Viewsonic VX2250WM - LED!
  • Ritalin
    • Sep 2010
    • 194
    First LED repair which will be quite exciting yet nervous cause this model is only 6 months old and I did a few basic google searches and so far no real information on repairs. Taking this thing apart was a real treat cause it is alot thinner than traditional monitors and has 3 thin ribbon cables running to the panel. Not to mention there is a 3rd board in the little chassis.
    Symptom: Plug in, now power, no light, no nothing.
    So far for visual inspection, no blow caps or cold soldering or board burn marks.
    Even though I know what I should check, I'd like to take a systematic approach to repairing this monitor to get practice rather than jumping to the obvious. So, if anyone has a list of 'to-dos' that would be greatly much appreciated.
    (Sorry for the bad pictures, didn't want to set up my normal lighting tonight to take 6-8 pictures. BTW if you click on the pictures below, it will open a window within this one, click on it again and it will open the picture in the new tab, and you can click on it again to get a larger picture)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viewsonic VX2250WM - LED!
    No Warranty?
    Check for AC mains x 1.414 = roughly 165V DC voltage across the large capacitor (C804). If present, check for secondary voltages to the logic board. If not present, check for blown fuse or shorted bridge rectifier.
    --- begin sig file ---
    --- end sig file ---
    • Ritalin
      • Sep 2010
      • 194
      Originally posted by retiredcaps
      No Warranty?
      Original owner lost proof of purchase and claimed they called and were denied replacement.
      • PlainBill
        • Feb 2009
        • 7034
        For a 'totally dead' problem I usually check the output of the power supply first. If there is no output, I go check across the large cap. I prefer to keep the probes away from them whenever possible.
        PlainBill
        • Wizard
          • Mar 2008
          • 2296
          Yours is first ever to grace badcaps forums with this LED backlight monitor.
          Cheers, Wizard
          • retiredcaps
            • Apr 2010
            • 9271
            PlainBill's method is safer. I now use aligator clips leads when possible for measuring the main filter capacitor.
            • seanc
              • Nov 2008
              • 1319
              That mains cap would be a pain in the ass to find a replacement for. Looks like some custom made job.
              What is its rating?
              • Ritalin
                • Sep 2010
                • 194
                Looks like I'm just going to RMA the sucker even though I'm not the original owner. So this will not be the first LED repair of badcaps.net
                • seanc
                  • Nov 2008
                  • 1319
                  Can you even do that now you've opened it?
                  • Supa
                    • Mar 2011
                    • 1
                    Just a FYI. I recently came across one of these VX2250WM exhibiting this no power/lights symptom. My work has lots of them so I was able to compare it to another and found that the power button was stuck in due to a design flaw lip ridge in the button cavity and an overzealous user mashing it in past the lip so it was stuck. I confirmed on the spare that holding the power button down when plugging it in caused it to look dead. There was no way to pry the button out from the front so I took the stand off and drilled a small hole through the clear plastic behind the button and push it out with a paperclip. Has worked fine ever since.
                    • jetadm123
                      • 2169
                      Hah hah! Great work! Now to keep a lookout for people advertising "dead" VX2250's!
                      • vxuser1
                        • May 2011
                        • 2
                        Bought the VX2250WM and after 3 weeks it died. The blue light on/off button is constantly lit, but there's nothing on the display, tried connecting to different computer with VGA or DVI with no luck.
                        I used my spare monitor and forgot about this one. One week later and I plugged it in and it started working again. Alas after 4 hours it died again, but this time the blue light is off.
                        Left it unplugged for one night and hey presto it works again. Well I've called tech support and they will pickup and hopefully fix this annoying problem.
                        The other problem it exhibits is after running for about 15 mins, you can't switch the monitor off from the on/off button.
                        • blackmtx
                          • Oct 2011
                          • 1
                          hi, same problem of mine, did you fixed/repaired already?
                          • vxuser1
                            • May 2011
                            • 2
                            yes, they replaced with new monitor, work fine now.
                            • grether
                              • Dec 2011
                              • 1
                              I also have a Viewsonic VX2250 with an odd problem. The menu button (not really a button, but more of a touch sensitive area) is stuck on. It usually brings up the menu after a few minutes of the monitor being on and uncontrollably scrolls through the audio adjust menu. If I turn the monitor off and on it comes back after a few seconds or minutes. HELP!
                              • MarcusNH
                                • Oct 2012
                                • 1
                                I've had the Viewsonic VX2250 monitor since 12/2010. In the last few months it has ocassionally gone black for a few seconds, then return. The blue power light remains on, and remains blue at all times. Recently, this is happening more frequently. I've updated the driver to Win 7-64. I've run the monitor on another computer and have the same problem, so I have ruled out driver and graphic card as the problem. I'm thinking that I have a leaky cap on the power supply board of the monitor. Has anyone else had this problem? Am I headed down the right path? Has anyone replaced the caps or do you know of a YouTube video that shows which caps to replace? Thanks for your help!
                                  VX series and actually just about all the Viewsonic monitors failed due to bad caps, that will be the first thing to look for.
                                  See my pictures of failed viewsonic here:http://s807.photobucket.com/albums/y...udm/VIEWSONIC/
                                  You will replace them as a set of caps.
                                  • nicholas hu
                                    • Jun 2011
                                    • 1
                                    hi all ,
                                    i am a lcd repair guy from Taiwan , just solve a failure case vx2250wm same as told of 16f , found x101 almost malfunction ( not totally dead ) , please using scope touch the pins of x101, if system shutdown ( it should not ) ,
                                    then please try replace the x'tal about 12.000mhz.
                                    the amptitude of frequency was lower then a normal item , when scope touching , the amptitude gone , then it will come back again in few second , the picture maybe goes white or goes black with backlite on .
                                    and had backup the file about the firmware from pm25lv020 , if somebody need it please let me know .
                                    the caps was fine ,no need to replace.
                                    • gto4ben
                                      • Aug 2013
                                      • 2
                                      If anyone is interested, my monitor exhibited the same symptoms. No power, mo power LED ON. Clue was that the voltage across C807 was 7V. it should be 16V. Further measurements showed that the +19V rail showed 6 ohms to ground. The problem was traced to C504 ceramic capacitor (2.2uF, 50V). Removal of the offending capacitor cleared the problem. Replacement resulted in a working monitor.
                                        Where is this C807, the picture shows the board with 5xx designators? Power supply board? Thanks.
                                        • bohaboha
                                          Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                                          by bohaboha
                                          Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                                          anyhow i couldn't t read anything else
                                          the backlight is on strong and the screen does not get dark or very dark but no pictures
                                          the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                                          01-02-2025, 08:04 PM
                                        • valvashon
                                          LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                          by valvashon
                                          The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                          Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                          11-24-2024, 12:08 PM
                                        • cnti
                                          Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                          by cnti
                                          Hi.
                                          BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                          This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                          BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                          RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                          burned, measured 10M ohm.
                                          QM801 [real PSU:...
                                          10-19-2023, 05:33 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
                                        • 2elw
                                          SVOD4 PCB pictures + parts
                                          by 2elw
                                          Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                          STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                          GW1N-UV9UG169C6/I5 FPGA - Its a...
                                          07-04-2025, 12:23 PM
