Hey all!
I was able to get a readyy nice deal from a private party on this VT30. I am stoked to see this get back up and running. I got everything for it including the breakaway inputs for Composite and Component ect, 3D glasses and Wifi USB Dongle.
Anyway, the seller told me he was watching the Superbowl and right as the Seahawks were at the infamous 1yrd line he said the TV did a BZZZZZ POP and that was that. (True Story, even the TV knew the bad play that netted an interception was coming!)
Fast forward, I picked it up and he told me Geek Squad told him it needed a new SC board due to 7 blink and sure enough yes it does blink 7 times.
Anyway so I got a little bit of time and broke it down to start my debug process. Holy moly this thing is THIN!
So I disconnected the upper and lower Ydrive boards and jumped SC50 pin to see if infact the SC board was toast and sure enough 7 blink happend with the buffers disconnected.
Next step I disconnected P2 and P11 (SC and SS power plugs) and then I disconnected plug 35 on the power supply (this feeds power to the bottom C buffer boards)
Then I proceeded to disconnect the 3 white flat ribbon cables being fed to the mainboard.
This test is to determine SMPS and Mainboard functionality. The TV was able to power on and the red LED stayed solid. (This is good)
Then I took out the Upper and Lower buffers to check their stability and they did not yield any shorts ( I hear the Buffers are the weak point of these VT series panels and are quite spendy to replace and or repair)
This panel uses all SMD IGBT's ect. And reading on others who have ruined their SC boards by trying to DIY replace them I opted to have ModusLink tackle the repair (yeah yeah i know I know).
Also ordered the replacement screw upgrade kit from SJ!
Anyway I will update once the repaired SC board comes back to me in a couple of weeks!
I am looking forward to seeing the very last generation of Panasonic plasma panel up and running, this was supposed to keep up with the Kuro from what I have read on various sites.
