old Bravia double fail?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Well, got another broken TV due to overconfidence I suspect, alas this one is another dud like the other TV I have that seems to have a bad tcon (not worth to buy another)...
    Anyway as received the backlight is out. Okay, but the power supply looks good, got a solid 24V out to the backlight. So I tried feeding in voltage into the backlight enable...still no light. Boo. Probably bad inverter or bad tubes.
    Okay...so that sucks, now the other half: the mainboard. Again PSU seems to get the right voltages out so rule that out. Can't see anything in screen with a bright light and the mainboard doesn't detect when the backlight inverter is disconnected (no error code)... so I think the mainboard is also dead. Also couldn't seem to get sound out of the TV as I randomly pressed buttons on the remote. The only button that seems to do something is the power button.
    So...looks like I got a rock here, better luck next time, apparent double failure is just not a good omen, perhaps it was a parts unit peddled out as a leftover parts unit or something *sigh* if only I could tell if the panel is any good, probably can't until the backlight is up, chances are the panel is also bad.
    Risky risky...disposal is the unfortunate cost.
  • nomoresonys
    • 12307
    • U.S.
    Re: old Bravia double fail?
    does the indicator light on front of tv light up at all, red light, green light, blinking etc?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4517
      • Italy - Milan
      7466 posts and you haven't learned to post Brand+model+photos?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        Nah this is just a rant post, buying/replacing boards is not economically feasible (can't afford, can't pass the buck), highly doubt it's something simple at this point after triage.
        Green LED turns on and stays on until power (either remote or power button, the NTC short out relay clicks/is working), no blink codes hence concluding a failed main board as the manual I found indicates it should blink codes if I disconnect the inverter board, but it doesn't. So that pisses me off...
        Btw nomoresonys I like your name due to the irony in my situation since the TV is a ... Sony Now it'd be interesting why Sony is so bad...share!
        • nomoresonys
          • 12307
          • U.S.
          did you try an update via usb, could work if this is one that does the update automatically without any remote clicks needed, my old kdl did it automatically. Have had some pretty bad luck with sonys, there is one good thing about them tho, that is they are not samsungs.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            LOL...
            Alas kind of ironic here, I was able to restore two samsungs to functional condition (granted one was just bad backlight LEDs, so ezpz).
            Well, I have little hope that the board actually is functional at this point so chances are USB doesn't work, but thanks, worth trying if FW is available. I can see that it at least is supplying USB power but the board is probably "light's on, but nobody's home" situation.
            BTW audio would be interesting, alas with the backlight out, can't use menus to turn on if it's an option. The samsungs (now have three, the CCFL LCD, LED LCD, and my DLP) had an option to play tones on power up, wonder if the older bravia models could do the same (if there was some way to enable it...) Alas of course I usually turn it off, maybe I should leave it on as a first line of defense on figuring out if the board failed or not the next time they fail.
            • nomoresonys
              • 12307
              • U.S.
              does the tv power on and off with the remote, as in the solid green light goes on and off with remote? thats what mine did, an update fixed it.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8703
                Yep solid green light with remote on and off, alas, it doesn't seem to read the update. Might need to try other USB sticks but don't have much hope...
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  Oh weird... there is some sort of life but not much...
                  I have this SD to USB adapter that I was using for the FW update. When the TV is turned on from the remote, the LED flashes once real quick, about 0.2 seconds.
                  This behavior differs from when I plug the SD to USB adapter in a wall wart where it turns on and stays on... so it looks like the TV is doing something, unsure what though... hmm!
                  This behavior is repeatable, I can make the USB SD adapter LED blink by turning the TV on and off from the remote or side panel.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    whats the model number
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8703
                      Service manual is here: https://servicemanuals.us/sony/tv/kd...l-46s5100.html
                      • nomoresonys
                        • 12307
                        • U.S.
                        ok, sonys can be fussy, good idea you have to try another usb, maybe skip the adapter and just use the thumb drive in the hdmi port.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8703
                          Tried a few USB in the USB port, no dice... some don't light, some just blink once... is there an override, will it flash firmware if the current version is the same as the flash version?
                          • nomoresonys
                            • 12307
                            • U.S.
                            so if you look real close with a flashlight and hit menu button theres no text or anything that you can detect?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              Couldn't see anything on screen as far as I can tell but not sure where to look. (Also some of these displays are so dark from the front that maybe I need a bigger flashlight ...)
                              I should say Bravia in the center on boot? Didn't seem to see this...
                              • nomoresonys
                                • 12307
                                • U.S.
                                is the optical out port lit red on the mainboard.
                                • R_J
                                  • Jun 2012
                                  • 9607
                                  Check the fuse on the t-con, I had one similar Sony model that had an open fuse and that was all that was wrong.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8703
                                    The optical out LED is NOT lit It flashes briefly when turning off.
                                    I don't think it's tcon at this point, unless the tcon affects the main board functionality?
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8703
                                      hmmm... if I leave it unplugged and then try to do FW update one of my USB stick blinks a few times for a total of a second before it stops. If I don't unplug and power cycle, it only blinks once for less than 0.2 seconds and stays dark.
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8703
                                        BTW, what I do wonder... should I investigate further and then find the panel bad, or should this be deemed a lost cause already since the inverter seems to be bad?
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
                                        • noinimod
                                          Sony 55X900E no standby light, no power. Replaced mainboard already
                                          by noinimod
                                          No standby red light, nothing
                                          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                                          Disconnected JK3 power board from main board, checked voltages on all the pin outs
                                          At a few pins I can see the power supply providing 19.5V to the main board
                                          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                                          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                                          12-22-2021, 12:58 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                          LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                          This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 03:40 AM
