sansui LCT42DSFT USB
  • willyam1
    • Feb 2012
    • 112
    • israel
    HI to all.
    problem is to much brightness in pic even without signal .
    when no signal screen should show a BLUE SCREEN and now its a little beet gray .when ther is signal the pic is a little beet grayny.
    I enter to service mode by remot SOURCE AND 2580.
    I went to eeprom and I got this.
    eeprom;addr:000
    date:00
    save
    factory recal
    I pushed the factory recal and afew sec after its the same problem.
    am I missing something in the reset procedor.
    or culd be the problem in the tcon board or screen defect?.
    please need help.
    willyam1
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: sansui LCT42DSFT USB
    I get no google hits at all on that model number - is it correct.
    Is it LCD or LED
    What does it do with a source connected
    Is there sound
    Can you update your profile with country and mains voltage
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    • willyam1
      • Feb 2012
      • 112
      • israel
      no google hits.its a lcd .when a source is connected can see good pic with color but too much brightness and sound ok.
      main board is 28.A001100-0020 and tcon is T420HW04.
      I will try to post letter a pic.
      willyam1
      • willyam1
        • Feb 2012
        • 112
        • israel
        problem solved.
        I replace the ic AS15HF WITH AS15G INTHE TCON BOARD AND TV WORKS FINE.
        THANKS WILLYAM1
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Wow -well done - dont think I have seen anyone replace chips on a T-con.
          Great
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Good job!
            About the no Google hits thing - probably a rebranded unit.
            Muh-soggy-knee
            • willyam1
              • Feb 2012
              • 112
              • israel
              thanks to all.
              willyam1
              • RRice25541
                Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
                by RRice25541
                So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
                the color is all outa wack, like the settings have been corupted,
                I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
                so
                The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
                when i bring up the menu and type the pass codes to access either mode the menu disappears...
                05-13-2022, 10:44 PM
              • masterm
                JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
                by masterm
                TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
                Problem with TV:
                - Netflix stopped working so i tried to do factory reset from the TV menu.
                - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
                - After waiting for some time, the TV went into a boot loop.
                - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
                04-30-2024, 03:03 AM
              • Coert van Dorsten
                Sansui Integrated Amplifier replacement volume control troubles
                by Coert van Dorsten
                Hi all you clever electronmic gooroos!
                I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
                10-15-2025, 02:54 PM
              • Hornnumb2
                Sansui sled4019 dim picture
                by Hornnumb2
                I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
                08-31-2025, 10:37 PM
              • Hornnumb2
                by Hornnumb2
