Vizio VO47LFHDTV10A burnt spot on PSU, replace or try to fix?
  • johnboy1313
    • Nov 2012
    • 1959
    I just picked this thing up. Probably paid too much for it but I felt sorry for the guy who is apparently being evicted from his house (who knows). Anyhow, There's an obvious burnt spot and a bulging cap, on the PSU, but no blown fuses. There's also bulging caps on both inverter boards. Chances are there's a bad regulator or two on the main board as well.
    The traces on the back of the panel look OK, do you think it's worth repairing this PSU, or should I just try to find a used one?
    Re: Vizio VO47LFHDTV10A burnt spot on PSU, replace or try to fix?
    Bad caps will cause those inductors to run hot but they are probably OK. Replace the caps. Normally Chemicons do not fail. Poor design if it can kill those!
    • johnboy1313
      • Nov 2012
      • 1959
      I Replaced 1 35V 470uf cap on the PSU, 2 35V 680uf caps on each inverter, and a 10A fuse on the master inverter. The results speak for themselves.
        I see only one problem, the logo below the screen says "Vizio", it should say "Piece of overpriced crap"
        Nice easy fix.
        • johnboy1313
          • Nov 2012
          • 1959
          Nice
            Some people do not know that they are just another re-badging company. Not designed in US, not made in US.
            • xredhawk
              • Jul 2011
              • 103
              hi , i got same burn spot on psu i moved coil and leg lifted off the board , i dont know what to solder that leg to as the green print on board burnt off, also has same bad cap, any help would be great!
              • johnboy1313
                • Nov 2012
                • 1959
                Pictures??
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Get a thick piece of solid wire and connect the parts again, the way they were before the trace got ripped up.
                  Muh-soggy-knee
                  • Bktimby
                    • Aug 2013
                    • 4
                    I Got the same problem but the board is burnt so bad the board started to peel up as you can see in the picture. I'm going to change the one capacitor. But before I start I was wondering if I'm wasting my time with the board that bad burnt.
                      That is the symptom of bad filter cap in the Pi filter, the inductors are trying to block the High frequency AC ripple from flowing through (inductor blocks AC and passes DC, cap passes AC, blocks DC. You need to change the caps as a set since bad cap can look normal.
                      To fix that solder solder joints, you need to add more regular solder (not lead free) to the connections and remove the solder, clean the leads real well and use solder flux to solder the parts back on.
                      • Bktimby
                        • Aug 2013
                        • 4
                        I finally got home long enough time to start working on the board. When I was cleaning the board the rest of the strip came off. Is there a way to repair it or trash it? Please see the pic.
                          It's repairable but you're going to need to figure out where each end of that inductor went so you can solder wires to each end.
                          • Bktimby
                            • Aug 2013
                            • 4
                            Please bare with me trying to fix a board for the first time. I would like to hook it up to see if it works but would like an opinion on it first. If you need to see other pictures you can scroll up in this thread. Thanks
                            • PL519
                              Tube lover
                              • Jul 2013
                              • 26
                              looks good so far, since both inductors are in parallel. Looking at your picture it seems you have changed C241, but not the other filter caps. I would recommend to change C240A und C240B too as they are responsible for the high ripple current through the inductor coils!
                              Greetings,
                              Wolf
                              • Bktimby
                                • Aug 2013
                                • 4
                                Will do thanks PL519
                                • Dflammer
                                  • Nov 2016
                                  • 6
                                  I have the same problem, same model. I will be replacing the 5 popped caps. I have voltage to the inverters but, nothing going out of the pink wires that plug into what I believe are the backlights. Both inverters have same dead end. I re-soldered the coils, got the 24v to the inverters. Will post results after the parts arrive.
                                  • Dflammer
                                    • Nov 2016
                                    • 6
                                    I changed out the 4 popped caps on the inverters and the 1 bad cap next to the burnt coil on the power board. Still no backlight. I had good 24 volts into the inverters before the cap repair and still have 24v to the inverters now. I got nothing coming out of the inverters. I have attached a pic of the Master inverter board. After I ordered the replacement caps, I noticed a little scorching on the IC that is between the caps and have attached a picture. How can I tell if the backlights are still good? I don't want to waste 40$ on a replacement inverter only to find that the backlights are dead.
                                    Thanks for the help, it is appreciated!
                                    Dave
                                      Do you have BL-ON (INV-ON) command signal from the main board to turn on the backlights Inverter?
                                      Please read the basic troubleshooting guide.
                                      BTW, that IC is blown and more likely the fuse and the Power MOSFETs on the inverter board.
                                      You cannot tell if the lamps are good or not unless you take the panel apart to inspect them, but that is not 100% for sure by using visual inspection.
                                      • Dflammer
                                        • Nov 2016
                                        • 6
                                        Thanks Bud. I have the 24 volts and the 'on' voltage is 3.5v at the inverter connector from the power board. There is the same voltage at both ends of the fuse and no resistance. Due to the scorched IC on the master inverter, I ordered 2 used inverters(same inverter model nos.) from ebay and will give that a shot. Replacing the TV is going to cost me about 7-800, so 30$ is OK for determination. The power board was scorched at the coils and I replaced the cap that had popped next to it. I replaced the 4 caps on the 2 inverters, all 4 were popped. I seem to be getting the voltages everywhere from the power board, sound and LCD are good and displaying/playing, just no backlight & no power coming out of either inverter.. I appreciate your help in this forum, GOD bless.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • irepair559
                                          Led lights PCB burnt can I replace with these PCB?
                                          by irepair559
                                          hello guys I got these LEDs lights ( Power probe TEK ) 4 little cube Leds that go into a one unit holder /charger , that charges via 5v rail to all 4 at the same time.. but brother used a 12v and fried 2 of the 4 boards.. ..so only 2 work and the others just get hot and battery don't charge..
                                          The boards consists of input of 5v then battery connector 5v out and a connector for the led ( 3 modes ) 5 wires..
                                          I bought some 5v charging boards type c..
                                          I can connect it to charge battery but how to connect the led 5 wire connector �� ?...
                                          11-19-2023, 03:51 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
