No POST after writing single bit to CMOS; any solution?
  • Behemot
    • 4845
    • CZ
    I have encountered so many boards which storing a single bit in CMOS would render inoperable that I am starting to be crazy about that.
    Last time it is my parents PC with DFI LANParty UT nF4 SLI-DR Expert. The symptoms are the same as usually: when you clear CMOS, it works fine. When you store a bit in there, it fails to POST. In real world that means you turn off or reboot the computer and as Windows and possibly every OS writes something in there, even though it would be time update, it does not POST after that. And certainly it is bad to use board in factory defaults with factory time, especially having to reset it manually each time.
    This time there is only one difference: I know this board's CMOS has been written to every day at least twice: it has some strange like-a-backup function which saves your BIOS settings each time the board sucesfully POSTs, just before the boot process. And than the OS does the time update and maybe other writes. So that makes me think it is bad CMOS memory?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: No POST after writing single bit to CMOS; any solution?
    The only thing I can think of that would normally update CMOS from the OS would be date and time settings. Other updates such as a change in hardware would update it but that is not from the OS booting, that's from the BIOS detecting new hardware.
    I think you may be right about bad CMOS memory though, that's the only thing that I think of that could account for the behavior.
      • 31246
      a bad diode could cause low voltage to the ram or false triggering of write-protect.
      • Behemot
        • 4845
        • CZ
        Which RAM do you mean? BIOS is stored in Flash (probably NOR) for some time. There is section which is usually denied for writing to unles you use programmer (this section is OK, I have flashed the latest BIOS version again with no change in behaviour). Than there is section called CMOS after CMOS RAM which has been used ages ago for this purpose. But it is still Flash, it weares out making the cells unusable.
          • 31246
          cmos is not flash,
          it's a couple of k of low-power ram usually stored inside the chipset with the RTC clock.
          it's powered by the battery & psu via a pair of diodes.
          i'v had to fix this a few times on industrial motherboards.
          • Behemot
            • 4845
            • CZ
            Chipset? Huh?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              Some computers have the battery backed configuration RAM ("CMOS") inside the chipset silicon to save costs. Usually the RTC is also integrated. This is versus the external RTC/configuration RAM when things were less integrated. Sometimes it really is stored in EEPROM cells but that's fairly rare.
              I'd suggest checking the configuration RAM battery if it has one, sometimes a bad battery could cause that behavior.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5065
                • New Zealand
                I would check battery, battery holder, and battery circuit also. I have many experiences of boards that do not POST with flat or dead batteries.
                Sometimes you can get dirty battery holder contacts as well (Happened to me once) or even bad soldering on battery holder (happened to someone else).
                Or the diodes etc can fail, of course.
                -David VanHorn
                • Behemot
                  • 4845
                  • CZ
                  Well, basically no battery would erase the settings going into default as well, wouldn't it?
                    • 31246
                    no,
                    no, or low voltage to the sram would cause random values.
                    a simple test,
                    reset the cmos,
                    and SET THE CLOCK.
                    then power down including killing the 5v standby by pulling the plug for a day.
                    preferably pulling the psu plug from the mobo incase the psu has a large cap in it.
                    then boot up and check the clock - the clock section is usually slightly more sensitive than the cmos ram and will show up a problem sooner.
                    • Behemot
                      • 4845
                      • CZ
                      Man you noticed the When you store a bit in there, it fails to POST? How the hell am I supposed to set any clock? IT WON'T POST.
                        • 31246
                        reset the cmos to start the test.
                        better yet,
                        follow the battery + track to the chip with your meter.
                        or get the datasheet for the chip and see what pin has the vbat supply on it.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5065
                          • New Zealand
                          Yes, but some boards don't seem to like it and go crazy when the battery is flat.
                          Put in a new battery and they POST straight away, then complain about a BIOS checksum error and the defaults having been loaded as per normal.
                          -David VanHorn
                          • Behemot
                            • 4845
                            • CZ
                            Strange because the battery itself should also play no role until the stand-by rail stops feeding board with 5 V. I'll have a look into it when I arrive with the PC to the shop.
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 5065
                              • New Zealand
                              It doesn't make sense to me either, but I've experienced it first-hand so I believe it.
                              -David VanHorn
                                • 31246
                                it makes sense if there is no diode to feed the standby-power to the sram.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  I'd say remove the battery altogether and try to power ON the board again. Have not seen a board that would refuse to boot due to no CMOS battery. However, I did have a board get corrupt CMOS settings due to a battery going slightly low. Took me a few minutes to figure how to change the menus from Chinese to English . Then I realized I could just pull the battery out and be done with that. And so I did.
                                  Since I keep a lot of old computers around that I don't get to use more than a few times a year, I always pull their CMOS battery. If I'll be using the computer for only a few days, I don't bother putting in a CMOS battery.
                                    • 31246
                                    i have - just the other day.
                                    it may have been an Intel LittleFalls2 board.
                                    (965 chipset)
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      I have seen battery clips so tight they short out with the battery removed. I imagine that could stop booting by dragging the standby voltage down.
                                        • 31246
                                        no, because there will be a diode inline - sometimes a resistor too.
                                        • questore
                                          XPS 13 9370 CMOS battery voltage always low
                                          by questore
                                          Hi Everyone,
                                          I have brought you a mistery item
                                          This laptop have come with some strange faults.
                                          1. CMOS battery was flat 0v
                                          Symptoms:
                                          - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                                          Amp drawing was stuck at 0.005 milliamps.
                                          - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                                          After inverstigation RTCD1 diode had a low value...
                                          09-30-2025, 05:47 AM
                                        • Exim
                                          ASRock N100M, no picture no boot, but semi-alive
                                          by Exim
                                          Hi guys,
                                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                                          ASRock N100M special features:
                                          - CPU soldered to board, small Intel 12th gen
                                          - iGPU
                                          - four POST LEDs
                                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                                          Symptoms:
                                          - no picture/signal on any of the display connectors,...
                                          04-01-2025, 02:36 PM
                                        • HammyCheesy
                                          Lenovo ThinkStation P720 BIOS Request
                                          by HammyCheesy
                                          Hello all,
                                          I'm trying desperately to revive a ThinkStation P720 that I purchased from a seller who claims it suffered a "failed firmware update."
                                          When given power, the machine turns on, spins up fans, beeps a single time, fans slow down, then a beep code is sounded repeatedly (3 high/short tones, 1 low/long tone).
                                          Type: 30BB
                                          Model Number: S03600
                                          S/N: MJ07N68C
                                          Things I have tried:
                                          1. Reseated all components, pulled everything except for 2 RAM modules (1 per CPU)
                                          2. Attempted to boot with just a single CPU...
                                          04-11-2025, 01:02 AM
                                        • titomno2
                                          Gaming Laptop Zephyrus S17 TFT not detected every time !
                                          by titomno2
                                          Hi guys,
                                          I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
                                          So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
                                          On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
                                          Then the screen won't work for a long period of time.
                                          If I wait 1 or 2 hours it work again most of the time.
                                          When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
                                          01-19-2025, 08:27 AM
                                        • LimesKey
                                          Dell Inspiron 7506 Silver 2n1 - "HELLCAT 15" - No power
                                          by LimesKey
                                          Hi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...
                                          10-17-2025, 05:33 PM
