Sanyo DP42848 Sound - No Picture
  • krseaman
    • Jul 2012
    • 8
    Tv powers on. After 6 seconds, picture comes on w/ faint buzzing sound from each inverter board equally - for 1 second then goes away.
    Picture is visible in LCD with a flashlight.
    I've attached a couple of pictures, let me know where I should start!
    Kevin
  • krseaman
    • Jul 2012
    • 8
    Re: Sanyo DP42848 Sound - No Picture
    Here are pictures of the inverter boards, dark spots look to be Flux not Charred.
    • krseaman
      • Jul 2012
      • 8
      I checked the Voltage to the two inverter boards and i'm getting 24V to both the master and the slave. If i unplug the slave inverter, and leave the master plugged in, i get the same behavior: turn on, 6 seconds later light comes on for 1 second, then off.
        I would Ohm out all four MOSFET's (the device with tab and 3 pin, the middle pin is connected internally to the tab), just label each pin with 1, 2, and 3. Then check the resistance between
        1&2
        1&3
        2&3.
        I would also replace those 3 caps on each inverter, it is cheap to do, need or not so you will not have problem later on.
        Also look real close at all the solder joints and for any burnt components.
        Set the Ohm meter to about 2K scale.
        • fading fast
          • Aug 2010
          • 4
          i have two of same tv same problem. when both sets come on you can see dark sections across screen like the lamps are burned out in that area. dont believe there is anything wrong with inverter boards
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            @fading fast - you will need to open it up and try and check if all the lamps light, could be lamps or wiring.
            • krseaman
              • Jul 2012
              • 8
              I swapped out the master inverter with a known good board and left the slave unplugged, and it does the same thing. So i also think its not a problem on the Inverters....
              Would bad bulbs make it come on and go off? The Entire screen lights up and looks normal for 1 second before going off.
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
              • Ierwin
                by Ierwin
                05-13-2025, 03:31 PM
              • jchang
                Samsung UN70NU6900F no picture and no sound
                by jchang
                Hi all
                I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                Symptom:
                No picture no sound.
                When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                No sound at all.
                What I tried:
                1. I tried unplugging the left or right ribbon...
                01-09-2023, 06:28 PM
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
