Vizio vw37l hdtv10a
  • halobender
    • Apr 2013
    • 36
    Vizio vw37l hdtv10a
    I hijacked an older forum hoping someone had a shortcut to help me find what may be wrong with this set. Decided it would be best to just start my own thread and hopefully with your help we can get this tv up and running so I can give it to my grandparents.
    Background: TV appears to have taken a surge from the AC coming into the unit. Other than some discoloration on the chassis and slight black discoloration around the AC terminations everything seems to look good appearance wise. No buldged caps, no burnt fuses, no popped resistors, etc.
    After plugging the TV in I found that it would not attempt to power up. I checked the main fuse on the ps and it is good. I checked fuses f1 and f2 on the main board and both test fine as well but f2 does not have the 5v input or output that it is supposed to have from the ps.
    Any ideas where to start? I have been trying to follow the service manual which listed checking f2 for 5v. Then asked if J1 connector is good. There is no dc voltage present on the J1 connector but the connector appears to be okay. Next step is DC-to-DC. Not sure what this implies. I did test the bridge rectifier and it tests fine. Last step is to check U8 pin 2 for 3.3v, which also has 0v. Of course this makes sense as I don't have any dc present leaving the ps.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Vizio vw37l hdtv10a
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      in picture 3 can you remove that board and take a picture of the underside of the pcb.
      • halobender
        • Apr 2013
        • 36
        Yeah that's the PS. The solder joints were okay but I reflowed them just to be sure there wasn't a fine crack. Also the black and red marks were just to show the f1 fuse location.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          no not that board the small one with blue and brown wires going from it to the psu it looks like the board the mains lead from wall socket plugs into
          • halobender
            • Apr 2013
            • 36
            That is that board. The socket from the wall is CN1 at the bottom right.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              sorry yes my mistake, picture took ages too load i will have another look at the picture
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                being really carfull as high voltage can you test the dc voltage across the large capacitor on the primary side remember this is high voltage and dont let probes slip or touch the heat sinks as some can give shocks etc if your not sure dont test.
                • halobender
                  • Apr 2013
                  • 36
                  I tested it the other day. 167v
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    so on every pin on the secondary side connectors theres no voltage on any pins?
                    • halobender
                      • Apr 2013
                      • 36
                      I will recheck again but I didn't see any voltage across any of the three connectors.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        use the tv chassis as a ground for your meter earth there should be a 5 volts somewhere and someone more experienced will now if this psu uses pfc etc as not sure if 167 volts is correct but im sure that dosnt boost untill the mainboard turns it on.
                        • halobender
                          • Apr 2013
                          • 36
                          Pretty sure the 170vdc is correct without the set being on. I am definitely checking my lower voltages to chassis ground but I haven't rechecked yet. I will do so soon and report my findings.
                            Check the PS-ON pin, it should be >2.5VDC when power switch is activated.
                            If you do not have PS-ON signal from the main board then there will be no >360VDC from the PFC Voltage booster, and also will not have either 12V or the 24VDC.
                            More likely to be bad LDO Voltage regulator ICs on the main board.
                            • jetadm123
                              • 2169
                              Welcome back budm. He mentioned on a different thread that he has no 5V standby output, which means there's something wrong with the power supply standby circuit.
                                OK, the that IC under the small wing heatsink is the SMPS IC for the standby circuit, there should be startup/running small electrolytics cap/s close by in that section that should be checked or try replacing it or try heating it with the hair dryer, he can run the power supply board by it self without having the cables going to the main board connected, the rectifier for the STBY output should also be checked.
                                • halobender
                                  • Apr 2013
                                  • 36
                                  Thanks for the information bud. So disconnect all other boards on the ps and check the SMPS? I checked the rectifier without power and it tested fine, unless there is a secondary one that I have yet to see. Can you describe in better detail what I need to check and in what order? Just to be clear.
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
                                  • SS454
                                    vizio e650i-a2 backlight flashes then turns off
                                    by SS454
                                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                    panel: au optronics T650HVN05.4
                                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                    08-20-2020, 03:57 PM
                                  • mrtek
                                    Vizio M65-C1
                                    by mrtek
                                    Hi.
                                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                    07-14-2025, 07:28 PM
                                  • howardc64
                                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                    by howardc64
                                    Failure Symptom
                                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                    Where is the short?
                                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                    05-27-2025, 02:56 PM
                                  • howardc64
                                    Vizio SmartCast TV software bug that looks like hardware
                                    by howardc64
                                    Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                    It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                    11-16-2024, 05:17 PM
