Pulled an LG 47lk520-ua LCD from the dump and plugged it in. Red STBY LED is lit, but dims when power button is pressed. No picture or sound. Suggestions on where to start?
LG 47lk520-ua No picture, STBY LED dims
Re: LG 47lk520-ua No picture, STBY LED dims
Post good clear pictures so we can see what we are dealing with it.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Test standby voltage. If you're not sure which pin is standby voltage, post a picture of the legend near the connector running to the main board from the PSU.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Is it indicated as 5V?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
No. It is marked as 3.5 VDC. Tested the 12 VDC (12.40 VDC) and the 20 VDC (21.8 VDC) supplies. Noticed that the red STBY LED cycles through bright/dim at about a 3 second interval. No changes in the voltage readings. Also noticed that when PWR is hit again, the PS voltages return to 0 VDC, excepting STBY which remains at 3.5 VDC. I then looked for voltage at F1 on the T-con board. No voltage present on either side of the fuse. Checked the one voltage regulator that I see on the main board and saw 2.5 and 3.2 on the pins.Comment
What is the marking on that regulator? I am thinking main board issue now. PSU seems fine.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
What is the part code on it, as well as the other one?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, here are the details:
IC410
PN = 111KG 1117
Pin 1 = 3.68 VDC
Pin 2 = 4.94 VDC
Pin 3 = 6.85 VDC
IC411
PN = 111KG 1117
Pin 1 = 3.71 VDC
Pin 2 = 0.00 VDC
Pin 3 = 6.85 VDC
IC3703
PN = EH17K 110n10
Pin 1 = 0.00 VDC
Pin 2 = 1.27 VDC
Pin 3 = 3.30 VDC
IC404
PN = 111KG 17 18
Pin 1 = 0.00 VDC
Pin 2 = 1.81 VDC
Pin 3 = 3.30 VDC
IC402
PN = AZ2940025E1 112J72
Pin 1 = 3.32 VDC
Pin 2 = 0.00 VDC
Pin 3 = 2.51 VDCComment
IC411 looks a little odd. Is pin #2 definitely 0V?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
That seems more realistic, it is creating 5VDC from 6.85V; 3.71V + 1.25V = 4.96V (you have 4.95V.)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Finally found a service manual and started with the troubleshooting steps (page 54). Measure 2.8 VDC on Pin 8 of IC405 which should be 3.3 VDC. Also looked at voltage on Q409 and found 0.0VDC on the output. When I shorted the input to the output pins of Q409, the blue LED on the top of the set turned on. Measured 9.5 VDC on the F1 of the T-con. Progress, but not there yet. Need to find the replacement for IC405. The part number on the chip is AOZ1073AIL-3. Anyone suggest a replacement?
http://elektrotanya.com/lg_47lk520-u.../download.htmlComment
Went ahead and bought a replacement motherboard owing to ShopJimmy's 15% discount code offered. Fired right up. Would have preferred to fix it, but too many others to troubleshoot in the garage! Thanks for all that helped.Comment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by JJAAMMThis was my main TV for the last 6 years. I'm not inclined to throw out a $2600 TV so quickly so I'm trying to investigate the issue.
Problem
TV was disconnected from power for 6 months during construction. When I plugged it yesterday picture was fine, after 30 seconds it dimmed then started developing horizontal lines, picture then starts to ghost vertically until it degrades into vertical streaks. TV always displays a perfect picture when cold. I can unplug TV for 5 minutes and plug it back in and picture is restored for 20 seconds. I can also keep it in standby mode... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
- Loading...
- No more items.
