Asus K55VJ Bios Dump Please..
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    Hi guys i need Bios dump for my asus laptop model K55vj intel i7 proc.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus K55VJ Bios Dump Please..
    i doubt you will find it else, but you can read and post old bios here, i might help you
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1576
      • malaysia
      try this
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        http://www.gulfup.com/?coy4Cm
        http://www.up-00.com/?MuNB
        • jeffwae
          • Oct 2014
          • 10
          • Indonesia
          i need it too.. thx for sending thats bios
          • Direncan
            • Mar 2019
            • 1
            • Turkey
            Can someone reupload k55vj bios. I have k55vj laptop on k55vm rev 2.3 mainboard with gt635m. I tried many bios but gt635m still not working
            • Nomi929
              • Apr 2019
              • 5
              • Pakistan
              Hi, Can i get Ec.Bin file for Asus X555LD Rev 2.0.
              Plz Help.
              • Maste
                • Jun 2020
                • 1
                • Turkey
                Originally posted by direncan
                can someone reupload k55vj bios. I have k55vj laptop on k55vm rev 2.3 mainboard with gt635m. I tried many bios but gt635m still not working
                +1
                • mike15
                  • Oct 2021
                  • 2
                  • CZ
                  Originally posted by alihomee
                  try this
                  Flashed this bios on Asus K55VJ and it works fine.
                  • mike15
                    • Oct 2021
                    • 2
                    • CZ
                    But Nvidia graphics was not working ... Attached is correct bios which works all good.
                    • fahri01
                      • Dec 2013
                      • 3
                      • Türkiye
                      thankyou.....
                      • Rr Rr
                        • Nov 2024
                        • 6
                        • Oman
                        How to replace K55VJ over k55VM?
                        I have k55VM in my laptop!
                          • 21002
                          Post a picture of the green barcode sticker on the RAM slot, if there is one
                          • Rr Rr
                            • Nov 2024
                            • 6
                            • Oman
                              • 21002
                              Not that, i asked you to post the barcode sticker https://www.badcaps.net/forum/troubl...or_amd?t=96604
                              • Rr Rr
                                • Nov 2024
                                • 6
                                • Oman
                                Is it this one?
                                  • 21002
                                  Is it this one?
                                  Is there a barcode sticker on the RAM slot, yes or no.
                                  • Rr Rr
                                    • Nov 2024
                                    • 6
                                    • Oman
                                      • 21002
                                      Wrong again....... .If you don`t know where the RAM slot is or what a barcode sticker looks like i can`t help you. Why do you want to flash the bios anyway, the laptop is running isn`t it, what`s the problem.
                                      • Rr Rr
                                        • Nov 2024
                                        • 6
                                        • Oman
                                        I can't find what you looking for🫣🤦🏻‍♂️
                                        I have problem wit my graphic card
                                        I have nvidia 635m but it is not working
                                        • razor_amd
                                          [TUTORIAL] fix asus bios with bios from asus web support (by razor_amd)
                                          by razor_amd
                                          With ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
                                          For example, you can have 3 similar ASUS motherboards, all being the same model, all of which will have different BIOS versions.
                                          I will give you an example and my version of preparing BIOS from ASUS website and in the process I am always cleaning Intel ME while doing it so you have fully cleaned BIOS, no DMI data, no password, nothing.
                                          This is the picture of 3 similar ASUS motherboards, all of them being X555LD...
                                          12-15-2020, 07:07 PM
                                        • DynaxSC
                                          Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                                          by DynaxSC
                                          I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                                          The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                                          Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                                          Usually on ASUS boards it worked...
                                          06-14-2024, 03:49 PM
                                        • Ahari
                                          by Ahari
                                          I...
                                          Yesterday, 06:12 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • Habble7
                                          I need a BIOS dump for the Samsung S49CG934SU monitor
                                          by Habble7
                                          The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
                                          Suspected Cause:
                                          I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
