Dead ASUS ROG G14 (GA401)
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    #101
    Re: Dead ASUS ROG G14 (GA401)
    Im sorry if this is a stupid question, but is this side ground? It measures 0.12 ohm, but the ?diode? Right above measures 20V on one side and 0V on the other… It just seems like the area marked with blue does not turn on, all measure 0-0.2V when plugged in and does not change when power button is pushed.
    • Sephir0th
      • Oct 2020
      • 1282
      It is GND and the "diode" is probably a Capacitor. Maybe we are on something with the 1.2V there, though. Detailed inspection of the circuit necessary, but not today (at least for me^^)
      FairRepair on YouTube
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        #103
        Alright, but I am guessing 0.2V isn't normal either, right?
        • Sephir0th
          • Oct 2020
          • 1282
          Originally posted by jacobtc
          Alright, but I am guessing 0.2V isn’t normal either, right?
          I strongly suggest to forget this area immediately. That's for battery charging and has nothing to do with your issue. Voltage without battery present is useless and meaningless.
          Edit: except you measure a short to GND at the coil.
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            #105
            Alright
            • jacobtc
              • Apr 2016
              • 274
              • Denmark
              #106
              Is this the expected voltage for VRAM described in the schematic? Page 78.
              • jacobtc
                • Apr 2016
                • 274
                • Denmark
                #107
                Great success! New BIOS fixed it! Got it all stripped down to test, but it outputs display!
                Now to figure out if the battery is salvable. I've had three generations of these G14, and common for them all is that they lock/kill the battery if anything happens with the board...
                • Sephir0th
                  • Oct 2020
                  • 1282
                  Good to know, the thing you pointed out in the schematics is just feedback Reference voltage and has nothing ro do with the actual output of the Phase anyway.
                  Now I'd be happy if the issues stop from now on...
                  • jacobtc
                    • Apr 2016
                    • 274
                    • Denmark
                    #109
                    Got Windows installed, and everything seems to work but the battery, so I will have to look into that... Have you had any luck unlocking batteries?
                    • Sephir0th
                      • Oct 2020
                      • 1282
                      Unfortunately not. I don't do that at all since this is only hobby for me. it just isn't economical for me tonsource a suitable device along with the mess to replace cells and all these things. Maybe someone else can help for this question.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        #111
                        Not advisable to "unlocking" batteries.Often the battery management PWM goes into protection when you dis connect cells. Need programmer to unlock that protection. I tried it on 2-3 batteries in my spare time and was able to fix only one out of three. The cost,energy and time simply dont make any sense. I just did it once for my own experience sake.
                        • jacobtc
                          • Apr 2016
                          • 274
                          • Denmark
                          #112
                          Alright, it just feels wasteful to throw out good cells. This is the third time doing it.
                          • jacobtc
                            • Apr 2016
                            • 274
                            • Denmark
                            #113
                            Bumping this thread in hopes of support for another thing wrong with this.
                            I finally received my battery, however Windows does not detect it charging at stays at 1%.
                            Battery norminal voltage is 15.4V, but is currently stuck at 15.1V and does not increase. Checked BQ, ACDET is 2.7V, ACOK is 6V, however BATPRES is 0V Is this a faulty aftermarket battery, or is something else wrong?
                            • mon2
                              • 14259
                              BATPRES is an active LOW signal. So when the battery is present, this pin should be low = 0 volts.
                              Remove the battery and this voltage should become a logic high value. Confirm it.
                              Measure the voltage to ground of each pin on the battery connector.
                              Post all measurements.
                              • jacobtc
                                • Apr 2016
                                • 274
                                • Denmark
                                #115
                                BATPRES is still low (0V) without battery.
                                All battery pins on board measure 0V.
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  On some boards it is pulled to GND by factory
                                  • mon2
                                    • 14259
                                    Good point. Forgot some models hardstrap the battery present pin to ground. Thanks.
                                    Remove the battery and power adapter.
                                    Meter in diode mode.
                                    Red meter probe, yes red to ground.
                                    Black meter probe to point to test.
                                    We are interested in the diode mode readings of pin #3 and pin #4 of the battery connector. Again, disconnect the battery during these checks.
                                    Pins #3 & #4 are the smbus SCL and SDA pins on the battery. We are checking if the ESD diodes at D5902 and D5903 are ok or if there are damaged from an ESD transient event.
                                    • Sephir0th
                                      • Oct 2020
                                      • 1282
                                      This thread has 6 pages already and I have no idea anymore what was tested and what not. So my suggestion is to test the DC-IN Mosfets (again)...
                                      • jacobtc
                                        • Apr 2016
                                        • 274
                                        • Denmark
                                        #119
                                        Do you mean Pin #4 & #5? Pin #3 is a BAT+ line.
                                        Pin #4 (CLK) reads OL
                                        Pin #5 (DAT) reads 0.5V
                                        • jacobtc
                                          • Apr 2016
                                          • 274
                                          • Denmark
                                          #120
                                          The board does get power though, it turns on, but battery is not recognized correctly
                                          • Mabot17
                                            ASUS gaming laptop GL704GV GPU DEAD SHORT
                                            by Mabot17
                                            Hello i need help to fix this laptop,at least a discrete to UMA conversion if it's possible.
                                            i took a photo of what i found,NVIDIA gpu side is 100% shorted as i desoldered power line coils and mosfet side is ok.
                                            Even without coils laptop still not power on.Main power rails,bios,1v,3,3v and 5v are present...
                                            05-10-2025, 11:04 AM
                                          • ktmmotocross
                                            Asus UX433FAC - batery dead after short on VIN rail
                                            by ktmmotocross
                                            Hello.
                                            Have this Asus UX433FAC that came with shorted mosfet on main power rail. After replace laptop works ok, but battery is dead. Laptop show charging but voltage on battery is 0.2V. when remove battery voltage on battery connector goes to 8.5V, but when connect battery again it goes down to 0.2V.
                                            can that short shorted battery? batmon show that battery is full at 80%
                                            12-29-2022, 12:06 PM
                                          • OOF DIO
                                            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                                            by OOF DIO
                                            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                                            (Had 3 problems, now just 1)
                                            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                                            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                                            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                                            04-19-2025, 05:03 PM
                                          • jkucukov
                                            Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
                                            by jkucukov
                                            I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
                                            During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
                                            02-05-2025, 09:27 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
