DELL G15 5510 GDL55 LA-K661P bios
  • ibrahim03
    • Oct 2015
    • 142
    • egypt
    bios errors service tage has not been programmed
    Service Tag is : C54Y3G3
    alert : TPM device is not detected
    and i need clear me
    thank you advance
    bios Attachment
  • hardware1
    • Sep 2021
    • 2930
    • N/A
    Re: DELL G15 5510 GDL55 LA-K661P bios
    and i need clear me
    thank you advance
    bios Attachment
    What was your main problem? is that file is your original backup or it's for another device? what's your device service tag?
    all donations are welcome,
    • hardware1
      • Sep 2021
      • 2930
      • N/A
      and i need clear me
      thank you advance
      bios Attachment
      Here's your new bios file, try it and let me know.
      In the first boot go to bios menu, write your service tag, disable Absolute, save and restart then press (Alt+F) to exit the TPM.
      • ibrahim03
        • Oct 2015
        • 142
        • egypt
        the bios for another device
        problem is
        1- service tage has not been programmed
        my Service Tag is : C54Y3G3
        2- alert : TPM device is not detected
        3- i need clear me
        thank you advance
        • hoaca388
          Badcaps
          • Jan 2022
          • 11653
          problem is
          3- i need clear me
          thank you advance
          Try this files.
          • ibrahim03
            • Oct 2015
            • 142
            • egypt
            Originally posted by hoaca388
            Try this files.
            power on no data
            • ibrahim03
              • Oct 2015
              • 142
              • egypt
              no power
              • ibrahim03
                • Oct 2015
                • 142
                • egypt
                and i need clear me
                thank you advance
                bios Attachment
                can you fix file one ?
                  • 20709
                  do you have the original bios backup, where is the bios at post #1 from,is it a random one you found somewhere
                  • ibrahim03
                    • Oct 2015
                    • 142
                    • egypt
                    i don't have the original bios backup
                    but the file working power and data
                    • ibrahim03
                      • Oct 2015
                      • 142
                      • egypt
                      and i need clear me
                      thank you advance
                      bios Attachment
                      i need fix
                      and i need clear me
                        • 20709
                        Use a much older bios region update and the TPM error should be fixed
                        • ibrahim03
                          • Oct 2015
                          • 142
                          • egypt
                          Indeed, I did a BIOS update, but the same problem is also a problem with a delay in showing the data, after about 25 seconds.
                            • 20709
                            Well the ME firmware needs cleaning as well. You can try that yourself sometime, we have some guides for that https://www.badcaps.net/forum/showpo...41&postcount=3
                            • ibrahim03
                              • Oct 2015
                              • 142
                              • egypt
                              There is another problem
                              • hardware1
                                • Sep 2021
                                • 2930
                                • N/A
                                Try this older version.
                                • ibrahim03
                                  • Oct 2015
                                  • 142
                                  • egypt
                                  no power
                                  • beast4ever
                                    • Feb 2015
                                    • 159
                                    • egypt
                                    Dell G15 5510
                                    Service Tag: 7BWW0H3
                                    Express Service Code: 15957845607
                                    I need a 32mb file. 2mb. There is no backup because the old IC is damaged.
                                    The existing version is 2MB. Thanks to my friends.
                                    • beast4ever
                                      • Feb 2015
                                      • 159
                                      • egypt
                                      Originally posted by beast4ever
                                      Dell G15 5510
                                      I need your help, friends. I tried the files in the topic, but it did not give an image.
                                      • bbanana
                                        Father Land
                                        • Oct 2021
                                        • 164
                                        • Vietnam
                                        hard to help, no orignal BIOS some model cant boot, Logo frezee or turn off after write servicetag, cant detect TPM device,...
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          Dell Latitude 5580 possible bios corruption
                                          by gizaha
                                          Dell latitude 5580, motherboard cdp 80 la-e151p
                                          3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                                          (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                                          I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                                          Since ssd is replaced and had clean install windows, i've...
                                          02-13-2024, 07:18 AM
                                        • mrrubik
                                          Dell Optiplex 7010 micro bad BIOS flash?
                                          by mrrubik
                                          Hi folks,
                                          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                          Steps I took:
                                          1. Read BIOS with CH341a, verified hash twice
                                          2. Patched
                                          12-23-2024, 04:11 PM
