Asus K55VJ Bios Dump Please..
  • Rr Rr
    • Nov 2024
    • 6
    • Oman
    Originally posted by SMDFlea
    Wrong again....... .If you don`t know where the RAM slot is or what a barcode sticker looks like i can`t help you. Why do you want to flash the bios anyway, the laptop is running isn`t it, what`s the problem.
    My laptop should have K55VJ but it's k55VM now!
    I need way to change it? ​
      • 22293
      Originally posted by Rr Rr
      I can't find what you looking for🫣🤦🏻♂️
      I have problem wit my graphic card
      I have nvidia 635m but it is not working
      You mean you flashed the wrong bios to it ? .The bios version that the laptop should have is the model that is on the barcode sticker on the RAM slot. Do you have an SPI bios programmer, yes/no ?
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
