60PN5300-UF with 5v on the 15V line?
  • football0062
    • Dec 2011
    • 98
    Have a 60PN5300-UF which i cannot seem to find the service manual for.
    The power supply only provides a VS(200v) a VA(60v) and a 5mv(5v) to the z sustain.
    Then from the Z sustain we have a connector that jumps over to the Y sustain.
    Problem is my 15V line is only producing 5V(5.45v) i have other lg service manuals that show the 15v being supplied from the Y sustain but those models are directly connected to the power supply, which in this model it is not.
    anyone know the source of the 15V on this model?
  • football0062
    • Dec 2011
    • 98
    Re: 60PN5300-UF with 5v on the 15V line?
    The 15V is actually produced on the Y sustain still and is sent to the Logic(which i dont believe the logic board uses) and Z sustain board.
    The problem was that one of the buffer IC's had gone bad causing excessive load on the y sustain. luckily i had the correct IC around and replaced it. Tv is now working perfectly.
      Good fix, BTW 5mV = 0.005V not 5V.
      Make sure it doesn't fail again. Known fault on some late model LG plasmas is bad panel ribbon causing failed Y-buffer.
      • Peter Chiu
        Banned
        • Dec 2012
        • 145
        Really ! I will quickly order for spare parts (IC251 R2A20299FT)
        I don't understand, u didn't have ( BGA rework station with Optical Alignment System). How could u solder so neat !!! Am I talk to a robot???
        • football0062
          • Dec 2011
          • 98
          im sorry i meant M5V not 5mv, as labeled on the board. i know the 50" panels go bad because of the cable being so close to frame screw and have already had to scrap 3 unit due to that. but this 60" model looks ok. a little more space.
          just used a hot air gun from hardware store and no clean flux paste and my weller PES51 with a ETS tip. oh and a 10X loupe
          • football0062
            • Dec 2011
            • 98
            by the way here is the service manual for this model, it popped up today.
            • Peter Chiu
              Banned
              • Dec 2012
              • 145
              Thank you for your Tips , Indeed.
              TQFP 100 Pins ICs ,they use robot to put in place and solder the IC chips.. I mean you as good as robot .Hop! you don't misunderstand,My Apology!
              This is the best investment I ever made, before I use paint-strip-Killer-heat-gun.
              http://www.ebay.com/itm/852D-SMD-Sol...item19fc5d5211
              • cubytus
                Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                by cubytus
                Hi to all,
                I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                01-10-2024, 01:26 AM
              • otaku_nut
                Vizio E701i-A3 fixed but now has red vertical line
                by otaku_nut
                Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                08-19-2025, 06:11 PM
              • TrueSword88
                Kogan - KALED65XU9220STB - Blue Vertical Line
                by TrueSword88
                Hi all.
                I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                The line just happens to coincide with the end of COF and start of the next COF (attached).
                The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                Hoping to fix...
                05-05-2023, 04:28 PM
              • mindoverflow
                ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                by mindoverflow
                hello,
                there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                I changed pads and thermal paste.
                I run mats test but it is reporting 0 errors.
                I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                02-09-2022, 03:22 PM
              • Technomancer
                Nintendo 2DS SD Card Reader issue. Problem on the clock line?
                by Technomancer
                I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
                Here is what I have done so far:
                -Tried SD card in another 2DS and on PC, works great.
                -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
                -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
                06-07-2022, 09:01 PM
