Sony KDL46w4100 tcon board F1 fuse
  • aerospacejackson
    • Jun 2012
    • 19
    • united states
    Hello, a tv repair place has identified my TCON board as being bad offered to fix it for 300 dollars, took the tv home and pulled the board, i am getting no continuity and my resistance is showing open through the F1 Fuse. On the surface of the fuse it say LF 7A, any idea as to a part number so i can order a new one? the model on the board is 404652ASNC6LV3.7.
    Re: Sony KDL46w4100 tcon board F1 fuse
    You can try this:
    http://www.digikey.com/product-detai...1CT-ND/1905919
    You lay a new fuse on top of the old fuse and solder both ends to the old fuse.
    The board may have short circuits, so order more then one.
      Just to check though - the symptom of the fault, no picture, but screen is lit up, and sound is present? Post a picture of the board, there could be a shorted ceramic capacitor on it.
      • aerospacejackson
        • Jun 2012
        • 19
        • united states
        Yes, those are the exact symptoms, turns on screen lights up, good sound, then after about 15 seconds it shuts off the standby blinks 14 times. Ill try to post a good picture of the board
        • aerospacejackson
          • Jun 2012
          • 19
          • united states
          also how would i check a the capacitor?
            With a multimeter... but post some pictures so we can highlight the possible ones.
            I guess the TV is shutting down because it is not seeing the T-con working. I have not worked on any Sony TVs so I don't know if this is how they do it. It seems kind of strange to me.
            • aerospacejackson
              • Jun 2012
              • 19
              • united states
              ok just one minute ill have a picture to post
              • aerospacejackson
                • Jun 2012
                • 19
                • united states
                here it is
                • aerospacejackson
                  • Jun 2012
                  • 19
                  • united states
                  This is going to be my first adventure into surface mount soldering so if you have any pointers there i appreciate it
                    Can you see those light brown rectangular shape, they should have something like Cxx next to them, they are MULTILAYER CERAMIC CAPACITORS (MLCC).
                    Set your Ohm meter to 200 Ohms range and just measure the resistance on both end of each cap, we are looking for something in less than 2 Ohms (the resistance had to be low enough to blow 7A fuse) if they are bad.
                    • aerospacejackson
                      • Jun 2012
                      • 19
                      • united states
                      not sure what you mean about setting it to the 200 ohm range, the multimeter im using is a fluke 115 truerms multimeter when i set it to ohms it looks like it has an auto setting the the side it has a M and the ohm symbol. when i put that on any of the ones next to the fuse (c372. cd253) they read between 6 and 8
                      • aerospacejackson
                        • Jun 2012
                        • 19
                        • united states
                        but the fuse just reads OL as if it was open
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          6 and 8 what? Ohms, k ohms, M ohms? If unsure, press hold, take a picture and upload it.
                          --- begin sig file ---
                          --- end sig file ---
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            Hello, a tv repair place has identified my TCON board as being bad offered to fix it for 300 dollars, .
                            What a complete ripoff!!
                            • aerospacejackson
                              • Jun 2012
                              • 19
                              • united states
                              M ohms, at least the guy was honest, he said "we can fix it for 300 but i wouldnt recommend it. Since the screen itself is going bad, i just want to get this fuse fixed and hopefully buy a few months out of it.
                                "but the fuse just reads OL as if it was open" that is correct reading since you have blown fuse.
                                I think you can activate manual range setting of your meter, see your user manual.
                                • aerospacejackson
                                  • Jun 2012
                                  • 19
                                  • united states
                                  when i activate manual at the bottom it has a 6 and then when i press range again it goes to 6 0 then 6 0 0
                                    Lets do this, put meter in Ohm mode, then short the test leads together and then step through the range and tell us what you see.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Since I have a Fluke 117, you want the one that says 600 ohms. This is the lowest scale.
                                      • aerospacejackson
                                        • Jun 2012
                                        • 19
                                        • united states
                                        I have placed the fuse on top of the old one and soldered the ends, the tv fires up now and does the same thing it did before regarding lighting but no picture but the problem where it shut itself down has stopped. Any ideas?
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • gersrt
                                          Ordered Wrong TCON Board For Sony TV, Can I flash Epprom
                                          by gersrt
                                          HI
                                          Made a mistake and ordered the wrong TCON board to replace in my KDL-46HX823, the board I ordered was Sony PLY 1-883-893-11 which is sort of correct.
                                          But later realized this board is used in 4 or 5 models, any way the one i got sent was for KDL-55HX820.
                                          Physically these boards are identical, everything on the board is the same. I havent put this board into the TV yet, but am I right in saying all i would have to do is copy the Epprom from my faulty board and transfere it on to the new board, or is there still something else that may stop this working....
                                          01-27-2021, 05:49 PM
