Element flx-3220f-a Stuck in Standby
  • avaktech
    • Jan 2012
    • 68
    • US
    Stuck in standy, red light. No other signs of life when power button is pressed.
    169 volts to inverter board no change when pressing power button.
    No visually bad caps that I can make out.
    Where do I go from here?
    Re: Element flx-3220f-a Stuck in Standby
    Check the diodes with your multimeter on the diode range. Check on the inverter board.
    • avaktech
      • Jan 2012
      • 68
      • US
      Sorry, kids made me drag em to the playground ill see what I can do when I get home
      • mu2
        • Oct 2009
        • 217
        I had an Element that had a bad on the power supply board. Your board looks similar. Check the diodes right above the yellow transformer.
        I recall that it was a fast recovery diode and either Digikey or Mouser had the exact part.
        If you find a bad diode, I can look up the part number that I used.
        Mike
        • mu2
          • Oct 2009
          • 217
          I looked back through my records and it was an FLX3220F-A that had the bad diode.
          The replacement was an FR154-B, which I purchased from Mouser. Their part number is 583-FR154-B.
          Haven't checked to see if they still carry the part. The tv is still working after a couple of years!
          Mike
            Lack of a heatsink on those diodes mean they run hot.
            Hotter diode = shorter lifespan.
            Inevitable failure. Especially as the inverter is probably drawing a good 4A.
            • avaktech
              • Jan 2012
              • 68
              • US
              Ok thanks for waiting guys. Pardon my ignorance but what kind of result am I looking for? I gather I would check both directions but would should I expect to see?
                Working: 150 - 700 one way, OL or a single "1" the other way.
                Faulty: Same reading both ways <50.
                • avaktech
                  • Jan 2012
                  • 68
                  • US
                  Is it possible for me to have several bad diodes?
                  • avaktech
                    • Jan 2012
                    • 68
                    • US
                    I'm gonna need to see if I can scrounge some up out of my donor pile. I'll post back when I get another chance to play with it. Hopefully tonight. Kid duty now, moms working.
                      Unlikely, but possible. When the diode goes bad it shorts. This *usually* triggers a current limit on the power supply. However, if the current limit is badly designed it may be able to damage the other diode. If you remove the diode and the others still show as shorted, then you might have another few. They are 20 cent parts, though.
                      • avaktech
                        • Jan 2012
                        • 68
                        • US
                        Hey Mu6, was the bad one on your set at D637? Thats the one that is most questionable to me, its reading 001 in both directions. Several others seem off but not as much as that one. BTW thank you everyone for the help.
                          Definitely bad. Pull it out and re-test to confirm, then note the part # written on the diode body.
                          • avaktech
                            • Jan 2012
                            • 68
                            • US
                            Tested bad on the bench too. How close do specs have to be for something like this? Can I throw something close in or would I be better off waiting for the right part? unfortunately i am a very impatient person.
                            • avaktech
                              • Jan 2012
                              • 68
                              • US
                              Ok, plucked a higher voltage rated diode from a PC power supply. I cut the old diode off at the legs and soldered the new one right to the old legs. Fired it up and i works a treat! Kiddies get a tv downstairs! Cant say how thankful I am for the help Tom66 and MU2, thanks for holding my hand. lol I posted a pic of my handywork for those interested.
                                Good idea taking it from a PC power supply but only if you pulled it from the output diodes. If you took one from the primary side it's possible it wasn't a fast recovery diode and that will mean the diode could fail soon. I'm glad you got it working.
                                • lepak06
                                  TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                  by lepak06
                                  Hello
                                  I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                  The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                  Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                  All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                  But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                  01-12-2023, 01:43 AM
                                • toty79
                                  Hisense LTDN50K220WSEU stuck in standby
                                  by toty79
                                  Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                  As per Hisense tv title LTDN50K220WSEU stuck in standby
                                  PSU rsag.820.5687 HLL 4855WF
                                  Main rsag 7.820.5842
                                  I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                  05-01-2022, 04:39 PM
                                • lego1234567
                                  LG 32LB1R - stuck in standby mode
                                  by lego1234567
                                  Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                  What could be the problem ? Thanks...
                                  01-21-2024, 03:39 AM
                                • Stunt
                                  Hp Laptop Stuck on Hp protected by hp sure start screen
                                  by Stunt
                                  Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                  I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                  I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                  Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                  screen that's it and stuck there. I left it until the following day and i still...
                                  09-02-2025, 01:51 PM
                                • Rusenga
                                  Samsung UA39EH5003R Stuck on standby
                                  by Rusenga
                                  Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                  Connector CNM803:
                                  TV ON
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                  TV OFF
                                  Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                  09-18-2021, 11:51 AM
