NEC Multisync 1550v Dead (so's my brain)
  • smason
    • 1652
    I wasn't going to bother with this one, got it in a batch of 7 dead LCD monitors. I usually only do 17" and above, but this little NEC looked nice, and there's probably someone locally that has a dead monitor, and can't afford to replace it, that would "settle" for a 15.
    So I plug it in, dead. No power light - nada.
    I disassemble it, and it looks like a nice quality unit. I used to think NEC made great monitors, though had quite a few 17" CRT units fail in the mid-90s at a company I worked for.
    So anyway, I figure I've got reasonable troubleshooting skills. I'm no PlainBill, but I do ok.
    The main fuse is obvious, a glass fuse right near the power connector. I test it, .2ohms. OK, I'm surprised but move on. Apply power and measure the big cap. Nothing. 0vdc. Ok, maybe the bridge rectifier failed open.
    So I'm about to remove the power supply from the bracket, unplugging connectors, and there's this 2 pin connector with fairly large wires on it.
    I think, oh that's the ac power input. Wait... no the power connector is on the board. These wires go to.... the master power switch. D'oh!!!!
    <slaps forehead>
    So I turn the master switch ON, and push the power button.
    Monitor comes up, seems to work just fine! Looks like someone recycled it just 'cause it's small.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: NEC Multisync 1550v Dead (so's my brain)
    Been there, done that. No power... No standby... fuse ok... it is plugged in... OH WAIT THE POWER SWITCH IS OFF. Happened quite a few times while working on computer PSUs.
    A working TV? How boring!
    • retiredcaps
      • Apr 2010
      • 9271
      A friend gives me his friend's 32 inch TV to fix. He says there is no power LED at all. It is a Chinese Tatung with no english manual, schematics or service manual. Great, I'm going to be using every bit of knowledge I gained over 10 months to fix this.
      Go home, plug it in and sure enough no power. Push the front panel power on/off switch and nothing. So I lay out the tools, camera, multimeter, etc. Just about ready to unscrew the first screw and see a quarter size on/off button in the back.
      I replug in the TV and hit this button. The red standby light comes on. Okay, maybe the owner turned it off or I maybe pressed it to the off position by carrying the TV next to my body?
      Press the front panel on/off switch and the power LED goes green and it displays AV2 for a few seconds and goes black. Damn, 2 seconds to black. Okay I have done enough of that type of troubleshooting, so no worries.
      Then I cycle through the source button and for cable, it displays static. Odd! I haul out a dvd player, put in a movie and switch source. It plays the dvd. Wait 30 seconds, hmm, it is still playing the dvd. Leave it running for 2 hours, still working.
      Turn it off, turn it on. No problems. I leave it off overnight. In the morning, I turn it on and it plays the dvd no problem.
      I phone my friend and say I can't find anything wrong so I return TV.
      Apparently, neither of the 2 knew about the master switch button in the back. This TV was shipped by the owner's parent from the far east and the owner didn't know it had a master switch in the back.
      Now I know why the technical writers for the user's manual put in the following troubleshooting steps: check power, check connector, make sure the master power button is on, etc.
      --- begin sig file ---
      --- end sig file ---
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        I had the same with 2 NEC 1770NX models ,
        bought them in as dead and went to plug in power lead and see small on off switch right next to the plug point flicked the switch to on and hey presto
        both monitors fully functioning.
        Still running ok 1 year later .
        • jetadm123
          • 2169
          See these on/off switches a lot on aftermarket ATX computer power supplies. Funny how many times when someone moves their computer, they accidently run their hand across the switch and shut it off. With manufacturers spending as little money as possible using cheap caps, it makes you wonder why they would spend the money on a on/off switch.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            A on/off switch that only cuts off ONE side of the ac line at that.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4958
              • New Zealand
              I once forgot to plug in the main ATX connector and shit myself thinking I had killed everything....
              -David VanHorn
              • cruiser_
                A1342 820-2567-A brain dead
                by cruiser_
                hi everyone,
                i've got this ancient board here, repairing it as an exercise really. it seems to be brain dead.
                upon triggering start via SMC_ONOFF the fan starts to spin, USB powers up, CPU gets hot but there is no further activity.
                nothing on the video output, no USB activity (using pendrive with an LED).
                I've read the bios, it looked ok, valid checksums, model/.mb match etc.
                I cleared VSS and wrote the bios back. NO change.
                any suggestion as to what might be the cause of this?...
                12-02-2023, 04:19 PM
              • marce002
                Help Brain DEAD A1286 820 3330
                by marce002
                Hello, NO BRAIN A1186? Core i7 a1286 mid 2012
                no water damage. around 440mah power and fans at full after a minute
                no image no chime start fans amber and green magsafe 1 ok
                I have u7400 with EN ok (pin 47), and 5V at (26,19 and 46), TONA and TONB around 12,4V both (pin 48 and 1), missing CPUIMVP_AXG_PGOOD pin 12
                Boards stays on if RAM is removed doing same thing.
                is brain dead?, what else to test to make sure it is?
                thanks in advance
                07-20-2022, 01:43 PM
              • paparazzo79
                Logitech MX Master 3 dead
                by paparazzo79
                I started having issues with this mouse on my laptop.
                Sometimes it works something don't.
                The only way when it stops to work to make it work again is to push usb dongle little upwards,probably so it can make better contact with USB port on laptop.
                But from this morning it doesn't work at all.
                On same USB port other wireless mouse works pretty normal.
                I tried on second laptop same MX master,northing simply dead.
                Now I plugged in USB dongle to one of my desktop PC which really has nice USB port and dongle doesn't...
                10-04-2021, 12:15 AM
              • double_DD
                How can I be sure that my EC chip is dead?
                by double_DD
                As the title suggests, how can I be sure that my EC chip is really dead?
                I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                03-12-2025, 07:47 AM
              • disorder
                ps5 edm-033 dead after hdmi/usb ports destroyed
                by disorder
                hello guys,
                i need help to repair a edm-033 ps2
                history : as always hdmi port and usb ports destroyed after unplugged
                after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                so i changed it
                now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                i don't see any projection of liquid metal on pcb.
                01-14-2025, 12:48 PM
