iPad 7 A2197 - no power
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Re: iPad 7 A2197 - no power
    I don't have another battery for testing, but I think it's not necessary, since there is a problem with PCB.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      Here are measurements of charge port connector.
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        There is also 5V, so connector looks OK i think.
        • vahamb
          • Sep 2019
          Originally posted by elecsoluces
          no power : check first PPBATT_VCC and PPVDDMAIN.
          Inject 4V/3A to PPBATT_VCC and try to boot the device. Report the current draw on your power supply.
          Sorry for jumping in. If I could ask some help figuring out with same model dead. . Plug the charger amps go up hit 1.6 and reset. Nothing on the screen. PPBATT_VCC is fluctuating between 0 and 1.37v. Injecting voltage to PPBATT_VCC 0.68 amps driven from dc power supply, then go down to zero All other rails seem present. Tristar replaced with no positive change. Looks like pmic is getting reset signal but don't know how.
          OP needs cpu reball I think. That's pretty common fault on these.
          • vahamb
            • Sep 2019
            Ended up being bad q8504 on PPBATT_VCC rail.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #26
              So, you think, the CPU is bad? Reballing this is unreal for me, I think. This is bad news. I hope there is some short somewhere, but I didn't find anything yet.
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                #27
                I tried to reheat CPU and now the current draw without battery connected is about 0.280A. Still won't power on.
                • willis6732
                  A2197 / Ipad 7th Gen / 2019 - No Power / Low Current Draw
                  by willis6732
                  Ive been working on this ipad for a little while now. CPU reballing is a common issue needed on this model.
                  I wanted to try and verify there is not a PMIC Problem before reballing the CPU.
                  Powering 4.2V at the battery gives a 0-1ma Draw
                  Pressing the power button it jumps to 18+ma and settle at 15ma
                  Ive attached my Readings for many of the power rails.
                  THis is how the columns are layed out:
                  Ohms/ Diode / Voltage After power button Press / Injecting Voltage Reading
                  In the second...
                  10-13-2023, 04:43 PM
                • GeirAndersen
                  iPad .pcb file collection
                  by GeirAndersen
                  I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                  Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                  IPAD COLLECTION 1
                  +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                  +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                  +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                  +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                  +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                  +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                  12-09-2024, 09:28 AM
                • proxneo
                  iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
                  by proxneo
                  Dear reader
                  TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
                  I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
                  12-01-2023, 04:14 AM
                • jolivares
                  NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
                  by jolivares
                  I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
                  This is what i found until this moment:
                  1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
                  2) no short circuit in lines VCC_MAIN, VCC_BATT.
                  3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
                  4) the current draw from the power supply, without battery, is about 26mA from the charging...
                  07-15-2024, 09:24 AM
                • waterchill
                  iPad 7 A2197 dead
                  by waterchill
                  So I have here this board which is dead. Current without battery is about 25mA with battery 470mA. I checked all voltages, missing this one:
                  PPVDD_GPU
                  PPVDD_GPU_SRAM
                  PP1V8_TOUCH_EXT_SW
                  PP3V0_ALS
                  PP3V3_ACC
                  PP1V25_REAR_CAM
                  I don't know if these voltages are coming up, when iPad is booting. I have changed the PMIC without any result.
                  The PPVDD_GPU line have 8,2 ohms and in diode mode it is short. I have injected 0,8v in this line, only the A10 chip is getting slightly warm.
                  Any ideas?
                  05-12-2023, 02:46 AM
