Dead ASUS ROG G14 (GA401)
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dead ASUS ROG G14 (GA401)
    It is absolutely safe to power a mb without EC. BGA EC's are mostly programmable thru JTAG but they are nightmare to program.
    • jacobtc
      • Apr 2016
      • 274
      • Denmark
      This will be programmed through the BIOS it seems.
      • rediii
        h???, spurrrn
        • Mar 2018
        • 487
        • somewhere in europe
        this is what i would say, too. i never reprogrammed the bga ite chips on asus laptops and if this ic was faulty replacing it resulted in a working machine...
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Agree, with Asus, ec is programmed from main bios on 1st boot. however, in other brands, its not always so.
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Well! Just received the new EC.. Soldered it, and checked that the short was still gone (it is).
            The laptop is still dead though, I still get 19V in to first DC-in mosfet, 0V out, next mosfet is 0V in, 4V out?
            I could just go ahead and solder all new mosfets on the board, but I have the idea of working blind, and just throwing stuff at it until it might work.
            • mon2
              • 14231
              Start with the basics as per the above sticky by @Piernov.
              1) Often the 2nd DCin mosfet gets killed.
              2) Which charger IC is onboard? Likely the BQ series? Share the full topside markings of the charger IC.
              3) Assuming it is the BQ series, the GATE pins of the 2 x DCin mosfets will be driven by the ACDRV pin.
              This ACDRV pin must be ~25v to enable the N-channel mosfets.
              Confirm the voltage to ground of the ACDRV pin.
              Also check:
              REGN
              ACOK
              ACDET
              Post each measurement.
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                #27
                Also check:
                REGN
                ACOK
                ACDET
                Thanks, you are always a great help!
                The IC is a BQ24780S,
                ACDRV (Pin 4) is 0V
                REGN (Pin 24) is 0.4V
                ACOK (Pin 5) is 0.4V
                ACDET (Pin 6) is 2.7V
                EDIT: And VCC (Pin 28) is present on IC at 19V.
                • mon2
                  • 14231
                  ACDRV (Pin 4) is 0V
                  Above in red are not good readings.
                  REGN should be ~6 volts.
                  Remove all power. Meter in resistance mode.
                  Check the resistance to ground of REGN pin # 24. What is the measurement?
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    #29
                    I don't know if it makes any difference, but the previous readings were done only with AC connected, this is due to the ASUS batteries somehow self-destructing by the smallest things, (I've had three of these boards kill the battery now).
                    With AC power removed, REGN is 10k.
                    • mon2
                      • 14231
                      When checking the resistance or diode mode values, all power must be removed.
                      With no power, REGN is fine @ 10k and is not shorted.
                      Ok to remove the battery and use only the recommended power adapter.
                      The REGN pin is a very basic LDO and should provide a low current 6 volt output. As long as the Vcc is stable @ 19v, this charger IC should supply a steady 6 volts.
                      Suggest to seek out a fresh replacement of this component. They are very inexpensive on Aliexpress.
                      • jacobtc
                        • Apr 2016
                        • 274
                        • Denmark
                        #31
                        Oh, I already have a bunch from last time I worked on a board like this. I'll get to replacing it ASAP. Thanks!
                        • jacobtc
                          • Apr 2016
                          • 274
                          • Denmark
                          #32
                          Alright, changed the BQ IC,
                          REGN is now 6V
                          When first installed, I plugged in power, and the second mosfet showed 20V out, all good.
                          Installed the board, plugged in power, and it is now back to 4V, and still no sign of life (no lights etc.)
                          REGN is still 6V though.
                          ACDRV is still 0V.
                          ACOK is now 6V.
                          ACDET is still 2.7V.
                          • mon2
                            • 14231
                            You are getting closer
                            These are good readings except for ACDRV which should be ~25v.
                            As per the Bible written by @Piernov - see the above sticky, often the 2nd DCin mosfet raises the fault you are observing.
                            On your board, you should have a ~4k resistor between ACDRV pin and the GATE pins of the DCin mosfet. If you can locate this 4k resistor, remove it off the board. Do not lose the part.
                            Power up again. Confirm if the ACDRV pin is now ~25v.
                            Often the 2nd DCin mosfet will cause the ACDRV voltage to tank.
                            Before starting, do confirm that the main power rail is not with a low resistance value to ground. A low resistance on the main power rail (ie. after the 2 x DCin mosfets) means there is a shorted component.
                            • jacobtc
                              • Apr 2016
                              • 274
                              • Denmark
                              #34
                              Yeah, had hoped it would work after the replacement, seeing 20V initially on the second DC-In mosfet
                              How would I go about finding the 4K resistor? There is quite the distance between the BQ chip and the second DC-In mosfet (many many resistors)
                              Also, ACDRV goes through a via in the board, so it makes it even more difficult to figure out.
                              • jacobtc
                                • Apr 2016
                                • 274
                                • Denmark
                                #35
                                Is this the resistor you are talking about?
                                • mon2
                                  • 14231
                                  Yes. Very likely that you will get back your 25v on ACDRV pin #4 but confirm it.
                                  Then the suspect is the 2nd DCin mosfet. It is probably defective and must be replaced.
                                  • jacobtc
                                    • Apr 2016
                                    • 274
                                    • Denmark
                                    #37
                                    Moved the resistor, still no change (0V on Pin 4).
                                    • mon2
                                      • 14231
                                      I am not clear on the operation done here on this resistor.
                                      Can you just hot air the part and remove it? Do not lose the part.
                                      Then we are sure the part is not being loaded down on the ACDRV pin.
                                      If you still do not gain back the 25v on ACDRV pin, then with care, measure each pin on the charger IC to ground.
                                      Post the readings for a review.
                                      • jacobtc
                                        • Apr 2016
                                        • 274
                                        • Denmark
                                        #39
                                        I just moved it, so it only had one pad connected. I have not removed it completely, no change.
                                        I did the requested readings, see pic.
                                        I still find it weird that the first DC-IN mosfet has 20V in, 0V out, then the next mosfet has 0V in and 4V out.. How is that possible?
                                        • mon2
                                          • 14231
                                          Sorry, I meant to measure the voltage to ground of each pin. Post the list again.
                                          Need to check if the charger IC has the conditions to spit out the boosted voltage on ACDRV. Be sure that the part is well fluxed and well heated to swim but settle down on the PCB pads, naturally. Low air pressure but enough heat to make it swim. Just in case there are any shorts, this process will correct the hidden shorts.
                                          • Mabot17
                                            ASUS gaming laptop GL704GV GPU DEAD SHORT
                                            by Mabot17
                                            Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                            i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                            Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                            05-10-2025, 11:04 AM
                                          • ktmmotocross
                                            Asus UX433FAC - batery dead after short on VIN rail
                                            by ktmmotocross
                                            Hello.
                                            Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                            can that short shorted battery? batmon show that battery is full at 80%
                                            12-29-2022, 12:06 PM
                                          • OOF DIO
                                            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                            by OOF DIO
                                            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                            (Had 3 problems, now just 1)
                                            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                            04-19-2025, 05:03 PM
                                          • jkucukov
                                            Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                            by jkucukov
                                            I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                            During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                            02-05-2025, 09:27 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
