Dead ASUS ROG G14 (GA401)
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    Hi!
    It seems like all the laptops I get are dead G14's. I already had two, in which one was fixable, and one wasn't. This one is different though, I promise!
    The previous owner used it without a screen, as the panel was dead, and suddenly it just died.
    The board looks fine, no visually burnt components as I can see.
    I do not get a short on the DC-In mosfets, however as I had with one of my other machines, the first mosfet does not seem to let voltage through, so the second mosfet does not receive 20V. (See pic).
    Only the BQ chip gets a little warm when the board is plugged in, nothing else.
    I believe I detect a short around the caps at the bios chip (1 Ohm), not sure if they should be that low. I removed the bios chip, but reading is still as low.
    Caps at GPU area are 22 Ohm, so they are probably not short.
    All Mosfets measure in the K or MOhm range, except one, which is 200 Ohm at D-S, so not really sure what is going on there.
    I would have hoped that a completely dead PC would mean an obvious short somewhere, but nope
    The other G14 I had, had sign of life with USB-C charging, but this one seems dead.
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    Re: Dead ASUS ROG G14 (GA401)
    I injected 1V1A into the cap on the right of the bios chip which were 1 Ohm. The IT5125VG-128 IC on the back side got hot, could this be the culprit?
    • reformatt
      • Feb 2020
      • 1483
      No schematics or boardviews I think for this model. But yes looks like a failed EC.
      To confirm, I'd look for the +3.3V regulator IC on this board, find it's type and refer to the datasheet. Look for the +3V LDO pin on that, and check resistance to ground.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        There is a schematic and boardview here: https://drive.google.com/file/d/1hMZ...uyI_3v7nK/view
        I will check for the regulator when I get home from work, if I can find it.
        • jacobtc
          • Apr 2016
          • 274
          • Denmark
          I found this in the schematic, not sure if this is the 3V3 though. Having a hard time finding what makes 3V3...
          Im new
          EDIT: Also, some caps are very low resistance right above the lower mosfets.
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Should I remove the ITE EC and check if the short is gone? I will have to reball it again, if the short is still present though
            • reformatt
              • Feb 2020
              • 1483
              It's a convoluted design compared to most other laptops and I'm still scratching my head a little following what should be a simple path for powering the EC.
              +3VAO/+3VA (pin 3 of PU8701) is your LDO voltage. However +3VA_EC goes via load switch (PU8801) so if it's shorted it might read it on the other side of that load switch. So check resistance to ground for +3VA and +3VA_EC. Pg 101 has the power sequence diagram for further troubleshooting.
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                Thanks for you support! Yeah, the schematics are not easy to figure out.
                I checked both Pin 3 on PU8701, it was 4.6 MOhm to ground.
                I checked VOUT1_1 (Pin 13) on PU8801, and it was 1 Ohm to ground.
                How would I use the power sequence diagram? I guess it is for knowing the starting sequence of the components at boot, but how would that help me?
                Thanks!
                • reformatt
                  • Feb 2020
                  • 1483
                  Based on your previous post, that does sound like a shorted EC (U3001). You can use 1V voltage injection and thermal camera to confirm. Removing U3001 would be the next step to see if the short is gone.
                  No datasheets available for IT5125VG-128/CX, however the 128 suggests that it has 128k of ROM. Some EC's when empty download their code from the main BIOS chip automatically. Given I can't see any EC dumps on the web for this model seems to indicate that this is likely the case.
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    I injected voltage here (see pic).
                    How often do EC's die though? I am fearing that it is something else that is shorting the EC.
                    Yes, as I have reseached, especially Asus downloads to EC from BIOS at boot.
                    • reformatt
                      • Feb 2020
                      • 1483
                      They do go short. As to why who knows. Often it's because of some external event. Some Lenovo's have a direct connection to the power jack for adaptor sense. When the power jack disintegrates, you get 19V on a pin that should only take 3V and this destroys the EC.
                      But this is not the case in this instance. Asus laptops often have failures that many other brands do not. Have a look at Northridge Fix's channel and he always goes on about how shit Asus laptops are.
                      • jacobtc
                        • Apr 2016
                        • 274
                        • Denmark
                        Alright, I'll remove it and see if the short disappears 😅
                        • jacobtc
                          • Apr 2016
                          • 274
                          • Denmark
                          Also, IF I need to reball, how do I know what ball size to use, without a datasheet for the ITE IC available?
                          EDIT: I might go with solder paste and one of my universal stencils...
                          • rediii
                            h???, spurrrn
                            • Mar 2018
                            • 499
                            • somewhere in europe
                            if you want to use solder balls, just go to aliexpress and search for the ite chip model and a proper stencil. look on the pictures that will tell you the ball size. otherwise try universal stencils that will match in size.
                            • jacobtc
                              • Apr 2016
                              • 274
                              • Denmark
                              Removed the EC, and the cap that previously measured 1 Ohm, now measures 10 kOhm!
                              Is it safe to say that the EC was at fault? The EC is 20USD from Aliexpress, so I want to be somewhat safe before ordering one
                              Also, I guess that I should not connect power to the board without the EC, correct?
                              Thanks for your help!
                              • jacobtc
                                • Apr 2016
                                • 274
                                • Denmark
                                Yeah, I found a stencil that works, I might buy that if for some reason I have to reball a new EC IC.
                                • rediii
                                  h???, spurrrn
                                  • Mar 2018
                                  • 499
                                  yes, then it was at least ONE fault. there could be more. nice job . mostly it is not safe to connect power to a board without controller ics... but in most cases the board will be just brain dead and that's it.
                                  • reformatt
                                    • Feb 2020
                                    • 1483
                                    Yes EC is shorted, replacement should theoretically come pre-balled. I personally wouldn't power the board without it fitted.
                                    Replacement needs to be blank or off a donor board (of the same model) as well. I ran into some issues transplanting an EC with different programming once. I didn't have a 128 pin ZIF adaptor and thought I could reprogram it via the keyboard connector. Well it didn't end well and I won't be doing that again. To date, I've not seen any programming adaptor for the 128 pin BGA EC's.
                                    • jacobtc
                                      • Apr 2016
                                      • 274
                                      • Denmark
                                      Yeah, I will buy the part from SUHMS on AliExpress, so it should be all good!
                                      Hope it won’t die instantly due to some other fault on the board
                                      • jacobtc
                                        • Apr 2016
                                        • 274
                                        • Denmark
                                        Yeah, what worries me is if something else causes the EC to die, that would be 20 USD wasted if the new chip just dies instantly
                                        • Mabot17
                                          ASUS gaming laptop GL704GV GPU DEAD SHORT
                                          by Mabot17
                                          Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                          i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                          Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                          05-10-2025, 11:04 AM
                                        • ktmmotocross
                                          Asus UX433FAC - batery dead after short on VIN rail
                                          by ktmmotocross
                                          Hello.
                                          Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                          can that short shorted battery? batmon show that battery is full at 80%
                                          12-29-2022, 12:06 PM
                                        • OOF DIO
                                          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                          by OOF DIO
                                          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                          (Had 3 problems, now just 1)
                                          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                          04-19-2025, 05:03 PM
                                        • jkucukov
                                          Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                          by jkucukov
                                          I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                          During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                          02-05-2025, 09:27 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
