Locating short circuits with bnch psu
  • scobie_21
    • Jul 2011
    • 144
    Hi Im looking for the quickest way to locate shorts on laptop motherboards. I have a bench supply but every time I connect it the over current trips out and I have to power it off then on again. Is there an easier way of locating suspect component/components?.
    Many thanks
  • smason
    • 1652
    Re: Locating short circuits with bnch psu
    Many thanks
    A better bench supply?
    Sounds like a smartass reply, but with a good bench supply if you tell it to limit current to 1A, it'll sit there and feed 1A into a dead short or whatever, no need to reset it all the time.
    I find it better to use a good low ohm meter and trace it that way.
    That said, I failed to find a short on a Dell laptop motherboard last month. Tried the give it power and watch for smoke routine, no luck.
    • scobie_21
      • Jul 2011
      • 144
      No not a smart ass reply at all. much appreciated I will look into buying better psu. Can you recommend any ?.
      • smason
        • 1652
        There are a lot of similar supplies that look like this Chinese one:
        Item 400396805866 on Ebay.ie (link was too friggin long and I'm too lazy to use a short link site)
        • scobie_21
          • Jul 2011
          • 144
          That's the exact same one I have.
          • scobie_21
            • Jul 2011
            • 144
            Actually its a slightly different model. Mine has not got the push button in the middle between the current and voltage knobs.
            • scobie_21
              • Jul 2011
              • 144
              So would I be right in saying I need one with a current limiting feature so it wont power off?.
              • rievax_60
                • May 2012
                • 897
                • australia
                I use a 1 ohm resistor in series with my power supply. I try to stay under 0.5A. My power supply is a simple linear design and tends to get rather hot when run at low voltage and high current.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  A milliohm meter.
                  A working TV? How boring!
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    Are you starting from zero volts?
                    • scobie_21
                      • Jul 2011
                      • 144
                      No Im using 1v. I have a short on a dell motherboard that I cannot locate I have tried isolating different sections by removing some coils on at various regulators. The unit wont power on and the dell psu goes into protection mode after a second or so. I have a bench psu and as the short is on the 1.05v line to the PCh I have established the short is not on the regulator side by removing the coil on the output and the short stays on the output side ie. Pch supply voltage there are many components on that side and my bench meter cuts off after a second or so when I connect it to the circuit.
                      • scobie_21
                        • Jul 2011
                        • 144
                        A milliohm meter.
                        Can you explain a bit more on the method used please ?
                        • scobie_21
                          • Jul 2011
                          • 144
                          When you say you try to stay under .5A how do you control this ? I don't seem to have any current limit on my supply It just goes straight to protection mode and I have to switch of the bench psu then on again so theres no chance to find components heating up.
                          • smason
                            • 1652
                            Hmm does it not have a current adjustment?
                            This is the exact model I have:
                            • scobie_21
                              • Jul 2011
                              • 144
                              The one I have is a Zhaoxin PXN-1505d it looks almost identical to yours except theres no button in the middle for low/high Amp readings. I set the voltage to 1v and no matter what I set the current to as soon as I connact it to the circuit the bench supply just says 00 on both v and current readings and I had to power it off to reset it.
                              • smason
                                • 1652
                                Weird. I can short mine out and it'll limit current but I don't have to power reset it ever.
                                • nucleus
                                  • May 2012
                                  • 64
                                  • Montenegro
                                  I also have similar dc power supply and I can set limits on voltage and current. when it reaches it stays there and can works days without problems. same is for short circuits. so probably your have malfunction or something
                                  • scobie_21
                                    • Jul 2011
                                    • 144
                                    But what about if you are measuring a dead short on a board ? What does it do then ?.
                                    Thanks for the input
                                    • nucleus
                                      • May 2012
                                      • 64
                                      • Montenegro
                                      it reaches limit I set (for example 0.5A), turn on red light that say "I hit the limit" and stays there. thats how it should work every dc power supply I think
                                      • scobie_21
                                        • Jul 2011
                                        • 144
                                        When I adjust the Current without connecting load nothing changes it stays at 0.00A, if I connect say a dc motor the v will go to what I set it to but theres no adjustment on the current it just shows amount of current drawn but is not adjustable
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • adelfr2009
                                          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                                          by adelfr2009
                                          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                                          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                                          09-28-2025, 10:21 PM
                                        • Geeker007
                                          9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                          by Geeker007
                                          Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                          I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                          So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                          01-28-2025, 03:31 PM
                                        • kotel studios
                                          Lenovo B50-70 LA-B092P REV 2.0 - short on +3VLP
                                          by kotel studios
                                          My lenovo B50-70 laptop (mainboard compal LA-B092P VER 2.0) had a short on the +3V generation part (where PU401 is).
                                          I've removed the SY8208BQNC and the short is gone on PL402. Although, it's still there on pin 5 "LDO" of the SY8208BQNC (1.8ohms to GND).
                                          All other coils aren't shorted to GND.
                                          Removing the PC412 cap didn't help. Mainboard pads are still shorted. Cap itself is fine.
                                          Pin 20 (+3VLP) of ALC codec isn't shorted too, so it shouldn't be the issue.
                                          Originally, the laptop wouldn't power on. It would get its 20V on the...
                                          10-12-2025, 03:32 AM
