Dell 2709WFP
+ More Options
Posts
  • diif
    • Feb 2014
    • 6978
    • England
    Dell 2709WFP
    I have wanted a big monitor for a while so snapped up a dell 2709WFP for cheap off ebay that blew fuses after it had suffered from a power surge.
    I stripped it down and after some researching on BCN discovered D651, Q651, R699 and R670 blown.
    I have replaced these parts and when i apply power the fuse doesn't blow, however i fail to get the monitor to show and power and there is no 24v at connector CN701.
    There is 342v going across the big cap.
    Q601 tests ok.
    I am suspecting IC601 a 1203P60 or the component's that effect it, 280v going in but nothing really coming out.
    I am hoping for some help to get a little further. Thank you.
    IC601 1203P60
    1 288mv
    2 1.28v
    3 166mv
    4 gnd
    5 49mv
    6 255mv VCC
    7 350mv moving
    8 280v
    IC651 L6561
    1 1.4v
    2 540mv
    3 1.4v
    4 0
    5 200mv
    6 150mv
    7 0
    8 246mv VCC
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Dell 2709WFP
    I have removed IC651 and found a low resistance between VCC and GND and i have replaced. IC601 also has a similar low resistance so i have ordered a replacement.
    • selldoor
      Slow Learner
      • 7870
      Re: Dell 2709WFP
      Pic 3 bottomright corner is that a yellow fuse - tested?
      • diif
        • Feb 2014
        • 6978
        • England
        Re: Dell 2709WFP
        Yes it is a fuse, and i've tested it and its fine.
        I think its IC601, will update when i've replaced it.
        • diif
          • Feb 2014
          • 6978
          • England
          Re: Dell 2709WFP
          A quick update, after replacing IC601, the monitor now powers on. Hurrah
          However here is a electrical crackling and a burning smell coming from the area of my substitute MKP cap or transformer. My replacement cap is only rated for 305v but the one i damaged was 520v so i need to find a suitable replacement.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
            Dell Thunderbolt Firmware
            by SMDFlea
            Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
            Some models have a choice of 2 different firmwares, it depends on the dell SKU.
            The SKU is in brackets (****)
            EDIT: NVM65...
            01-26-2025, 06:22 AM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
