Toshiba C50-a628 BIOS need.
  • nazrul145
    • Jan 2014
    • 337
    • BD
    Hi brother, I need toshiba c50-a628 bios. Because this bios only support UEFI boot. So i need update bios for CSM boot. i have downloaded toshiba server but this bios is more than 8MB so that i cant use it.
    System model: C50-A628
    Part no: PSCJGV
    Motherboard PN: DB10BM-6050a2623101-mb-a02
    If anyone can please help me.
    Thanks advance
    I have attacched orginal bios below.
  • dj_ricoh
    • 2073
    • uk
    Re: Toshiba C50-a628 BIOS need.
    you can change uefi boot but you need to disable some security settings so you can install hdd
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      install windows 8 first, update the new bios with csm , then install windows 7.
      i had the same problem
      • Ramee
        • Jul 2014
        • 218
        • Israel
        Part no: PSCJGV
        Thanks advance
        Just enable Legacy mode, to install windows 7. use flash drive w/ win7 installed in it, hit F12, select your flash drive name from the menu then hit enter.
        • nazrul145
          • Jan 2014
          • 337
          • BD
          This bios only support uefi mode and I can't boot windows 8 also.when I boot from pendrive or windows 8 dvd it gives this message ``checking media failed``Or tell me how can I update this bios. Waiting for good solution. Thanks again.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            use rufus to create uefi bootable usb installation diskof win 8, works 100%
            and for the sake of testing try this bios, make sure you have old backup, i have no laptop to test it, dunno will it work
            Im Back... sort of...
            • nazrul145
              • Jan 2014
              • 337
              • BD
              Thanks I will check tomorrow and let's you know.
              • nazrul145
                • Jan 2014
                • 337
                • BD
                Thanks ala_borbe, i have tried with your bios but its not power up my laptop. also try with rufus to make bootable pendrive but also same no bootable media found. Please give another bios file.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  try this bios
                  this is tutorial on how to use rufus
                  Code:
                  http://www.nextofwindows.com/how-to-make-uefi-bootable-usb-flash-drive-to-install-windows-8/
                  maybe you don't have uefi win8, some installation discs do not have uefi files on them, so they cannot be booted on uefi environment
                  if so, you need new win8 installation iso
                  you can also try downloading iso bios update for this model
                  Code:
                  http://support1.toshiba-tro.de/tedd-files2/0/bios-20140402102034.zip
                  • nazrul145
                    • Jan 2014
                    • 337
                    • BD
                    Thankss lot all off of you speacially ala_borbe. I have updated bios with your provided ISO image. By the way i want your help , Can you give your e mail id to me?
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      ok, no problem, im glad it worked
                      mail *****************] but you can contact me here, via pm or so
                      anyway, would it be to much to ask you to once again dump your new bios so that it might help others and to see what i did wrong and why my dump did not work?
                      tnx in advanced
                      • nazrul145
                        • Jan 2014
                        • 337
                        • BD
                        Your second uploaded dump also no power, I have upload my working dump below.
                        • pcnetch
                          • Aug 2013
                          • 125
                          • Sri Lanka
                          Thanks for uploading bios. its works. Thanks lot
                          • edivaldobp
                            • Jan 2017
                            • 2
                            • Brasil
                            thanks a lot, fix my problem too!!!,,
                            • xe_d_sono
                              • Aug 2013
                              • 25
                              • Portugal
                              Teste on a C55-A-1U3, it worked well! Thanks
                              • Gamkutopolowk
                                • Jul 2017
                                • 4
                                • Tunisia
                                Thank
                                • gustarom
                                  • May 2013
                                  • 44
                                  • indonesia
                                  greatt
                                  • alas3376
                                    • Nov 2011
                                    • 382
                                    • BENIN
                                    it work for me , thank you
                                    • dahnking
                                      • Apr 2018
                                      • 262
                                      • kenya
                                      working, Thank you
                                        • 21685
                                        Originally posted by ajbernasko
                                        need bios for Toshiba Satellite Pro C50-H-11B board number is IP3_IN16_MB_V30_20201105A
                                        This thread topic is for the C50-a628 .Start your own thread...
                                        • kenkaniff
                                          HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                                          by kenkaniff
                                          Product Name: HP Pro x360 Fortis 11-inch G9
                                          System BIOS: U94 Ver.01.08.00 10/06/2023
                                          Serial Number: 5CG31946F5
                                          SKU Number: 85W05EC#AK8
                                          Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                                          This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                                          I needed to remove bios password...
                                          10-01-2025, 04:32 AM
                                        • throwaway327
                                          Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                          by throwaway327
                                          ASUS ROG Ally X - (Handheld Gaming PC)
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                          I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                          06-18-2025, 05:52 PM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • Neddsme
                                          Bios partially corrupted somehow and now warm boot doesn't work which is critical
                                          by Neddsme
                                          Hie.
                                          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
                                          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
                                          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
                                          I managed to run Windows troubleshooting and...
                                          02-04-2022, 05:57 AM
                                        • Max029
                                          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
                                          by Max029
                                          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
                                          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
                                          TY,
                                          08-18-2024, 08:28 PM
