Viewsonic VX2250WM - LED!
  • bohaboha
    Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
    by bohaboha
    Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
    anyhow i couldn't t read anything else
    the backlight is on strong and the screen does not get dark or very dark but no pictures
    the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
    01-02-2025, 08:04 PM
  • valvashon
    LG 55UH6150- trouble powering up, then half lit screen (pictures!)
    by valvashon
    The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
    Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
    11-24-2024, 12:08 PM
  • cnti
    Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
    by cnti
    Hi.
    BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
    This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
    BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
    RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
    burned, measured 10M ohm.
    QM801 [real PSU:...
    10-19-2023, 05:33 PM
  • lostone
    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
    by lostone
    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
    05-19-2024, 11:40 AM
  • 2elw
    SVOD4 PCB pictures + parts
    by 2elw
    Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
    STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
    GW1N-UV9UG169C6/I5 FPGA - Its a...
    07-04-2025, 12:23 PM
