Plasma Y board IGBT equivalency question
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    I have two TVs here with both Y-SUS failures, one LG and one Samsung.
    The Samsung's Y-main shorted one FGD4536 and one RJP63K2(there are two in parallel)
    I have the FGD but I only have one RJP63F3, which is different from the K2, so, can two 30J124 be put in place of two RJP63K2? are they equivalent?
    Also for the LG two 30F131 shorted, I have some FGD4536 (the same that are used on the samsung), can they be also be a substitute without issues?
    RJP63F3 and K2 are 630V 30A IGBTs, but their rise/fall time and other internal variants differ.
    30J124 600V
    FGD4536 360V
    30F131 360V
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Plasma Y board IGBT equivalency question
    Well, no one bothered to answer.
    I will report then, LG TV, 30F133 or 131 and FGD4536 are interchangeable, but the sus board was not operating normal, the image has some issue with proper sustaining and after increasing VS by 5% and resetting the configs, the tv powered up on a static background + white menu with energy saving disabled, that put a enormous strain on the Y board and it died again, **** off.
    I have not tested the 30J124s in the Samsung yet.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      be nice to know the model #'s. pics ?
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        I did not open the thread to ask for help with the repair, just the IGBTs thing, ended up discovering on my own.
        Well I repaired the samsung Y board, it is a E series 43 inch, fault is as follows:
        1 capacitor 331k 1kV blew up and shorted a RJP63K2, FGD4536 and a SF10A400HD diode, replaced the RJP pair with 30J124 and it works fine, however there are multiple black horizontal lines, I did not measure the buffer with care, it is faulty(open circuit on a lot of pins) and will need replacement.
        For the LG it is a 50PN series and my next move is to buy some scrap boards and try to replace the mosfet drivers.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          are you sure you have the ribbon cables inserted correctly ? common issue when replacing y board.
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            100%, like I said, all of the Y-buffer pins where there are missing picture are open circuit, while the others have the standard 0.8V.
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              Late update but, it is working perfectly now after wapping the buffer board.
              • nomoresonys
                • 12328
                • U.S.
                Have not heard of this before, can you explain.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Wapping is swapping minus an s.
                  • nomoresonys
                    • 12328
                    • U.S.
                    Lololololololol
                    • Biruslapio
                      • Nov 2013
                      • 552
                      • Brasil
                      oh... I was wondering why there were 3 responses and one of them a "lolololol", yes, I meant swapping, I don't even know if there is a slang called "wapping", but it cannot be good (google says it's part of london).
                      • nomoresonys
                        • 12328
                        • U.S.
                        LOLOL I thought it was a new technique or something.
                        • mikkele86
                          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                          by mikkele86
                          hello.
                          I have two power amplifiers, both having their IGBT blown on the PSU.
                          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                          So I though i missed a capacitor or diode. I removed...
                          01-06-2024, 06:45 AM
                          Hypertherm Plasma Chopper IGBT Module failure successful repair
                          by sam_sam_sam
                          I have several chopper units that need to be repaired but just repaired one of them to see if it could be done successfully which they can be repaired
                          The company that makes the IGBT module have discontinued this part as 5/30/2020 which our company has bought 12 IGBT modules which will allow me to repair 6 chopper units ( one note there is no direct replacement availability )
                          I am buying these modules directly from the manufacturer
                          But there is a 8 week lead time
                          Now you can find on EBay for half the price but I have a feeling that might be fake...
                          06-07-2020, 11:08 AM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • KYBOSH
                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                          by KYBOSH
                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                          No picture but you hear the TV static (white noise) playing loud and clear.
                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                          But it seems they didn't get too far and just left it.
                          When I first took a look I was amazed at how pristine the inside looked.
                          Its as if the TV had been in a time capsule.
                          Caps looked like they were just pulled off the self.
                          Copper coils had no sign of corrosion on...
                          02-01-2023, 11:10 PM
                        • alltvrepairs
                          Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                          by alltvrepairs
                          I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                          I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                          Any one met this problem in the past?...
                          10-08-2025, 07:34 AM
