This is going to take a bit of detail to explain...
Got a Panasonic TC-P50S30 Plasma that was a lightning strike casualty..
Totally dead as a doornail.. No lights, no LED, no power indicator, no nuttin..
As I have mentioned previously, I am not much of a PCB troubleshooter. Frankly, I am a massive wimp when it comes to fiddling with boards, checking voltages and stuff while the TV is powered on... So, my "expertise" consists of visual inspections and the like...
The TV has a metal box like device as the plug, a NOISE FILTER CIRCUIT. Pic #1
Inspecting all the boards on the TV (Pic #2) there doesn't appear to be any char marks, no blown caps, no damage whatsoever... I have checked all the fuses on all the boards and they all check out fine. None blown...
So, my first thought is that the Noise Filter doo-hicky is fried...
Order a replacement. No luck.. Still as dead as a doornail..
OK, so I am thinking Power Board... Replace that. No luck... Still dead..
That's where I am at now..
Now I am beginning to rethink my "repair" process. This is a really sweet Plasma, a newer model that is in excellent cosmetic condition. So I really don't want to just toss it..
On the other hand, I really don't want to keep spinning the wheel hoping I hit the right board before I run out of $$$...
So, now I am thinking that I might as well learn how to check power connections and voltages and what have you...
I have only got a little rinky dink voltmeter that I use to just check continuity and voltages on laptop power adapters... So I guess my first question is going to be what kind of equipment should I buy that will allow me to safely check (emphasis on SAFELY) voltages....
Another question I have is, what about bypassing the NOISE FILTER doo hickey and hook power directly to the Power PCB...
Good idea???
Bad idea???
Totally frak'in moronic idea???
Any hints, tips, suggestions would be greatly appreciated...
Good idea???
Bad idea???
