ATX Hiper type R 480W postfixing problem
  • harp
    • Jun 2022
    • 622
    • Planet Earth
    The psu has initialy shorted 5vsb and few rounded caps...
    I find short, there was big sb540 diode and one red small in glass no marking, from 5vsb rail to ground.
    After replaced sb540 with sb560, I supose that this glass diode was zenner 5v1, so I put it there. Also replace mentioned caps. I was so confident that I put all in box...
    All double checked, nowhere short is remaining, it has 5vsb and 5v ps-on now, but when power on, it briefly run (fan and voltage) and shutdown. This behaveour is repetable if again switch on. I do not use any bulb or toaster this time, nor any load.
    I conserned about these glass diode, if I miss point...
    Is it some changed in "modern" atx supply, say they need connection to mb or so? All before, they run naturaly when pson applied.
    Any idea?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8320
    Re: ATX Hiper type R 480W postfixing problem
    Sounds familiar to me. Look at my PowerMan IP PSU repair, it’s a similar problem, probably not the same, but it will give you an idea. Check out the feedback optocouplers. Find the one that goes to the supervisor IC shutdown. If the pin is high in voltage, it’s in protection mode. Force a ground to this pin and the supervisor IC is disabled…
    https://www.badcaps.net/forum/showthread.php?t=106011
    • harp
      • Jun 2022
      • 622
      • Planet Earth
      Thank you very much, I use your example for schortcut.
      Two main caps are ok, bridge is ok, but found one (of three) optocoupler who on one side no reading at all in diode mode. After desoldering, one side is stay still open... so I now must find something simmilar.
      https://www.tme.eu/en/details/ltv-81...output/liteon/
      Before I plugin to mains, is there anything else to check?
        • 31182
        817 is a very common part
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8320
          check the voltage on each pin of the optocoupler on the secondary side to secondary GND. Then look up the spec sheet of the opto. Also clearer pics would be nice. 817's are pretty common as stj already said.
          • harp
            • Jun 2022
            • 622
            • Planet Earth
            Is sfh690b situable replacement?
            https://cdn.badcaps-static.com/pdfs/...fe342584b2.pdf
            I have a couple of it, or must find harder 817...
              • 31182
              cny17 may also match
              the 690 looks good on paper, but the package is very small.
              • harp
                • Jun 2022
                • 622
                • Planet Earth
                That supose to do after conecting the main... if not blow up.
                But, what you mean with that, what I looking for?
                I visualy traced place with burned opto, burn side is on primary side, and it is not for 5vsb. Shall I dig to try find why it die?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8320
                  See if the supervisor shuts the PSU down. The opto needs a certain voltage to turn on. Upload a picture of the secondary side with the supervisor IC. Let’s see what this thing is.
                  • harp
                    • Jun 2022
                    • 622
                    • Planet Earth
                    I have a good news and a "good" news... which one first?
                    A good news is that I found pc817 from sharp, and a "good" news is that this opto has the same reading in diode mode as original, compared to original... I mean no reading on one side.
                    I connect on a dot side transistor tester, and with dmm monitoring other side... both do a brief reading, so it was both good.
                    I will return original opto on pcb.
                    Uh, I love working with device pluged in the main, I mean what can go wrong... right?
                    So, what next I lookin for?
                    EDIT
                    TL3842, LM339, L6561, NONAME 18 pin for fan
                    Previous repair on 5vsb
                    D7, ZD2, C18, C19
                    check all on secondary heatsink ok, and C20
                    • harp
                      • Jun 2022
                      • 622
                      • Planet Earth
                      Little help how to do that
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        Most ATX power supplies require a load to operate.
                        Please connect a few old hard drives or a PC mainboard and try again.
                        • harp
                          • Jun 2022
                          • 622
                          • Planet Earth
                          In my case, that "most" is my first atx who work like that...
                          Thank you, it work with mb connected, so this thread was false alarm to "most" people
                          I learn a lesson, and I will using it in future.
                          Thanks a lot
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8320
                            That brown goo, I’d remove on sight. It goes conductive after a while causing corrosion and spells trouble. I guess I am late, but yes this PSU has no loading resistors ( like two 100 Ohms resistors in parallel) on the output that I can see. Per already mentioned that there has to be a load on it and this would have been the next suggestion. That’s why good pictures are always important!
                            • hobostove
                              Corsair RM1000e - Help identify 5VSB Zener diode
                              by hobostove
                              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                              There's a 22ohm resistor that's melted and open, but it still has the bands.
                              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                              It looks like the diode connects the source and drain of a TNY284...
                              03-27-2025, 02:25 PM
                            • mikey5791
                              Tiny Tech ATX480W output power ticking
                              by mikey5791
                              Hi to all forum members,
                              ​​​​​​This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
                              Fyi, i desoldered the secondary side electrolytic cap those over 1000uf...
                              02-20-2025, 01:11 AM
                            • asr
                              Finding replacement diode iPad Pro 3rd gen A1701
                              by asr
                              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                              07-09-2024, 06:24 PM
                            • unimatrix93
                              TV backlight zener diode
                              by unimatrix93
                              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                              The led strips has 9 6V leds.
                              02-10-2025, 12:13 PM
                            • NicRac
                              monowheel repair,Is the diode the problem?
                              by NicRac
                              Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                              First of all, I am new here. Therefore I will shortly introduce myself.
                              I am Nico and currently I study Physics.
                              In my freetime I like to build and repair stuff. Especially big battery's.
                              A few years ago I got myself an electric unicycle, monowheel or however you call that.
                              The battery bms was broken so I replaced and resolder that. Nothing big.
                              I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                              07-26-2024, 06:13 AM
