storm season is here.long run ups mods
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    these apc units do nicely on large external batts.
    you can see how simple it is once you see the battery connectors and remove disconnect.replace with the battery connectors and hook up external cables.will post pics later as database seems broken
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: storm season is here.long run ups mods
    my UPS's batteries are dead as hell. Of the 3 UPS's I have, one was blown up last year by lightning........go figure.
    Database seems broken? Do tell, seems good here.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      - in the morning i got a database error one time when viewing a thread
      - three users complained about database error when they tried to upload attachments
      - i tried to fix one users attachment and got database error
      better check the logs....no smoke without fire....i hope its something minor
      attachments is working now....strange
      nope its broke again
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        seeing the same.... checking it out.
        Team : 49813
        Join in!!
        Team Stats
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          test
          Seems to be ok. I was implementing a HUGE database for a car site last night, I had to change some settings. I changed everything back. Please report any further errors.
          Thx.
          Team : 49813
          Join in!!
          Team Stats
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            works for me too. many thanks.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              i will post the pics tomorrow.
              post the brands of your ups's and i will tell you whether they are good for long run/external batts.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                somehow the other pics got corrupted on a bad floppy.
                next set will be a ibm 12v unit that now has a 12v 50ah wheelchair gel battery attached and a lighter socket with 15a breaker for charging cellphones,ect and a white led for a nightlight.
                • dood
                  Deputy dood
                  • Mar 2004
                  • 2462
                  How does the stock charging circuit deal with the added batteries? Is this something I could do with my standard APC 350va UPS? I think that battery is 6v, and it only has a single batt, but I could be wrong. Even if it is 6v, you can still buy 6v batts at lawn and garden or motorsports shops. Do you have to have any special type of battery, or will any old lead-acid battery do? What specs should you look for that will give you the approx runtime?
                  Ludicrous gibs!
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    dood; I've been told by APC that it is not a good idea, there is risk of overloading the charger, and then you will have a very useless UPS...
                    • arneson
                      • Sep 2005
                      • 1267
                      I've done this a couple of times, and my intention was to use the old UPS as a small power inverter.
                      My bank of batteries were able to recharge from the ships engine alternator when under way. I don,t think these units have the ability to bring back a set of deep cycle batteries when they are down.
                      Jim
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        apc units like the 1400 i had hooked up there do just fine with an external battery.
                        charging is limited to about an amp so expect slow recovery if you deep cycle it.
                        been doing these for about 10 years and no failures.of course the mfr will discourage such use.its called cya.(cover your a$$)
                        we live out in the sticks here and sometimes every severe thunderstorm or ice storm takes out the power here.i setup most of my neighbors with these and they have been very happy.
                        • brianl703
                          • Dec 2007
                          • 8
                          I have an APC Smart UPS 1000 (not sure of the exact model--it's a 4U unit that originally had two 12V 7AH batteries in series. One of the older beige-front units, not the newer black-front ones).
                          I modified it to use two marine deep cycle batteries (Costco Kirkland Signature 85AH group 24 batteries--made by Johnson Controls). It can power a Dell Optiplex 260 with a 15" LCD screen (the Optiplex was running Folding at Home so it was consuming more power) for about 14 hours. It was pulling about 6 amps from the batteries with that load, so I figure it was around 120-130 watts.
                          I put a 60-amp fuse inline with the batteries, and used 10-gauge wire. Thicker wire probably would have been better but I'm not loading this UPS anywhere near it's max.
                          This UPS has a fan in it. It seems that if you're going to add larger batteries to a UPS, you want one with a fan. The fan actually didn't even work so I replaced it (24V muffin fan) when I figured out that it was never coming on.
                          I find that I only need to add water to the batteries once every few months, even though the float voltage of the APC Smart UPS is higher than optimal for a flooded lead acid battery.
                          Interestingly enough, it charges the batteries at 10 amp rate after a power failure. Pretty odd given that it had two 7AH batteries in it, but this charge rate is perfect for the 85AH deep cycle battery.
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            lol thats probably why smartups generally toast SLA early
                            • pentium
                              • Mar 2006
                              • 2778
                              I had a random battery fault that tripped mt UPS in a power failure last winter (idiot drove into a three phase pylon) and if it does it again I better go and start switching over to the deep cycle battery I have stored in the shed. Actually, I better go see if it's okay.
                              Find Nedry!
                              Check the Vending machines!!
                              <----Computer says I need more beer.
                              • Askbart
                                • Mar 2011
                                • 1
                                How about the Tripp Lite Rack Mount SMART2200RMXL2U Can I fabricate something to us its existing External Battery Pack Leads that are build in?
                                I see you choose Gel and not AGM batteries; is that because the build in battery charger of the UPS is designed for Gel and not AGM?
                                • CapLeaker
                                  Crimping CAT7 connectors high failure rates
                                  by CapLeaker
                                  I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                                  Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                                  11-09-2024, 04:11 PM
                                • Eniaro
                                  Are USB C connectors standard
                                  by Eniaro
                                  I have a number of laptops with damaged USB-C connectors.
                                  I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                                  I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                                  I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                                  07-24-2023, 03:07 PM
                                • Alain Renteria
                                  LG OLED77G2PUA Not Powering On After Storm
                                  by Alain Renteria
                                  Got it for free on marketplace because it stopped working after a storm.
                                  When I began troubleshooting the power supply, I fried 2 fuses and a mosfet by shorting 2 pins on accident, but I've replaced those components.
                                  The tv had a soundbar connected, which was also killed by the storm. On the tv side I found a transistor shorted on the hdmi 2 (arc) and a lot of capacitors shorted on the main board.
                                  Disconnecting and reconnecting the psu to main board cable, while still being connected to 120 V AC, would wake things up, such as a red light from the optical...
                                  11-25-2024, 11:11 PM
                                • Maxim Bojko
                                   Palit RTX 2080 Super Jetstream Mats/Mods help
                                  by Maxim Bojko
                                  I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
                                  After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash...
                                  09-18-2024, 04:18 PM
                                • chronic519
                                  Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                                  by chronic519
                                  Hello.
                                  GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                                  Found issue with a RAM block
                                  Replaced, green lines gone.
                                  Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                                  Used a good card to test and same results low errors 32+.
                                  I am just search for some form of command to do a full test on the GPU.
                                  I just ran the mats command with my good GPU and passed after roughly 40 min.
                                  The repaired one, ran...
                                  05-20-2025, 07:56 PM
