2 types of new polymers?? Rubycon MFZ and Chemi-con TMV
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Recently, i researched these 2 kinds of polymers on some new L775 mothbaords. However, we can't find any datasheets from Rubycon 2007 catalogue and the latest catalogue of Chemi-con.....
    I just found a little bit information about MFZ and TMV, anyone can get more information about these 2 types of polymers?
    A little bit information of MFZ from this datasheet -->
    http://datasheets.maxim-ic.com/en/ds/MAX8811.pdf
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: 2 types of new polymers?? Rubycon MFZ and Chemi-con TMV
    I'll check my 2007 Rubycon paper catalog and try to look into it when next these two 'cons come for a visit. UCC seems particularly slow about getting info about news series onto their web catalog, and I'm not sure Nichicon or Rubycon are much better. Is the Rubycon part one of those stacked foil-and-polymer types for use under the uP? I know their paper catalog has data on one such new series. Also, both Nichicon and Panasonic have fairly new products that seem to fit that application and form factor.
    PeteS in CA
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      good find Joe! i searched but i did not find anything. maybe some series are first for special integrator clients then afterwards they will officially launch it.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        some of these new series are likely oem only.
        means you may not be able to get them from digikey,ect.
        • PeteS in CA
          • Aug 2005
          • 3581
          Nothing on these in the Rubycon 2007 paper catalog. These two series names do not resemble the series names of any current series in the Rubycon catalog or the 2006 UCC paper catalog. I'll keep my eyes and ears open about new polymer series when Rubycon and UCC next come visiting.
          PeteS in CA
          • PeteS in CA
            • Aug 2005
            • 3581
            Well, I got a 2007 UCC paper catalog. No TMV series in it, polymer or liquid electrolyte. UCC plans to continue to use PS(X) and PX(X) for their polymer series names (through-hole and SMT, respectively). There is no new series responsive to Nichicon's PA series in the catalog. In some other literature we were given, there is an MFZ series mentioned. In context, it appears to be a UCC part, but it is neither polymer or liquid electrolyte. It appears to be positioned as lower ESR than liquid electrolyte but higher ESR than polymer. It is not mentioned either in the catalog or online.
            PeteS in CA
            • PeteS in CA
              • Aug 2005
              • 3581
              Can't shed any further light on Rubycon, whether the series is MFZ or TMV. OTOH, it looks like their products may soon be distributed through Newark.
              PeteS in CA
              • ahmedtou
                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                by ahmedtou
                Hi everyone,
                help me please
                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                I will share all the details with you, including the disc information.
                Code:
                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                Current Profile: BD-R
                Disc Information:
                Status: Empty
                State of Last Session: Empty
                Erasable: No
                Free Sectors: 12,219,392
                Free Space: 25,025,314,816 bytes
                Free Time: 2715:27:17 (MM:SS:FF)
                Next
                08-27-2025, 08:49 AM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • kahlil88
                Dell Dimension C521 motherboard
                by kahlil88
                Need to replace several bad caps and possibly some seemingly good ones of the same series as preventative maintenance, but let me know if I'm just being paranoid. Very much open to replacing all or some with polymers but not sure what values to go with.
                Bad caps are all 6.3v 1800uF (5x Rubycon MCZ + 1x Chemicon KZJ).
                There's a row of clean 6.3v 820uF KZJ caps above the RAM slots and 2x 16V 680uF MCZ on the corner closest to the CPU fan....
                11-06-2022, 05:24 PM
              • P4C800
                ASUS P5A and P2B-S recapping. Searching old datasheets.
                by P4C800
                I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                There are three mainboards:
                - ASUS P5A rev 1.04
                - ASUS P2B-S rev 1.03 "Rubycon"
                - ASUS P2B-S rev 1.03 "Chemi-Con"
                If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                P5A
                10-09-2023, 05:55 AM
              • Mark R
                Equipment Display Types
                by Mark R
                Most Displays I have worked with are of course LCD Or Blueish Fluorescent Types. I Have a Marantz PMD800 tuner with sort of a white display. The display area is a sealed rectangular shape in a Glass Case. Looks like some sort L.E.D. display only not your typical section number type. I picked up this Tuner cheap as the display is very Dim. In front of the circuit is a dull red Plastic lens.
                The display is very week and hard to see. I've got my DC 5 Volts allover and also a DC 32 Volt that runs some other section. Power supply looks good front to back. Not familiar with this type...
                06-07-2024, 07:19 PM
