISP pin5 is also connected.
                    • 31294
                    the regulator should have 5v coming out - start with that!
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Right I agree.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        link the red battery wire to the regulator input and see if it turns on when you connect the battery.
                        Just did it except I've got no battery, using a regulated PSU. Nope, it does not come on. Nothing at the output of the regulator IC, which in circuit measures a short between Out and Gnd. I'll pull the reg test it and check the ckt for a short.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          if your testing ic2 on 2k setting i get .772 ohms between ground and out
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            This 78L05 reg (IC2 on my board) reads 3.2K ohms between Gnd and Out leads. It's not shorted. I've got a 2 ohm short downstream on the board.
                              • 31294
                              with or without the display fitted?
                              • SteveNielsen
                                Retired Tech
                                • Jun 2012
                                • 2327
                                Without display connected.
                                  • 31294
                                  got hot air?
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    I've got a dangerous heat gun.
                                      • 31294
                                      lift the atmel chip & re-check the short.
                                      btw, what part number is it?
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        ATMEGA168V 10AU 0812
                                        I can try to lift the chip but I'm afraid of getting everything else too hot with this heat gun, no nozzles to focus the hot air.
                                        I'll try making an aluminium shield over the board.
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
                                        • maleksa
                                          Korg Kross2 Service Manual and LCD pinout
                                          by maleksa
                                          The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                          However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                          Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                          From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                          10-11-2024, 05:54 AM
                                        • disorder
                                          ps5 edm-033 dead after hdmi/usb ports destroyed
                                          by disorder
                                          hello guys,
                                          i need help to repair a edm-033 ps2
                                          history : as always hdmi port and usb ports destroyed after unplugged
                                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                          so i changed it
                                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                          i don't see any projection of liquid metal on pcb.
                                          01-14-2025, 12:48 PM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
