Dell 2709WFP
  • diif
    • Feb 2014
    • 6978
    • England
    Dell 2709WFP
    I have wanted a big monitor for a while so snapped up a dell 2709WFP for cheap off ebay that blew fuses after it had suffered from a power surge.
    I stripped it down and after some researching on BCN discovered D651, Q651, R699 and R670 blown.
    I have replaced these parts and when i apply power the fuse doesn't blow, however i fail to get the monitor to show and power and there is no 24v at connector CN701.
    There is 342v going across the big cap.
    Q601 tests ok.
    I am suspecting IC601 a 1203P60 or the component's that effect it, 280v going in but nothing really coming out.
    I am hoping for some help to get a little further. Thank you.
    IC601 1203P60
    1 288mv
    2 1.28v
    3 166mv
    4 gnd
    5 49mv
    6 255mv VCC
    7 350mv moving
    8 280v
    IC651 L6561
    1 1.4v
    2 540mv
    3 1.4v
    4 0
    5 200mv
    6 150mv
    7 0
    8 246mv VCC
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Dell 2709WFP
    I have removed IC651 and found a low resistance between VCC and GND and i have replaced. IC601 also has a similar low resistance so i have ordered a replacement.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: Dell 2709WFP
      Pic 3 bottomright corner is that a yellow fuse - tested?
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Dell 2709WFP
        Yes it is a fuse, and i've tested it and its fine.
        I think its IC601, will update when i've replaced it.
        • diif
          • Feb 2014
          • 6978
          • England
          Re: Dell 2709WFP
          A quick update, after replacing IC601, the monitor now powers on. Hurrah
          However here is a electrical crackling and a burning smell coming from the area of my substitute MKP cap or transformer. My replacement cap is only rated for 305v but the one i damaged was 520v so i need to find a suitable replacement.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
          • diamon
            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
            by diamon
            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
            Pictures of these boards:
            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
            Dell...
            02-28-2024, 12:51 PM
          • master3112
            Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
            by master3112
            I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
            Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
            The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
            07-29-2025, 01:55 PM
          • OntarioTL
            Dell 5410 greyed out BT
            by OntarioTL
            Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
            If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
            Dell Lattitude 5410
            Service Tag...
            07-25-2025, 01:28 PM
