Hypertherm Plasma Chopper IGBT Module failure successful repair
    • Jul 2011
    • 6070
    I have several chopper units that need to be repaired but just repaired one of them to see if it could be done successfully which they can be repaired
    The company that makes the IGBT module have discontinued this part as 5/30/2020 which our company has bought 12 IGBT modules which will allow me to repair 6 chopper units ( one note there is no direct replacement availability )
    I am buying these modules directly from the manufacturer
    But there is a 8 week lead time
    Now you can find on EBay for half the price but I have a feeling that might be fake
    If you buy the chopper units from Hypertherm at cost of about $1800.00 each
    I can repair them at cost of about $300.00
    I have 3 more chopper units to repair
    We have a total of 10 chopper units
  • npielawski
    MacBook Pro late 2016 (820-00239) with multiple failure modes.
    by npielawski
    I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
    I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
    10-15-2025, 01:53 AM
  • mikkele86
    Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
    by mikkele86
    hello.
    I have two power amplifiers, both having their IGBT blown on the PSU.
    The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
    I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
    I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
    So I though i missed a capacitor or diode. I removed...
    01-06-2024, 06:45 AM
  • puccovelli
    Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
    by puccovelli
    Hi all, I hope this is the right place to post.
    I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
    I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
    1] Could someone confirm what the component that has blow actually is (and where I could get another from).
    2] Whether this component is likely to cause the RAM failure issue, and if replacing...
    10-11-2025, 06:30 AM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    Replaced emmc.
    Terminal log
    UART
    AC_ON
    E-B
    FDE enabled
    06-01-2025, 02:11 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
