Do you got Evercon datasheets ?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Do you got Evercon datasheets ?
    Capsun's products list.
    http://www.szcapsun.com/en/product.asp
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I'm not seeing anything that makes sense as a cross reference.
      They make caps to order so presumably who ever orders can have them marked with their own series code.
      - Dr Seuss
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Originally posted by mockingbird
        Now that we're on the topic of this defunct manufacturer, I have a "GSC" cap, which uses a similar namesake to this Evercon cap, and I would love to know it's official specification:
        "E5NK", 16V 470uF.
        Now that I've seen the picture....
        That isn't an NK series.
        E5NK is the date code.
        That cap probably dates back to when GSC only had two series and they went by the sleeve color.
        RE was Green.
        LE was Black.
        I think you have an LE there.
        - Dr Seuss
        • Agent24
          I see dead caps
          • Oct 2007
          • 4962
          • New Zealand
          The datasheets I got were from a WebArchive copy of http://www.gsc-cap.com/ from 2004 - does that seem old enough?
          -David VanHorn
          • mockingbird
            • Dec 2008
            • 5484
            RE was Green.
            LE was Black.
            PCBONEZ - You are the man!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Just a trivia
              GSC full name = GEN SALES ELECTRONIC CO., LTD
              http://web.archive.org/web/200302050...sc-cap.com.tw/
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Yes.
                They made the LE and RE series from sometime in the 90's until they went *poof* [or at least their site did] in 2005.
                Both of them sometimes had the series marked and sometimes not. Had to go by the colors.
                Then in '07 Evercon showed up at http://home.so-net.net.tw/gsccap/NEW/e-p1.htm.
                It showed both Sacon and Evercon info for a while.
                Then that site went *poof* in 2008 - just about the time the crap FZ series were getting famous.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Which archive were you able to access data sheets at?
                  - Dr Seuss
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4962
                    • New Zealand
                    #29
                    -David VanHorn
                    • Gabriel
                      • Jan 2010
                      • 620
                      • Norway
                      #30
                      @PCBONEZ
                      Thanks for your pm - I will have a look at the Panasonic FM.
                      Are they easy to get on Ebay ? I see they are not sold here on badcaps netshop.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Originally posted by Gabriel
                        @PCBONEZ
                        Digikey carries them.
                        I think Mouser does too now.
                        - Dr Seuss
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4962
                          • New Zealand
                          #32
                          RS-Components have some too and so should Farnell
                          -David VanHorn
                          • Ady2017
                            Are there any datasheets available for Elna RJG capacitors?
                            by Ady2017
                            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                            05-25-2025, 02:19 PM
                          • CdDvdFlash
                            Please teach me how to find datasheets to obsolete caps
                            by CdDvdFlash
                            I've got a Toei arcade CRT chassis and printed on the PCB is CM-R14 but it might be a CM-R20 and so far needs two caps replaced, I've looked on the Nippon Chemi-Con site and got their 2020 catalogue I cant find any info about the first cap in the catalogue or on their obsolete catalogue, on the cap is:
                            (Radial electrolytic cap) Nippon Chemi-Con 1uF 160v 85c 8mm diameter, roughly 15mm long (cap is bulging at the legs) with 6mm PCB hole spacing, the chassis service manual says this cap C58 is a CE04W with "04" in a smaller font than the capital "CEW" so it must be...
                            08-12-2023, 12:29 PM
                          • Tomek188
                            Looking for datasheets for EN7521 and MT7520
                            by Tomek188
                            I need datasheets for EN7521 and MT7520 (similiar chips). This is GPON ONT.​
                            01-17-2025, 01:47 PM
                          • petehall347
                            100nf and 100uf precision capacitors
                            by petehall347
                            i am wanting to calibrate my multimeters and for this i require a 100nf and 100uf precision capacitors . trouble is i can't find them ....
                            08-13-2024, 06:56 AM
                          • ten-d
                            Nippon Chemi-con 100uf 100v BP electrolytic cap
                            by ten-d
                            Hi all!
                            I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                            01-30-2024, 05:18 PM
